MX Lacroma
Im sorry
I think not for OBH,
the image is constantly changing ,
and then I do not have the time or the will to make again graphics and coding.
@Matrix10
Hi no need to be sorry I FULLY understand the hard work you put in to these wonderful skins that so many on here and elsewhere seem to enjoy!! :) :)
I'm currently using your MX_Maestra2C skin and its perfect on OBH ... thanks.
Keep up the great work i really appreciate the effort as I'm many on here do too!!! :)
Hello matrix10. Will you update lacroma and hq10x to bh305L
It is impossible,with this kind of standard E2 image coding for skins.
Let me explain.
Each plugin or image addon has its own ID number.
Which determines the position in, for example, the plugin list.
In the case of skins, the list is static,
and the position of the icon is linked to the plugin ID number
Positions are pre-determined.
Previously, the plugin authors used high numbers
and image standard adding low ID numbers (system,menu,search,media player, ..)
However, some authors no longer hold that rule.
In this case, it is impossible to make skin with such a layout of icons.
Just install a external plugin with a low ID number and a full list of icons (positions in the list) is no longer good.
