MY Tube Fix VU Duo OE 1.6
I install the two files as cited above but when i start mytube "seaching feeds" but took more time then i had crash and restrat!!!
Sorry i just noticed that this pluging is for Vu+Duo:blink:, can i use it with Vu+ Uno?
Have you tried directly with the plugin into image before apply this (old) fix?
yes i try it but only old files on it?
Can you fix this problem in the next NEW BLACK HOLE 1.7.0 FULL MULTIBOOT​
Thanks​
Thanks​
What kind of a problem ?
MyTube in the image works good.
at least that was the case when I last tested.
Does not require update ,and you should not update.
I tested in the new multiboot image version and there is also good.
But if you still have a problem
Then he is caused with something.
Search
still problems even in 1.7.0 forget the thing,the image is class and this is putting a downer on it just sack it off because it just cant be fixed,dont belive it works for anyone has i tryed shops duo it was same there
Tested on vu duo, and works fine!
I think the problem specifically with U , No one is forcing you to use Black Hole Image!
Criticizing in constructive way is good and appreciated to share our experiences ,,,, !
However, If you are not happy with us , then GO back to what ever image U are using,,,and stop spamming our fourm with your nigative thoughts!
a911
BH Lover
like ive said before you people can not take any problems and then by default start saying childish statements like :go back to whatever image you used before:
The fact of the matter is ive used blackhole with great sucsess and had a few problems mostly with streaming media through plugins like mytube and youtube players there play but dont have sound. this might not be a problem with you but i cant lip read.
How is that slagging blackhole off? i dont want you to waste your time replying as i cant be bothered arguing.all i know is ive tryed three blackhole images and non of the mytube or even usb playback have sound apart from that its a great image that i will continue to use thankyou very much.One day the developers might say somthing like there is a serious problem with audio that we are yet to fix instead of pointing fingers to people like me who are using the image.i defend blackhole to the hilt but i cant argue against problems that a clearly there and not fixable.
I have to say I don't really bother with Youtube plugins on my box or even my tv.
But i've just tested Mytube player on my Vu+ Ultimo, with BH 1.7.0 and I have no problem with sound.
But we do not have this problem.
And if we had
We would not be able to solve
because we did not make MyTube plugin.
My kids are always using Mytube (usually when I want to watch something on TV) and there is no problem with sound on Vu+Duo and BH 1.7.0.
