nuovo cfe vu+ solo
ecco l'output
BCM73250010
012
K1
K2
K3
K4
K5
Shmoo Version=3.6
DDR Freq=0x0000018E
%00000001%
RC1=00000005
WC1=FFFFFFF2
RC2=00000019
WC2=00000045
RC3=0000000F
WC3=FFFFFFF2
RC4=0000000F
WC4=00000045
NWC=0000001B
RC5=00000005
WC5=0000001B
RC6=00000019
WC6=0000001B
NRC=0000000F
RW=00000015
WW=00000054
G=00000000 R=0000000F W=0000001B
BL=00000000
RC1=00000005
RC2=0000001F
BL=00000001
RC1=00000005
RC2=0000001F
BL=00000002
RC1=00000003
RC2=0000001F
BL=00000003
RC1=00000001
RC2=00000019
3
COPY CODE
AS567
CP16=80040483,BEA3519F,80000167
BCM97325B0 CFE v2.27, CFE core v2.12, Endian Mode: Little
Build Date: Wed May 18 10:18:50    2011 (shcheong@ncsh)
Copyright (C) Broadcom Corporation.
DDR Freq:      398MHz
CPU speed:    333MHz
Memory Config: 32-bit UMA
Device Tech:  1Gb
Total memory:  256MB
Total flash:  128MB
Initializing USB.
USB: Locating Class 09 Vendor 0000 Product 0000: USB Hub
CFE initialized.
checking usb
Loader:elf Filesys:raw Dev:flash0.kernel File: Options:rootfstype=jffs2 root=/de
v/mtdblock0 rw mem=0x8000000
Loading: 0x80001000/3403928 0x80340098/135028 Entry address is 0x80322000
Starting program at 0x80322000
<5>Linux version 2.6.18-7.3 (linux@wheezy) (gcc version 4.4.3 (GCC) ) #1 Sat Oct
8 15:33:52 CEST 2011
Fetching vars from bootloader... OK (E,d,B,C)
board_init_once: regval=23440802, ddr0_strap=2, , ddr1_strap=2, pci_size=0
Detected 128 & 128 MB on board, total 256 MB
CFE EnvVar: LINUX_FFS_STARTAD: 00000000, LINUX_FFS_SIZE: 07400000
CFE EnvVar: LINUX_PART_STARTAD: 07400000, LINUX_PART_SIZE: 00400000
g_board_RAM_size=256MB
Options: sata=0 enet=1 emac_1=0 no_mdio=0 docsis=0 ebi_war=0 pci=1 smp=0
CPU revision is: 0101954c
FPU revision is: 01739300
Determined physical RAM map:
memory: 10000000 @ 00000000 (usable)
User-defined physical RAM map:
node [00000000, 07000000: RAM]
node [07000000, 09000000: RSVD]
<5>Reserving 144 MB upper memory starting at 07000000
<7>On node 0 totalpages: 65536
<7>  DMA zone: 65536 pages, LIFO batch:15
Built 1 zonelists.  Total pages: 65536
<5>Kernel command line: rootfstype=jffs2 root=/dev/mtdblock0 rw mem=0x8000000  c
onsole=ttyS0,115200
Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, linesize 32 bytes.
MIPS secondary cache 128kB, 8-way, linesize 128 bytes.
SCM configuration: 00fac688 41d4d617 00f07100 8fff0d00 81ff0100 0fff0fff
Synthesized TLB refill handler (20 instructions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
Cache parity protection disabled
timer irq 100
PID hash table entries: 2048 (order: 11, 8192 bytes)
Found MIPS counter frequency: 167 Mhz
Using 166.501 MHz high precision timer.
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 108800k/262144k available (2659k kernel code, 153176k reserved, 541k dat
a, 124k init, 0k highmem)
Mount-cache hash table entries: 512
Checking for 'wait' instruction...  available.
