MyMetrix-OpenStore BH 2.0.x
Hi Cappa,
can you help me how I can install the Skinpart the AMS? I have tried everything but I can not make it!
Thank you
Hi,
Loving the skin, had it on VTI but want to go back to BH.
Having a little problem though. I was running BH 2.0.4, downloaded the plugin, created the swap file, did generate skin, and then when I went to apply skin in the System > Skin menu, it said that this skin was not compatible with this version of Black Hole.
I believe my VU+ Solo is a clone if that helps.
Any ideas? Desperately want this skin back!
Thanks in advance.
Hi,
Thanks in advance.
Smple: NO HELP SUPPORT FOR CLONES HERE.
Banned for 1 week.
Hey guys,
Any one managed to get this skin work with BH 2.0.9 ? works great with 2.0.8, but when I tried it with a fresh install of 2.0.9 it didn't load correctly and in some cases it says not compatible with BH version.
So, in order for me to understand, this mymetrix is not a skin but a way to add a selection of other skins in your basic skin ??? or is it a skin that replaces the already installed skin ??
Hey guys,
It works but you must choose mod by capa an after apply the skin...
Thanks for this Great skin. The only thing I miss is that in channel list there's only current program description. I would love to see both CURRENT and NEXT program DESCRIPTIONS SIMULTANEOUSLY. Is there a way to edit some file (EventName.py or something, I don't know) in order to make METRIX show them both (not only the current program description)?
I mean... :)
cheers
I'm using MyMetrix on BH 2.0.9.1 in conjunction with Cool TV Guide and it is working fine on my Vu+ Uno. Must say it's an excellent combination. the only issue I have is that when in EPG the background colour of any highlighted program is white and the foreground yellow making it impossible to read. I have played around with Mymetrix and Cool TV guide and cannot change it.
Mymetrix is a program that allows you to create a skin. You take seperate components that make up the skin i.e. what font you want, do you want to display weather info, what colour do you want text to be, what style (from a selection) you want the information line etc etc them Mymetrix compiles these into a current skin format.
I confirm the problem. No matter what type of skinning I choose in cool tv currently selected field is unreadable.
Wysłane z komórki
Please Help.
at bottom on the info bar picos are showing poor quality because picot window is bigger than other skins. how do you get around it?
