MX HQ10 all versions
@Matrix10
i know it is a plugin but is it possible to solve this home screen problem in live football plugin (it only happens with fullHD skins)?
regards
@Matrix10
regards
Do not misunderstand me.
Well, that should make the author of the plugin.
This implies that Skinner should correct all the coding in plugins in skin coding,
and we already have a lot to code,and this is not good for image performance.
We moved to 1920 x 1080 skin format a long time ago
even some very famous plugins still are with old format.
I think users need to ask the authors of plugins
to solve this problem,
adding plugins coding in to skin code is not a good solution.
Rgd MX
Hi
Thanks Matix10 for a fantastic skin.
There is one issue; the second info bar shows some random/wrong frequency, is it the skin or the image that do that?
Regards
Iradj
Hi
Regards
Iradj
Skin shows what you get from image programming.
@Iradj there´s no issues with @Matrix10 skins. Afaik, @Matrix10 skins are the best in the enigma2 universe skins.
By default the image has this parameters ( Infobar Frontend Data Source = Tuner ). You have to change this from "TUNER" to "SETTINGS" in "OSD SETTINGS" Menu ( Screen Shot ):
Press <OK> or <GREEN> to save and restart enigma2.
When restarted you can check if all is like the next Screen Shot: 11361 MHZ
Thanks nunigaia , it´s work :-)
regards
Iradj
Press in your remote control:
<MENU>; and choose <SETUP>; <USER INTERFACE>; <OSD SETTINGS>;
Test and set it as you desire...
In various <menus>
Like:
  • INFO
  • EPG
  • CHANNEL LIST
etc ....
By pressing the MENU key on your RCU ( remote control unit ), you can set fonts and lots of settings for MENUS ... picons, pig, text, graphics and so on ...
Set independ fonts size, for events name, services names, picons size, etc.
Is it possible to show always second infobar and not first and press OK?
I can't find option to set fonts size. Can You explain better, please? When I must press MENU key on my RCU for set settings for MENUS?
In severall menus, like channel list, epg infos ( multi and single ), by pressing <MENU>, you can set the font size, for severall itens like:
- picons size
- Event info size
- Service Name size, etc
Note: For the first question, the answer is NO.
Thanks, hope to see it for blackhole , dont use openblackhole for now.keep up the work best skins from iou on the market. Will you update graphics for blackhole for more tuners