NET: Registered protocol family 16
PCI->SDRAM window size: 512MB
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 8192 bind 4096)
TCP reno registered
brcm-pm: disabling power to USB block
brcm-pm: disabling power to ENET block
JFFS2 version 2.2. (NAND) (SUMMARY)  (C) 2001-2006 Red Hat, Inc.
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered (default)
Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0x0 (irq = 22) is a 16550A
brcm-pm: enabling power to ENET block
Broadcom BCM7325 P20 Ethernet Network Device v2.0 Oct  8 2011 15:33:16
Config Internal PHY Through MDIO: Auto-negotiation timed-out
: 10 MB Half-Duplex (assumed)
Broadcom STB NAND controller (BrcmNand Controller)
i=0, CS[0] = 0
NAND_CS_NAND_XOR=00000001
brcmnand_probe: CS0: dev_id=ecf18015
After: NandSelect=40000101, nandConfig=55042200
NAND Config: Reg=55042200, chipSize=128 MB, blockSize=128K, erase_shift=11
busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
BrcmNAND mfg ec f1 Samsung K9F1G08U0A 128MB
Found NAND: ACC=d3000000, cfg=55042200, flashId=ecf18015, tim1=4232222d, tim2=00
000d94
BrcmNAND version = 0x0200 128MB @00000000
Found NAND chip on Chip Select 0, chipSize=128MB, usable size=128MB, base=0x
brcmnand_scan: B4 nand_select = 40000101
brcmnand_scan: After nand_select = 40000101
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
Brcm NAND controller version = 2.0 NAND flash size 128MB @18000000
mtd->oobsize=64, mtd->eccOobSize=16
brcmnand_scan:  mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
brcmnand_default_bbt: bbt_td = bbt_main_descr
brcmnandCET: Status -> Deferred
        numchips=1, size=8000000
Creating 7 MTD partitions on "bcm7xxx-nand.0":
0x0000000000000000-0x0000000007400000 : "rootfs"
0x0000000007400000-0x0000000007800000 : "kernel"
0x0000000007800000-0x0000000007c00000 : "boot"
0x0000000007c00000-0x0000000007d00000 : "cfe"
0x0000000007d00000-0x0000000007d80000 : "mac"
0x0000000007d80000-0x0000000007e00000 : "env"
0x0000000007e00000-0x0000000007f00000 : "nvm"
ehci_hcd_brcm_init: Initializing 2 EHCI controller(s)
brcm-pm: enabling power to USB block
10 Dec 2004 USB 2.0 'Enhanced' Host Controller (EHCI) Driver (EHCI-brcm-0)
drivers/usb/host/ehci-brcm.c: starting brcm EHCI USB Controller
- USB h/w setup mode <B>
- USB power enable set for active HIGH mode
brcm-ehci brcm-ehci.0: BRCM EHCI
brcm-ehci brcm-ehci.0: new USB bus registered, assigned bus number 1
brcm-ehci brcm-ehci.0: irq 62, io mem 0x10480300
brcm-ehci brcm-ehci.0: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
10 Dec 2004 USB 2.0 'Enhanced' Host Controller (EHCI) Driver (EHCI-brcm-1)
brcm-ehci-1 brcm-ehci-1.1: BRCM EHCI
brcm-ehci-1 brcm-ehci-1.1: new USB bus registered, assigned bus number 2
brcm-ehci-1 brcm-ehci-1.1: irq 63, io mem 0x10480500
brcm-ehci-1 brcm-ehci-1.1: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ohci_hcd_brcm_init: Initializing 2 OHCI controller(s)
2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (OHCI-brcm-0)
drivers/usb/host/ohci-brcm.c: starting brcm OHCI USB Controller
- Resetting at b0480408
<-- brcm_start_hc
brcm-ohci-0 brcm-ohci-0.0: BRCM OHCI
brcm-ohci-0 brcm-ohci-0.0: new USB bus registered, assigned bus number 3
brcm-ohci-0 brcm-ohci-0.0: irq 64, io mem 0x10480400
