MX Redline/RedBlack skins
Thanks for your skins and all your work. Will there be MX Blueline/BlueBlack before other skins.
I do not think, not for now
blue OSD (from RedBlack) do not look to me as good as the red version.
Maybe later in combination with different OSD.
This OSD would also be a good with BlueBlack.
I like the MX X series skins specially Menu panels
and so I made ​​a new OSD for them
because I do not like totally black skins.
Even I think it's not a bad idea to use this OSD with the blue version
with redblack menu with blue buttons e.t.c.
Totally agree with you that if you're not satisfied with the end result, it's not worth it doing it. Your Benchmark is always going up and is shown by your excellent skins. Wait for your MX X3.
chanel lista ?
da vidimo kanal lista kako izgleda :D
No channel list works without it :D
Only a hundred Picons in channel list
as in picture book.
Well, I said that there will be no new panels
and Channel list.Only color changes
Just New players and OSD,
Movie player, DVD player, MyTube player.
We already have many good panels.
Why should they change.
We may use
Panels from X2 or RedBlack but with a blue buttons,
and TV PIG
I'd would prefer to try,
Narrow OSD with example Clock and/of Picon in the upper right TV screen corner.
But we'll try another time
@MX
I made a few OSD icons and replaced in your RedBlack skin (personal use), they look good and clean. You are very busy making so many graphic and coding to create such great skins, but maybe interested to replace some icons in them; in that case be my guest.
