MX HQ10 all versions
@Matrix10
two questions:
1. Is it possible to move down the infobar until the extreme of the image?
2. Is it possible to increase a little bit the transparency of the skin?
Thanks a lot for this great work!!
regards
Yes it is possible but I will not change the skin.
To move OSD, use the editor
look for in skin.xml
<screen name="InfoBar"................position="0,830"
and
<screen name="SecondInfoBar".............position="0,763"
higher the number, OSD more down example
<screen name="InfoBar"................position="0,840"
@Matrix10
The skins MX HQ10XC and MX HQ10X are not available for download on Vu+ solo se.
Is it possível to have it?
Regards
Not because skins can not be used with constant image changes and adding plugins
will change position of the icons.
I decided not to use these skins,
because coding does not allow automatic icons position change.
I suppose you did not mean "MiniTV" because MiniTV is the name of the function that shows TV in the display of the box.
I suppose you meant PiG (Picture in Graphic). If so (we need to be precise in IT world) it can't be "disabled" simply because some skins have and some doesn't. You need to try other skins, in case.
Sanırım "MiniTV" demek istemediniz çünkü MiniTV, kutunun ekranında TV'yi gösteren işlevin adıdır.
Sanırım PiG (Grafik İçinde Resim) demek istediniz. Eğer öyleyse (BT dünyasında kesin olmamız gerekiyor), sadece bazı kaplamaların sahip olduğu ve bazılarının olmadığı için "devre dışı bırakılamaz". Her ihtimale karşı başka dış görünümleri denemelisin.
Which skin would you recommend?
Sorry: I can't, because I absolutely want PiG while showing menus or the channel list or EPG: so I only know skins with PiG. Mine's EclipseFire, for instance.
If I rember correct the MX HQ 10 was my favorit skin for a long time.
If you open the Channel List and press menu to open Context meny
Chose Configuration
Chose slim instead of Standard in Service list mode*
Press Green button to save
Restart Enigma2 and you have the Channel List without PIG
Doğru hatırlıyorsam, MX HQ 10 uzun süredir en sevdiğim görünümdü.
Kanal Listesini açar ve Bağlam menüsünü açmak için menüye basarsanız
Yapılandırmayı Seçin
Servis listesi modunda Standart yerine inceyi seçin*
Kaydetmek için Yeşil düğmeye basın
Enigma2'yi yeniden başlatın ve PIG'siz Kanal Listesine sahip olun
[EK]51481[/EK]
Thank you for your help. What should I do for full screen overlay?
