MyMetrix-OpenStore BH 2.0.x
Changelog: -->> INFO
Update 16.11.13 -
- add CrossEPG
- add RunningText (in Channelselection & EPG Panel)
- fixed connecting and ***-start message
- add ****Imfo Widget
- fixed Channelselection buttons
hi ! capa !
can you add french language for menu . Thanks
Hello,
first I'd like to thank the developer (cappa?) for his work, it seems to be a beautiful skin. Currently its not supported on my duo2. I'm going to follow this thread for updates.
Thanks
vsnap
Hello,
Thanks
vsnap
1. Hi, thank you but the skin Developer is @iMaxx from VTi Forum.
2. This Skin runs of course on your vu duo2 too.
HI Cappa,
thanks for the reply. Nevertheless, thanks for your support.
The stange thing is, that I'm on the latest Version of BH and MyMetrix. It still says "Sorry this skin is not compatible with the current Black Hole image version."
Looks like I need to investigate some further...
regards
vsnap
HI Cappa,
regards
vsnap
HI Cappa,
regards
vsnap
This is a BlackHole compatible version and will be available on BH Addon server soon
Gesendet von meinem iPhone mit Tapatalk
Good surprise! Finally, a compromise :kiss:
Everything is working, all BH functions and fully MyMetrix plugin with OpenStore.
But be careful with SkinParts from OpenStore. Some of them are only for PLi and VTi Image.
Dont wonder if some of them won't work
Thank you for this precaution is better to wait and can download from the BH server.
thank you capa
MyMetrix OpenStore 2.0.14 - BlackHole 2.x.x
!!! DOWNLOAD FROM BlackHole ADDON SERVER !!!
Changelog:
18.11.13 -
- personalized BH widgets (will not overwrite if you download from OpenStore)
- fixed Display Output
- fixed CrossEPG Provider Panel
- fixed Samba Panel
- fixed CamInfo.py
- fixed NextEvent.py
17.11.13 -
- add AMS Skin Parts BH(AdvancedMovieSelection Plugin)
- add TMDb Info for AMS (need TMDb Plugin )
- add TheTVDB for AMS
16.11.13 -
- add CrossEPG
- add ***Imfo Widget
14.11.13
- fixed several GS
- added missing Converter
- added mission png's
- fixed SecondInfoBar
- completed MetrixHD uninstall File
13.11.13
- Update to OpenStore-MyMetrix 2.0.14 full. include OpenStore Plugin