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (OHCI-brcm-1)
- Resetting at b0480608
<-- brcm_start_hc
brcm-ohci-1 brcm-ohci-1.1: BRCM OHCI
brcm-ohci-1 brcm-ohci-1.1: new USB bus registered, assigned bus number 4
brcm-ohci-1 brcm-ohci-1.1: irq 59, io mem 0x10480600
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
pegasus: v0.6.13 (2005/11/13), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new driver pegasus
drivers/usb/net/rtl8150.c: rtl8150 based usb-ethernet driver v0.6.2 (2004/08/27)
usbcore: registered new driver rtl8150
usbcore: registered new driver asix
usbcore: registered new driver cdc_ether
usbcore: registered new driver net1080
usbcore: registered new driver zaurus
usbcore: registered new driver usbserial
drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
usbcore: registered new driver usbserial_generic
drivers/usb/serial/usb-serial.c: USB Serial Driver core
drivers/usb/serial/usb-serial.c: USB Serial support registered for Belkin / Pera
com / GoHubs USB Serial Adapter
usbcore: registered new driver belkin
drivers/usb/serial/belkin_sa.c: USB Belkin Serial converter driver v1.2
drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI USB Seri
al Device
usbcore: registered new driver ftdi_sio
drivers/usb/serial/ftdi_sio.c: v1.4.3:USB FTDI Serial Converters Driver
drivers/usb/serial/usb-serial.c: USB Serial support registered for pl2303
usbcore: registered new driver pl2303
drivers/usb/serial/pl2303.c: Prolific PL2303 USB to serial adaptor driver
TCP bic registered
Bridge firewalling registered
E' davvero interessante come nel tuo box ci sia il CFE aggiornato ...
E come il box stia avviando una immagine a me sconosciuta (unica certezza è che è IMPOSSIBILE che sia una BH) compilata ad inizio ottobre 2011 ... con il vecchio kernel ... come riportato sotto.
e' una vti non black hole , la black hole 1.7 non c'e' verso di metterla cosi come la vti o ogni altra immagine col nuovo kernel/boot
infatti la richiesta nel topic e' nuovo cfe vu solo. vorrei tanto metterla ma non parte....
forse volevi che la installassi e poi postassi il log di hyperterminal?
cosi non puoi capire che cfe monta ora?
Se leggi attentamente il mio precedente post ti ho scritto che il tuo CFE è già aggiornato!
Prova con una BH (1.6.7) e vediamo che cosa ti dice hyperterminal.
BCM73250010
012
K1
K2
K3
K4
K5
Shmoo Version=3.6
DDR Freq=0x0000018E
%00000001%
RC1=00000005
WC1=FFFFFFF2
RC2=00000019
WC2=00000042
RC3=0000000F
WC3=FFFFFFF2
RC4=0000000F
WC4=00000043
NWC=0000001A
RC5=00000005
WC5=0000001A
RC6=00000019
WC6=0000001A
NRC=0000000F
RW=00000015
WW=00000052
G=00000000 R=0000000F W=0000001A
BL=00000000
RC1=00000005
RC2=0000001F
BL=00000001
RC1=00000005
RC2=0000001F
BL=00000002
RC1=00000004
RC2=0000001B
BL=00000003
RC1=00000001
RC2=00000019
3
COPY CODE
AS567
DDR Freq:      398MHz
CPU speed:    333MHz
Device Tech:  1Gb
Total memory:  256MB
Total flash:  128MB
Initializing USB.
CFE initialized.
checking usb
Loading: 0x80001000/6641640 0x806567e8/117352 Entry address is 0x804e96c0
Starting program at 0x804e96c0
Linux version 3.1.1 (amedeo@localhost.localdomain) (gcc version 4.4.3 (GCC) ) #1
Mon Dec 19 10:48:58 CET 2011
Fetching vars from bootloader... found 7 vars.
