Open Black Hole 0.6 skins download
OBH server download.
MX Titanium C for Open Black Hole 0.6 image
MX Titanium for Open Black Hole 0.6 image updated.
Both of the skin slow down for 4-6 seconds on the motor when switching from one satellite to another.With diseq switches no problem.
I'll start to believe that skin has brakes for the motor. :D
Or is it the other way around ?
Why the plugins Icons appear in different sizes in Green Panel, but normal looking in Plugin browser, with ALL FHD skins ???
The problem was solved.Delete all skins except the standard.Downloaded now Titanium works C. without braking.
CRASH
Skin] SKIN ERROR in screen 'Setup' widget 'widget': {MX_Titanium_C/skin.xml}: component with name 'HelpWindow' was not found in skin of screen 'Setup'!. Please contact the skin's author!
< 17856.791> [Skin] SKIN ERROR in screen 'Setup' widget 'widget': {MX_Titanium_C/skin.xml}: component with name 'footnote' was not found in skin of screen 'Setup'!. Please contact the skin's author!
CRASH
Crash in which panel / window. In setup ???
How did you get crash ???
