My hdd performance test
I was using a mates box earlier shiro... this is mine now same model hdd and box..seems to be a difference tho thanks
Before format (test 1) ext3
root@bm750:~# cd /media/hdd
root@bm750:/media/hdd# dd if=/dev/zero of=./output.img bs=8k count=256k
262144+0 records in
262144+0 records out
2147483648 bytes (2.0GB) copied, 56.766664 seconds, 36.1MB/s
Before format (test 2) ext3
262144+0 records in
2147483648 bytes (2.0GB) copied, 59.223396 seconds, 34.6MB/s
After format to ext4 (test 1) ext4
262144+0 records in
2147483648 bytes (2.0GB) copied, 31.084794 seconds, 65.9MB/s
After format to ext4 (test 2) ext4 ............also added some plugins etc as was fresh install...
root@bm750:/media/hdd# cd /media/hdd
262144+0 records in
2147483648 bytes (2.0GB) copied, 34.917347 seconds, 58.7MB/s
BlackHole 2.0.4 bm750
My Vu+ box: vu duo
Hdd Vendor model: ST3500312CS
Capacity: 500GIG
External / Internal: Internal
Filesystem: ext4
262144+0 records in
262144+0 records in
Many thanks Romman, great test !!
Now we know that ext4 will increase performances also in SataII box.
The theoretical limit of the SATA II is 384 MB/s then the benefits of the bus SATA3 only be obtained with a solid state drive.
With the normal hard drives there are not differences in performance between SATA2 and SATA3 box.
Yes it's true.
Anyway solo2 and duo2 seems to have better performances in hdd managment.
Yes it's true.
Also the old Vu+ models (DUO-UNO-ULTIMO) have the SATAII bus, so if you use a normal disk (SATA2 o SATA3 NOT SSD) the performance will be the same as the SOLO2-DUO2.
But to take advantage of the SATA3 speed necessarily need a solid state drive.
No the hdd performances are better in solo2 and duo2 and much better on a desktop Pc.
The hdd performances depend from many variables and the hardware of Duo2 and Solo2 is more powerful than previous models.
With my hdd model (WD AV25 BUCT) i have a similar performance between Notebook (Llano quad core,SATA2) and SOLO2.....
We are going off topic but just to show something flying :D
Atemp$ dd if=/dev/zero of=./output.img bs=8k count=256k
262144+0 record dentro
262144+0 record fuori
2147483648 byte (2,1 GB) copiati, 4,41721 s, 486 MB/s
With what (or which :D) hard drive? Crucial m4?
ok to be more precise
These are my 3 hdd on I7 core ( sataIII cable to SataIII Marvell controller )
VERTEX3 MI SSD 120GB
AGILITY4 SSD 256GB
2147483648 byte (2,1 GB) copiati, 4,44776 s, 483 MB/s
Samsung SSD 840 500GB
2147483648 byte (2,1 GB) copiati, 4,32085 s, 497 MB/s
end off topic
My Vu+ box:solo2
Hdd Vendor model:Toshiba MQ01ABD0
Capacity:500 gb
External / Internal:internal
Filesystem:ext3
Test result:
262144+0 records in
2147483648 bytes (2.0GB) copied, 34.374048 seconds, 59.6MB/s
My Vu+ box:solo2
Capacity:500 gb
Filesystem:ext3
Test result:
262144+0 records in
My Vu+ box: Solo2
Hdd Vendor model: Toshiba MQ01ABD050
Capacity: 500 GB
Filesystem: ext3
Test result:
262144+0 records in
2147483648 bytes (2.0GB) copied, 73.357324 seconds, 27.9MB/s
Note: Installed and formatted 7 months ago.
Same boxes, the same disks. Booh?
@krca: Did you test on BH2.0.4? Fresh formatted in ext3?
The meaning of all your figures is uncertain. To test a SSD you should better use AS SSD Benchmark program for Windows.
My Vu+ box: Uno
Hdd Vendor model: Seagate Momentus 7200.4 SATA 3Gb/s (ST9500420AS)
Capacity: 500GB
Filesystem: ext3
Test result:
root@vuuno:/media/hdd# dd if=/dev/zero of=./output.img bs=8k count=256k
262144+0 records in
2147483648 bytes (2.0GB) copied, 48.712161 seconds, 42.0MB/s
2147483648 bytes (2.0GB) copied, 44.967611 seconds, 45.5MB/s
2147483648 bytes (2.0GB) copied, 45.823478 seconds, 44.7MB/s
2147483648 bytes (2.0GB) copied, 44.679826 seconds, 45.8MB/s
2147483648 bytes (2.0GB) copied, 44.532106 seconds, 46.0MB/s
2147483648 bytes (2.0GB) copied, 47.481253 seconds, 43.1MB/s
My Vu+ box: duo
Hdd Vendor model: westerndigital caviar blue
Capacity: 500gb
External / Internal: internal
Filesystem:Ext3
Test result: 40.3MB/s
My Vu+ box: Uno
Capacity: 500GB
Filesystem: ext4 (ext3 results)
Test result:
262144+0 records in
2147483648 bytes (2.0GB) copied, 32.436546 seconds, 63.1MB/s
2147483648 bytes (2.0GB) copied, 32.393913 seconds, 63.2MB/s
2147483648 bytes (2.0GB) copied, 32.146557 seconds, 63.7MB/s
2147483648 bytes (2.0GB) copied, 32.105352 seconds, 63.8MB/s
2147483648 bytes (2.0GB) copied, 32.101931 seconds, 63.8MB/s
2147483648 bytes (2.0GB) copied, 32.076711 seconds, 63.8MB/s
Filesystems differences:
ext3: /dev/sda1 on /media/hdd type ext3 (rw,relatime,errors=continue,barrier=1,data=writeback)
ext4: /dev/sda1 on /media/hdd type ext4 (rw,relatime,barrier=1,data=ordered)
Conversion Ext3-To-Ext4
Unable to convert internal hdd, because internal command tune2fs (part of busybox) does not have implemented necessary features. Backup recordings and do hdd inicialization and re-mount. Ext4 preformance is better as Ext3.