Early serial console at MMIO32 0x10400b00 (options '115200n8')
bootconsole [uart0] enabled
Options: sata=0 enet=1 emac_1=0 no_mdio=0 docsis=0 pci=1 smp=0 moca=0 usb=1
Using 256 MB RAM (from straps)
bootconsole [early0] enabled
CPU revision is: 0101954c (MIPS 34Kc)
bmem: adding 144 MB RESERVED region at 112 MB (0x09000000@0x07000000)
Initrd not found or empty - disabling initrd
Zone PFN ranges:
  Normal  0x00000000 -> 0x00010000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
    0: 0x00000000 -> 0x00010000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
Kernel command line: bmem=144M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw ro
otflags=sync
PID hash table entries: 1024 (order: 0, 4096 bytes)
Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Writing ErrCtl register=00800006
Readback ErrCtl register=00800006
L2 cache parity protection enabled
Memory: 105788k/262144k available (5068k kernel code, 156356k reserved, 1196k da
ta, 220k init, 0k highmem)
NR_IRQS:128
Detected MIPS clock frequency: 332 MHz (166.498 MHz counter)
Calibrating delay loop... 220.16 BogoMIPS (lpj=110080)
pid_max: default: 32768 minimum: 301
PCI2.3->SDRAM window: 512 MB
bio: create slab <bio-0> at 0
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource upg
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NTFS driver 2.1.30 [Flags: R/W].
JFFS2 version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
msgmni has been set to 206
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10400b00 (irq = 22) is a 16550A
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x10400b40 (irq = 66) is a 16550A
loop: module loaded
bcmemac: Broadcom STB 10/100 EMAC driver v3.0
bcmemac: registered interface #0 at 0x10080000 as 'eth0' (00:1d:ec:00:05:da)
usbcore: registered new interface driver zd1201
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
brcm-pm: enabling usb clocks
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 62, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 63, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 3
ohci-brcm ohci-brcm.0: irq 64, io mem 0x10480400
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 4
ohci-brcm ohci-brcm.1: irq 59, io mem 0x10480600
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
lirc_dev: IR Remote Control driver registered, major 254
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR LIRC bridge handler initialized
Linux video capture interface: v2.00
Success! Registering the characther device  success with 0
blackhole initialised
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ALSA device list:
  No soundcards found.
TCP cubic registered
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
lib80211: common routines for IEEE802.11 drivers
EBI CS0: setting up NAND flash (primary)
mtd->oobsize=0, mtd->eccOobSize=0
B4: NandSelect=40000101, nandConfig=55042200, chipSelect=0
brcmnand_read_id: CS0: dev_id=ecf18015
Block size=00020000, erase shift=17
BrcmNAND mfg ec f1 Samsung K9F1G08U0A 128MB on CS0
Found NAND on CS0: ACC=d3000000, cfg=55042200, flashId=ecf18015, tim1=4232222d,
tim2=00000d94
Found NAND flash on Chip Select 0, chipSize=128MB, usable size=128MB, base=0
ECC layout=brcmnand_oob_bch4_4k
-->brcmnand_default_bbt
Creating 7 MTD partitions on "brcmnand.0":
0x000000000000-0x000007400000 : "rootfs"
0x000007400000-0x000007800000 : "kernel"
0x000007800000-0x000007c00000 : "boot"
0x000007c00000-0x000007d00000 : "cfe"
0x000007d00000-0x000007d80000 : "mac"
0x000007d80000-0x000007e00000 : "env"
0x000007e00000-0x000007f00000 : "nvm"
UBI: attaching mtd0 to ubi0
UBI: physical eraseblock size:  131072 bytes (128 KiB)
UBI: logical eraseblock size:    126976 bytes
UBI: smallest flash I/O unit:    2048
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
UBI: max. sequence number:      0
UBI: volume 0 ("rootfs") re-sized from 473 to 915 LEBs
UBI: attached mtd0 to ubi0
UBI: MTD device name:            "rootfs"
UBI: MTD device size:            116 MiB
UBI: number of good PEBs:        928
UBI: number of bad PEBs:        0
UBI: number of corrupted PEBs:  0
UBI: max. allowed volumes:      128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:    1
UBI: available PEBs:            0
UBI: total number of reserved PEBs: 928
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 1/0
UBI: image sequence number:  1488497074
UBIFS: parse sync
UBI: background thread "ubi_bgt0d" started, PID 36
UBIFS: start fixing up free space
UBIFS: free space fixup complete
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size:  114786304 bytes (112096 KiB, 109 MiB, 904 LEBs)
UBIFS: journal size:      9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format:      w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root:  0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:12.
