MX Maestra
Skins Update for better support BH 3.0.4
Download from BH image server.
MX Maestra Black (for BH 3.0.3 and up ver)
MX Maestra2 (for BH 3.0.3 and up ver)
MX Maestra (for BH 3.0.3 and up ver)
MX Maestra C (for BH 3.0.3 and up ver)
MX Maestra2 C (for BH 3.0.3 and up ver)
very beautiful and simple skin.. looking forward to it.
is it possible to make the event text different than channel name next to it in channel list screen ( color or text formatting )
shot6-jpg.29345
thank you so much for your beautiful work
thanks matrix 10 nice skin
i have a question if i can change the blue to transparent och grey
Thanks Matrix10, it's an amazing skin!
I hope it's ok to make a few modifications according to taste and needs, for personal use only of course. ;)
If it is for personal use.
I would not know that either :D
Haha, you're right. :laugh:
I just replaced the signal bar with a colored one in infobar and added some information about highlighted channel (and a clock) in channel list, instead of 'next event'.
Here are two pics, please feel free to remove them if it is against the rules.
However, I couldn't figure how to remove those annoying channel numbers in the list, and it doesn't exist a setting to do so in setup screen either. :oops:
Can you help me with that, if it's an easy task like deleting or changing a few lines in skin.xml ?
Thanks again for this beautiful skin.
You can not delete it but you can hide it.
The problem is that you have a big space without anything if you hide.
And this can not be changed in skin coding.
Search in <screen name="ChannelSelection"
coding
serviceNumberFont="Regular;26" change to hide serviceNumberFont="Regular;00"
Great, thanks for fast reply.
I'll try and see how it looks, maybe replace them with small picons if I manage to. :rolleyes:
Here's how it looks:
I changed the color of event description too while at it, but I have no idea why the color of little progress bars changed as well.
However it doesn't look bad at all, in fact I quite like it this way. :cool:
Thank you for your help.
