MyMetrix-OpenStore BH 2.0.x
on my vu+solo2 with bh 2.0.7c works everything.....great skin and without lags or crashes till now but testing is going on and on....thanks capa
Hi capa,
wenn ich Grün und dann blau button drücke kommt es zum GS.
when I press green and then blue button it comes on the GS.
Hi capa,
download latest file, I gave you link to last PN. In this version your problem is fixed...
On my solo2 with 2.0.7 no GS....all ok
I just noticed that in the list of records the written descriptions are cut off at the bottom
If someone is using Duo(1) or Solo(1) there should be activated SWAP File for correct working
@trocche , I'll check this today evening