Freeing unused kernel memory: 220k freed
mount: mounting sysfs on /sys failed: Device or resource busy
procmk_init
dvb_bcm7325: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (vusolo)
bcm7335: hotplug_callback():
Hotplug - status.connected 0
CPU 0 Unable to handle kernel paging request at virtual address c070a070, epc ==
c070a070, ra == 80060844
Oops[#1]:
Cpu 0
$ 0  : 00000000 0040ff64 c070a070 00000000
$ 4  : 0000000d c0aee1b4 00020000 00000001
$ 8  : 11008400 1000001f 81200000 0000000c
$12  : 00000010 8061de3c 0000000f 810ab054
$16  : 86418100 00010000 00000000 00000000
$20  : 00000001 0000000d 00000002 805f4460
$24  : 8061de3c 8061de5c
$28  : 86ff4000 86ff5c10 00010000 80060844
Hi    : 00000002
Lo    : 39ce73d9
epc  : c070a070 0xc070a070
    Tainted: P
ra    : 80060844 handle_irq_event_percpu+0x5c/0x280
Status: 11008002    KERNEL EXL
Cause : 10800008
BadVA : c070a070
PrId  : 0101954c (MIPS 34Kc)
Modules linked in: procmk
Process modprobe (pid: 54, threadinfo=86ff4000, task=86fee998, tls=770b1490)
Stack : 13d9451a 0000000f 13d9451a 0000000f 00000000 0000000f 805f4460 00010000
        00000020 00000000 00000002 b0001408 b0001410 b0001404 b000140c 80060aa0
        00000001 00000068 00000002 805f6ac4 805f4460 80063830 86ff5c68 86ff5c68
        00000000 80663240 00000000 00000000 00000001 80060408 0000000a 80660000
        805f1f14 806630c4 00000000 80005818 b000140c 800634ac 00000000 806630c8
Call Trace:
[<80060aa0>] handle_irq_event+0x38/0x5c
[<80063830>] handle_level_irq+0x98/0x118
[<80060408>] generic_handle_irq+0x44/0x64
[<80005818>] do_IRQ+0x18/0x24
[<800634ac>] handle_percpu_irq+0x58/0x8c
[<800022b8>] plat_irq_dispatch+0x118/0x1e0
[<80003f6c>] ret_from_irq+0x0/0x4
[<8000225c>] plat_irq_dispatch+0xbc/0x1e0
[<8006f31c>] free_hot_cold_page+0x6c/0x2f0
[<8006f3e4>] free_hot_cold_page+0x134/0x2f0
[<80089c20>] __tlb_remove_page+0x24/0x34
[<80089f88>] unmap_vmas+0x32c/0x610
[<80075e4c>] pagevec_lru_move_fn+0xf8/0x128
[<80094c70>] remove_vm_area+0xb0/0xcc
[<80075f1c>] lru_add_drain+0x90/0xec
[<8008cd14>] unmap_region+0x98/0x12c
[<8008e098>] do_munmap+0x204/0x300
[<8002dd78>] do_softirq+0x68/0x70
[<8008e1d4>] sys_munmap+0x40/0x68
[<8000c5c4>] stack_done+0x20/0x40
Code: (Bad address in epc)
---[ end trace 0562de2393b935c2 ]---
Kernel panic - not syncing: Fatal exception in interrupt
Rebooting in 180 seconds..
