Open Black Hole 0.6 skins download
in the image openblackhole 0.6 I can not change themes, maglré the download MX X7, this theme is not displayed in the list, only the theme is displayed by default
please help me
please help me
If you managed to download the skin from the server and your box flash is not full then the skin must be in the list.
I installed the image open blackhole 0.6 in multiboot,
I download the skin MX X7 from the server. I use parameter / system / panel front / only the skin default on the list.
Installed skin you can find and use from Main Menu >> Setup>>System>>User interface>>Skin
Why it isn't possible to install MyMetrixLite on MetrixFHD?
Or, if really not, is there a customizable (font, colours, data) skin the same way Metrix is?
I like the idea Metrix could be connected with the open-store that allows you to upgrade customizations
Check:
<Menu>; <Plugins>; <Dowload Plugins>; <Skins>;
Drop down on list ... and verify the skins names list.
Note: We don´t support Metrix skins, i´ve not tested but the skins are there. Is up to you to use it, or not.
Ok, done it, but it doesn't work fluently like the Matrix10's skins do in general. And more, openstore doesn't allow me to register as a new member. So... MyMetrix experience was shorter then few minutes. Back now to the best skin ever. I'm talking about MX-HQ9W obviously ;-)
Anyway I still consider that there are maybe hundreds of skins for all the e2 images, but mainly they are BLACK or BLUE.
I'm not able to design, and not at all a skin. But i.e. look at this GREENskin I've just photoshopped.
I would ask Matrix10 if he/she is interested in experimenting this kind of design once.
MX-HQ9W is, without any doubts, my favourite, too, as Nunigaia already knows. Only, in OBH, for reasons I don't know, the Multigraphic EPG hasn't the same readibilty as in BH because the selected event in the timeline is of a very dark blue, too much similar to the black of the background.
In BH, instead, the selected event is of a standard blue, much easily distiguished from black.
View attachment 29312 View attachment 29313 View attachment 29314
The skin ( your screen shot ) is not only green, has lot of transparency ... When you have subtitlesbehind the skiin, you can´t read the information you got in infobar ... it´s a lot of confusion and not easy readable.
But this is my opinion. :)
I had fun for hours trying all possible colours and setup on KRAVENHD skin plugin.
Ok. It was funny.
Now, back to my HQ9W ;-)
Hello Matrix10 .
when i start media player with your skin i can get Movie info and more, But not whitch channel its recorded from , i get that with vix skin thats are in open black hole but not your skin .
is there any way to add this in skin.xml so i can see in media player whitch channel the Movie is recorded from.
Regards
Seth_72
PUOI consigliarmi una imaggine che va bene sul vu ultimo 4k grazie
Se, per "immagine" intendi proprio il software e non la Skin, allora:
1. Perché ti agganci a dei thread che non c'entrano nulla? Hai postato anche altrove dove si parlava di visualizzazione delle lettere dei tuner.
2. Le immagini le trovi nelle apposite sezioni di questo forum e sicuramente non crashano così, tanto per crashare; non in senso generico e generale. Bisognerebbe che dicessi come e quando crashano a te.
