MX HQ10 all versions
You can download this skin from OBH image server
This skin using nieuw Menu coding so you have to update image first.
Skin Update MX HQ10X & MX HQ10XC
On BH/OBH download server
Change removed background button in Main menu panels
Small change in graphicEPG
Removed unused files.
For skin use last upgraded image.
How to reinstall skin?
If you have older version
De-install and again download / install
Or
Again download and re-install?
Sent from my iPhone using Tapatalk Pro
Hello,
do you know how to open info bar epg.
also how to display the multiepg like in the screenshoots here... with the blue graphic bars..
lastly what is the best between mx hq10b, hq10x and hq10xc?
sorry for the trouble.
kr
Mario
Continued HQ10 series of skins
MX_Lacroma
Hello,
kr
Mario
Long press Epg button
In EPG press Menu button for options
Hi!
Which Picons are u ising in the preview Pictures of HQ10?
Just installed your skin on OBH 0.6
I cannot find the OSD settings as described for 0.4
Hi!
220x132 transparent picons. ( you can done some of them, depending of sat position, ( Levi or Halus 220x132 for Black Hole )).
For OSD settings:
Press <MENU>; <Black Hole Apps>; <OSD Settings>.