ecco qui kernel panic
BCM73250010
012
K1
K2
K3
K4
K5
Shmoo Version=3.6
DDR Freq=0x0000018E
%00000001%
RC1=00000005
WC1=FFFFFFF2
RC2=00000019
WC2=00000042
RC3=0000000F
WC3=FFFFFFF2
RC4=0000000F
WC4=00000043
NWC=0000001A
RC5=00000005
WC5=0000001A
RC6=00000019
WC6=0000001A
NRC=0000000F
RW=00000015
WW=00000052
BL=00000000
RC1=00000005
RC2=0000001F
BL=00000001
RC1=00000005
RC2=0000001F
BL=00000002
RC1=00000004
RC2=0000001B
BL=00000003
RC1=00000001
RC2=00000019
3
COPY CODE
AS567
DDR Freq:      398MHz
CPU speed:    333MHz
Device Tech:  1Gb
Total memory:  256MB
Total flash:  128MB
Initializing USB.
CFE initialized.
checking usb
Zone PFN ranges:
otflags=sync
NR_IRQS:128
TCP reno registered
loop: module loaded
ALSA device list:
tim2=00000d94
UBIFS: parse sync
procmk_init
Oops[#1]:
Cpu 0
Hi    : 00000002
Lo    : 39ce73d9
    Tainted: P
Cause : 10800008
BadVA : c070a070
Call Trace:
Finalmente un errore degno di questo nome.
Prova a riflashare via Vu+Util e cavo seriale (possibilmente SOLO cavo seriale)... vediamo se si riprende...
Prova a riportare anche l'output durante l'operazione di flash ....
ho visto che prende pure il file non nfi ma uno per volta, procedo flashando uno per volta dal boot, poi kernel poi root?
BCM73250010
012
K1
K2
K3
K4
K5
Shmoo Version=3.6
DDR Freq=0x0000018E
%00000001%
RC1=00000005
WC1=FFFFFFF2
RC2=00000019
WC2=00000045
RC3=0000000F
WC3=FFFFFFF2
RC4=0000000F
WC4=00000045
NWC=0000001B
RC5=00000005
WC5=0000001B
RC6=00000019
WC6=0000001B
NRC=0000000F
RW=00000015
WW=00000054
BL=00000000
RC1=00000005
RC2=0000001F
BL=00000001
RC1=00000005
RC2=0000001F
BL=00000002
RC1=00000003
RC2=0000001D
BL=00000003
RC1=00000001
RC2=00000019
3
COPY CODE
AS567
DDR Freq:      398MHz
CPU speed:    333MHz
Device Tech:  1Gb
Total memory:  256MB
Total flash:  128MB
Initializing USB.
CFE initialized.
USB: New device connected to bus 1 hub 1 port 1
USB: Resetting device on bus 1 port 1
USB: Locating Class 08 Vendor 0011 Product 7788: Mass-Storage Device
USBMASS: Unit 0 connected
checking usb
Reading usbdisk0:/vuplus/solo/cfe_cfe_auto.bin:  >> Skipping...: File not found
Reading usbdisk0:/vuplus/solo/root_cfe_auto.jffs2:  >> Done. 62259200 bytes read
Programming...
done. 62259200 bytes written0x20000 done
Reading usbdisk0:/vuplus/solo/boot_cfe_auto.jffs2:  >> Done. 576 bytes read
Programming...
done. 576 bytes written0000 0x20000 done
Reading usbdisk0:/vuplus/solo/kernel_cfe_auto.bin:  >> Done. 3501066 bytes read
Programming...
