My hdd performance test
My vu+ box: solo 2
Hdd vendor: samsung HM251JI
Capacity : 250 GB
Size 2.5
Internal
Test result
root@vusolo2:/media/hdd# dd if=/dev/zero of=./outpu
t.img bs=8k count=256k
262144+0 records in
262144+0 records out
2147483648 bytes (2.0GB) copied, 40.632639 seconds, 50.4MB/s
Inviato dal mio GT-I9300 utilizzando Tapatalk
My Vu+ box: Duo2
Hdd Vendor model: Seagate PN: 9JB1N4-575 RPM = 7200
Capacity: 3 Tera 64MB Cache Partitions = None
External / Internal: Internal
Filesystem: Linux ext3
Image = BH 2.0.7 .2 ATSC
Test result:
root@vuduo2:/media/hdd# dd if=/dev/zero of=./output.img bs=8k count=256k
262144+0 records in
2147483648 bytes (2.0GB) copied, 13.613609 seconds, 150.4MB/s
Notes:
This HD was installed straight from the box, brand new. Original format type is unknown to me.
The Duo2 is my first VU+ receiver. I did not have much information on how to install this hard drive when I got it. The receiver immediately recognized this drive when it was installed, but I could not access the hd to record on it or use it
All I did to solve these problems was to do an image back-up. Doing this caused the receiver to format or to make this drive useful and accessible. Linux ext3 format is what I ended up with without any partitions. EB
My Vu+ Duo2
hdd vendor: Toshiba SSD 2.5 - 128 GB M/N HDS2
internal
filesystem Linux ext4
image: BH 2.0.7.1
test result:
262144+0 records in
2147483648 bytes (2.0GB) copied, 12.675709 seconds, 161.6MB/s
Hi Siro
I formated my Toshiba SSD 2.5 - 128 gb with this command:
# umount /media/hdd/ ; /sbin/mkfs.ext4 -T largefile -m0 /dev/hda1
and it reported no error, but I am not sure if it is on ext4. to be sure, what I have to do?
greetings
My Vu+ box: Duo2
HDD Vendor model: Western Digital AV-GP 7200 64MB SATA 3
Capacity: 2 TB
Filesystem: ext4
Image: Black Hole 2.0.9.1
Test result:
262144+0 records in
2147483648 bytes (2.0GB) copied, 17.986806 seconds, 115.9MB/s
Hi all,
He is my test with new SSHD 2.5 SATA III 6GB from Toshiba with 1 Tb
My Vu+ box: Vu+ Uno
Hdd Vendor model: Toshiba SSHD MQ01ABD100
Capacity: 1Tb
Filesystem: ext4
Test result: 59.7 Mb/s
Let you know the test once new Solo2 is delivred
Regards
Amine
My Vu+ box: Solo 2
Hdd Vendor model: 1TB Samsung HN-M101MBB Spinpoint M8, 2.5", 9.5 mm, SATA II 3Gb/s, 5400rpm, 8MB Cache, 12ms with Ecoseek
Capacity: 1000 GB
Filesystem: Ext 4 (formatted by black hole)
Test result:
262144+0 records in
2147483648 bytes (2.0GB) copied, 24.245535 seconds, 84.5MB/s
These are quite useless benchmarks. You should first deside what you want from your HDD in a satbox, MB/s or reliability?
It is well known that some of SSDs can read/write at >1 GB/s (e.g. OCZ ZD4CM88-FH-3.2T), so HDDs will disapear soon as floppies did.
Please, remember that this is not a comment or discussion thread!
Possibly these last 2 posts (mine included!) could be deleted from the thread to keep it clean.
disk is initialized in Dreambox 3 years ago:
My Vu+ box: Duo2
Hdd Vendor model: Seagate ST31000340NS
Capacity: 1 TB
Filesystem: EXT3
Test result: 2147483648 bytes (2.0GB) copied, 35.153243 seconds, 58.3MB/s
same disk fresh initialized in VU+ Duo2
Test result: 2147483648 bytes (2.0GB) copied, 19.285293 seconds, 106.2MB/s
My Vu+ box: Duo2
Hdd Vendor model: TOSHIBA DT01ACA200
Capacity: 2 TB
Filesystem: EXT4
ATA SATA III
Test result: NOT YET
Hi,
Here is a new test with my Duo2 and new SSD
My Vu+ box: Duo²
Hdd Vendor model: Transcend SSD Série 320
Capacity: 256 Gb
Filesystem: ext4
Test result: 2147483648 bytes (2.0GB) copied, 14.425711 seconds, 142.0MB/s
Thank you
Amine
My Vu+ box: Duo2
Hdd Vendor model: Toshiba MD04ACA400
Capacity: 4 TB
Filesystem: ext4
Test result:
262144+0 records in
2147483648 bytes (2.0GB) copied, 15.129957 seconds, 135.4MB/s
My Vu+ box: Duo2
Hdd Vendor model:Western digital WD20EARX-00P SATA 6 Gb/s Cache 64MB
Capacity:2TB
External / Internal: internal
Filesystem: ext4
Test result:
262144+0 records in
2147483648 bytes (2.0GB) copied, 26.612032 seconds, 77.0MB/s
the strange thing is that in the datasheet it says Host to/from drive (sustained) 110 MB/s
Vu+ Duo²
HDD: Seagate Momentus Spinpoint (ST1000LM024 HN-M) SATA2 (3GBit/s), 5400rpm, 8MB Cache
Capacity: 1TB
Ext/Int: Internal
Filesystem: ext4
Test results: 2147483648 bytes (2.0GB) copied, 17.846784 seconds, 114.8MB/s
