Navi x
Maybe you're missing something on winscp. When you open winscp, click Tools and choose Preferences. Then from the opened window click on Panels and right on top you will find Show Hidden Files. Just tick it and down below click on OK. That's all. Go back and login and you will have Hidden Files shown on your Winscp.
Clould be also that for some reason my .xbmc is corrupted?
If your /.xbmc is corrupted ... no problem ... you found it?
1) - If so ... just delete it.
2) - Open XBMC Launcher it will create a new and clean /.xbmc folder for you.
Upon this you can use it to upload your files.
As you can see no xbmc folders..
It seems you have a SOLO SEV2, right?
So, in this case you have an external HDD.
1) - You have to start from the beginning for handling XBMC on your HDD.
2) - If you have launched for the first time XBMC without the HDD connected to your STB ... you must have a /.xbmc folder in your /home/root folder
  • the trace complete is --> /home/root/.xbmc
You have to delete this folder if exists.
3) - POWER OFF your STB. and don´t start XBMC Launcher for now.
4) - Connect your HDD to your STB, if not connected.
5) - POWER ON your STB and don´t start XBMC Launcher for now, after booting.
6) - Verify if your HDD is detected and if is mounted as /media/hdd.
7) - If the HDD it is corrected mounted ... take a look on /media/hdd if you have /.xbmc folder and proceed to 10)-
8) - If not mount your HDD as /media/hdd in devices manager.
9) - Go to point 7)
10)- Delete the /.xbmc folder and restart your STB.
11)- Upon your STB is restarted go go plugins and Launch XMBC Launcher ... the /.xbmc folder on your /media/hdd should be created and ready to upload your addons.
Woww ;) yes i have a solo se v2! I have a nas connected to deco where I record and download epg. So u can confirm that's right way to proceed ? Thanks!!
This is my mount by now, external ethernet nas. It's ok? Or i have to do something more?
Only now you said that your HDD is a NAS!
Everything i told you, was said for local HDD ... not for a Network HDD. Think it´s not possible do that. You have to attach a device to handle XBMC to your STB mapped as /media/hdd. ( minimal a USB pen drive or a second HDD ( usb with external power ))
Could u please remember how I can map? Sorry and thanks.. Previous step done all.. Just waiting to map unit
I installed script.zip in media/hdd/.xbmc. File is present and transferred ok. I opened xbmc in blackhole 3.1 vuduo2, looked in video addons navi-x is not there. Any help appreciated