done. 3501066 bytes written 0x20000 done
please remove usb first and reboot
ecco il log del flash via usb
BCM73250010
012
K1
K2
K3
K4
K5
Shmoo Version=3.6
DDR Freq=0x0000018E
%00000001%
RC1=00000005
WC1=FFFFFFF2
RC2=00000019
WC2=00000045
RC3=0000000F
WC3=FFFFFFF2
RC4=0000000F
WC4=00000045
NWC=0000001B
RC5=00000005
WC5=0000001B
RC6=00000019
WC6=0000001B
NRC=0000000F
RW=00000015
WW=00000054
BL=00000000
RC1=00000005
RC2=0000001F
BL=00000001
RC1=00000005
RC2=0000001F
BL=00000002
RC1=00000003
RC2=0000001D
BL=00000003
RC1=00000001
RC2=00000019
3
COPY CODE
AS567
DDR Freq:      398MHz
CPU speed:    333MHz
Device Tech:  1Gb
Total memory:  256MB
Total flash:  128MB
Initializing USB.
CFE initialized.
checking usb
Programming...
Programming...
Programming...
Ok il flash sembra tutto a posto.... vediamo cosa dice al reboot (sempre dalla seriale)
da lo stesso kernel panic il log
ALSA device list:
tim2=00000d94
UBI: max. sequence number:      72
UBI: max/mean erase counter: 2/0
UBIFS: parse sync
UBIFS: recovery needed
UBIFS: recovery completed
procmk_init
CPU 0 Unable to handle kernel paging request at virtual address c073dd70, epc ==
c073dd70, ra == c073e41c
Oops[#1]:
Cpu 0
$ 0  : 00000000 00000000 00000000 c073dd70
$ 4  : 86403c00 00103000 c073e290 00000000
$ 8  : 11008400 1000001f ffffffff 00000018
$12  : 00000020 8061de68 0000000f 810c9594
$16  : 85554800 00103000 86403c00 8641a800
$20  : 00000000 00000000 c073c748 00000001
$24  : 8061de68 00000000
$28  : 86410000 86411c00 ffffffff c073e41c
Hi    : 00000002
Lo    : 39ce73d9
epc  : c073dd70 0xc073dd70
    Tainted: P
ra    : c073e41c 0xc073e41c
Status: 11008003    KERNEL EXL IE
Cause : 10800008
BadVA : c073dd70
Process modprobe (pid: 54, threadinfo=86410000, task=86fde568, tls=77556490)
Stack : c0701d94 c0701d78 00000001 00000001 00000000 c073dd70 c073d200 c0b0f018
        00000000 c0b03914 0000000d 00000020 00000001 86411c58 c0b03850 00001000
        80061f90 c0709a3c 00000000 00000101 00000001 0000000c 00001000 00000000
        00000000 00000000 00000001 0000000c 00000060 805f4460 805f20b0 80660000
        fffffffe 00010000 805ee700 00000000 805f1f14 806630c4 80571498 8002d4e8
Call Trace:
[<80061f90>] enable_irq+0x0/0x8c
[<8002d4e8>] tasklet_hi_action+0x14c/0x154
[<8002db28>] __do_softirq+0xbc/0x164
[<8001e304>] __wake_up+0x28/0x48
[<8005c834>] module_sect_show+0x0/0x18
[<8006f44c>] free_hot_cold_page+0x19c/0x2f0
[<8006f46c>] free_hot_cold_page+0x1bc/0x2f0
[<80094db0>] __vunmap+0x78/0x11c
[<8004b218>] blocking_notifier_call_chain+0x14/0x20
[<8005e2d0>] sys_init_module+0x250/0x13f4
[<8027e638>] __bzero+0xbc/0x164
---[ end trace 82f3a53e44b60639 ]---
BCM73250010
012
K1
K2
K3
K4
K5
Shmoo Version=3.6
DDR Freq=0x0000018E
%00000001%
RC1=00000006
WC1=FFFFFFF4
RC2=00000019
WC2=00000041
RC3=0000000F
WC3=FFFFFFF4
RC4=0000000F
WC4=00000040
NWC=0000001A
RC5=00000006
WC5=0000001A
RC6=00000018
WC6=0000001A
NRC=0000000F
RW=00000013
WW=0000004D
BL=00000000
RC1=00000006
RC2=0000001F
BL=00000001
RC1=00000005
RC2=0000001F
BL=00000002
RC1=00000004
RC2=0000001B
BL=00000003
RC1=00000001
RC2=00000018
3
COPY CODE
AS567
DDR Freq:      398MHz
CPU speed:    333MHz
Device Tech:  1Gb
Total memory:  256MB
Total flash:  128MB
Initializing USB.
