MX Maestra
MX Maestra Blue
MX Maestra Gray
MX Maestra Firebrick
You can download skins from the Black Hole image server.
thanks dear matrix10
i like to say please : develop army skin (skin in Up and Down of picture ) in 1080 Full HD and big picon size
please
please
please
please
thanks for nice works
Skins UPDATE
Other panel Icons
and in some skins other changes
MX Maestra Black (for BH 3.0.4.A and up ver)
MX Maestra C (for BH 3.0.4.A and up ver)
MX Maestra (for BH 3.0.4.A and up ver)
MX Maestra2 Black (for BH 3.0.4.A and up ver)
MX Maestra2 C (for BH 3.0.4.A and up ver)
MX Maestra2 (for BH 3.0.4.A and up ver)
MX Maestra3 Black (for BH 3.0.4.A and up ver)
MX MaestraSE3 (for BH 3.0.4.A and up ver)
MX MaestraSE2 (for BH 3.0.4.A and up ver)
MX MaestraSE1 (for BH 3.0.4.A and up ver)
MX MaestraGray (for BH 3.0.4.A and up ver)
MX MaestraBlue (for BH 3.0.4.A and up ver)
MX MaestraFirebrick (for BH 3.0.4.A and up ver)
Hi Matrix, I must say I really like, for instance, the MaestraFirebrick and its similar skins. Only, I find that the timer windows is really small and you can read only 7 timers per page whilst, for instance, Waves1 displays 11 item. Not only that: again talking about Timers, in MaestraFirebrick the last field (containing the kind of timer, is partially overwritten by the kind of service. So, also a wider windows might solve this issue.
P.S. I also noticed that markers are not in the right position (recognizable by the bar colour; or maybe is the opposite, that the bar is not aligned to the marker.
In the screenshot I post, obviously, I set the markers while the movie is paused and so their positions should coincide to the bar.
Is this Black Hole or Open Black Hole ?
This is Black Hole
skin section
You use open black hole.
I have fix i think all you write abt skin Movie Player and Timer
Open Black Hole Timer List
You can test with Open Black Hole
Replace skin.xml in MX_Maestra_Firebrick folder OBH image.
If it is good,
I'll have to make an update for all other skins
Yes, you are completely right. I got by mistake into the BH thread whilst I use OBH.
I tested it and it's perfect for both issues! Do you plan the PIG for these skins?
Maybe with a different graphic.Not this one.
But,
I think PIG is not more modern.
Skins UPDATE
Movie player Marker position
MX Maestra2 weather Black Hole
you can download from BH image server
Skin for weather in extra OSD
1. First you have to download and install from BH image server (green button)....BH plugins>>>Weather Plugin
2 Start Weather Plugin set your city and city code with Menu button/yellow button ....
3.Download and use this skin for Weather info in extra OSD (2 x OK button)
skin format 1920 x 1080
picon format 220x132
Regards MX
MX Maestra2b Weather
download from BH server
Skin for weather info in extra OSD
MX Maestra Black Weather
Is it me? or MX Maestra2 Black Weather really slow when press previous channel or next ch. (History Zap)
Is there version without Weather plugin?
