Open Black Hole 0.1 update 19-06-2015 Vu+ Duo2
Hi friends , two questions:
The images in openmultiboot must be original or backup ?
The kernel of the image in openmultiboot must be the same to flash or even newer?
Thanks
1) - The images in openmultiboot must be original or backup ?
Thanks
1) - You can use backups, although we don´t support backups, and other images rather than Open BlackHole or Blackhole.
2) - The advantage of Open Multiboot in comparison with Multiboot, is that Open Multiboot doesn´t Mix Kernels, afaik, you can boot all severeall images, that uses OpenGl.
From my experience:
Blackhole 2.1.5, 2.1.6 and 2.1.7 - Ok
Vti 8.2 and Vti 9.0 - Ok
OpenPli 4.0
OpenAtv 4.2, 5.0 and now 5.1
and others, that you can find in the guide for Open Multiboot -> http://www.vuplus-community.net/board/threads/how-to-use-open-multiboot-on-open-black-hole.23270/ already tested.
i use the BH2.15 and all is cool with it . i wonder if OBH0.1 is a bit faster than BH2.17.1 ? because it is lighter .
i wonder if i can backup my settings and reuse them with OBH ?
when next OBH and BH will be made ..? Xmas is coming...
Backup your settings with an settings editor, you can use dreamboxedit or dreamset for it.
And you can use your settings with no problem with Open Blackhole and now with Blackhole 3.0.1.
You can use too, as you want in Flash or in Open Multiboot.
hallo nunigaia,
If you have information after the updating of the black hole there is an update for the open?
No... Until yesterday, there´s no update for Open Blackhole, maybe in the next few days ..., although you can try on your Duo2, Blackhole 3.0.1 in flash and Open Blackhole 0.1 in Open Multiboot.
i would prefer to get Blackhole or Open Blackhole in a compilation that is not online update-able...and more info about Open Multiboot.
i mean : can i install Open Blackhole in the vu+ memory and boot the full Blackhole image that would be on usb ?
Enable autostart at startup by pressing yellow key.
Abilitare l'avvio automatico all'avvio premendo il tasto giallo.
La voce ''avvio automatico'' non esiste nella ''open'' e non ci sono altre opzioni, l'unica è quella di creare lo swap fino ad un massimo di 250mb.
Una volta creato, non si sa se poi è stato creato, e la sua dimensione.
Non ci sono opzioni per gestire tale swap.
Poi se riavii il decoder lo swap sparisce.
i wonder if supermassimo200 is coming from future or me....because my clock says 7.39 am satuday 12 december but the board write "supermassimo200,Sunday at 8:44 AM" on the above of my post.....where are the Xfiles fbi Heros Mulder and Scully
or may be he wrote it the last sunday 6...?
that should be that...
If you put the mouse in the date/time you should see the date..... i't's the past sunday, 6/12 ...
Hello All,
This new image sounds fantastic. Is their a guide I can follow to get this installed on my Duo2?
Thanks,
Tony