CFE initialized.
checking usb
Zone PFN ranges:
otflags=sync
Writing ErrCtl register=00800000
Readback ErrCtl register=00800000
NR_IRQS:128
Detected MIPS clock frequency: 332 MHz (166.499 MHz counter)
TCP reno registered
loop: module loaded
ALSA device list:
tim2=00000d94
UBI: max. sequence number:      76
UBIFS: parse sync
procmk_init
CPU 0 Unable to handle kernel paging request at virtual address c07e5328, epc ==
c07e5328, ra == c073e474
Oops[#1]:
Cpu 0
$ 0  : 00000000 00000000 85554200 c07e5328
$ 4  : 8554d800 00000000 00000001 001a0340
$ 8  : 11008400 1000001f ffffffff 00000000
$12  : 00000000 00000000 0000000f 810a51d4
$16  : 85553800 00103000 86403c00 86419800
$24  : 8061de10 00000000
$28  : 86410000 86411c00 ffffffff c073e474
Hi    : 00000002
Lo    : 39ce73d9
epc  : c07e5328 0xc07e5328
    Tainted: P
ra    : c073e474 0xc073e474
Cause : 10800008
BadVA : c07e5328
Process modprobe (pid: 54, threadinfo=86410000, task=86fde568, tls=779e5490)
Stack : c0701d94 c0701d78 00000001 00000001 00000041 c073dd70 c073d200 85554200
Call Trace:
---[ end trace 62f0d58f35a7f34d ]---
credo il casotto inizia qui
Oops[#1]:
Cpu 0
Hi    : 00000002
Lo    : 39ce73d9
    Tainted: P
Cause : 10800008
BadVA : c07e5328
Call Trace:
Oops[#1]:
Cpu 0
Hi    : 00000002
Lo    : 39ce73d9
    Tainted: P
Cause : 10800008
BadVA : c07e5328
Call Trace:
Box da sostituire....
azz davvero? ma con l'immagine precedente funziona... uaa che casino
non si puo riformattare le partizioni o cose del genere?
E' un errore particolarmente strano, quando viene inizializzato il core del sistema (con i driver VuPlus).
Puoi provare a fare cosi:
- ricarica il CFE
- riflasha una vecchia immagine
- verifica che parta tutto regolarmente
- flasha una immagine nuova e incrocia le dita
Essendo l'errore riguardante la gestione interna dei dispositivi della CPU, x me può essere che il tuo pezzo abbia qualche problema: purtroppo può capitare :(
fatto rimesso cfe e immagine con kernel vecchio, sto facendo una scansione canalie il resto dei setup, e' come se il kernel impeigando la ram in modo diverso andasse in errore o forse solo basta riformattare le partizioni se solo sapessi come si fa...non te nlo dico come rosico perche prorpio tonno non sono e sarei voluto venirne a capo . provero almeno a meterci su i nuovi drivers mi pare siano usciti poi dopo il weekend vedo che mi propongono. tienimi aggiornato se ti viene in mente un altra cosa. non posso comunque che ringraziarti per l'assistenza. vediamo che accade... sob
se puo essere di ulteriore aiuto il mio è un solo col telecomando bianco, credo le prime serie..
