Open Black Hole Vu+ Duo2 0.1
how or where do i :
3) - Map if not yet Mapped the Usb pendrive as /media/usb
Because after i plug off the pendrive, the icon´s are gone away.
how or where do i :
3) - Map if not yet Mapped the Usb pendrive as /usb/media
Ok ... Let´s help to map a USB PENDRIVE that is not mapped!
1) - Use a new ( formated USB pen to FAT32 ) <---- you can do this on your pc:
see this screenshot: ( Windows 7 ):
Make your screen parameters look like this one --> Click Start to Format your USB Pen Drive! Click OK ---> You´ll get a message " Format Complete "
Eject The USB Pen to remove it Safely
Remove the USB Pen and put it on your STB.
You´ll get a msg " No displayable files on this media found "
2) - Let´s Map the USB pen drive to support your picon files.
Press MENU on your RCU ( remote control unit )
Choose Black hole App's
Choose Device Manager ( next screenshot )
Press Ok on devices Manager to get this screen:
Press RED Key and get the next screenshot:
Make the screen change with your RCU ( remote control unit ) to fit like this: ( next screen ):
On YES ---> Press ok to reboot your STB
Upon rebooting it ---> Your USB Pendrive must be mapped.
GOOD JOB!
Note: You can verify this by Press Menu --> Select Black Hole App´s --> Device Manager.
thanks nunigaia for your instruction, i did it your way, but nothing chanced, after plug off the USB Stick, the Log´s are gone :-). i checked it at Device Manager the USB Stick is mapped as media usb.
thanks nunigaia for your instruction, i did it your way, but nothing chanced, after plug off the USB Stick, the Log´s are gone :). i checked it at Device Manager the USB Stick is mapped as media usb.
Now tom001
You have your USB mapped as /media/usb
Do This:
Go here ---> http://www.vuplus-community.net/board/threads/open-black-hole-vu-duo2-0-1.22909/page-4#post-174646
Follow steps 5 e 6.
Reboot, you´ll have your picons installed and working for Astra 19.2 East!.
Test and reply, i am here to help not to do it for you! :victory:
yes, it´s mapped as /media/usb!
Ok, --> Do now the next steps.
follow now what i said on post http://www.vuplus-community.net/board/threads/open-black-hole-vu-duo2-0-1.22909/page-5#post-174768
I´ve corrected the previous posts dued to file locations ---> it must be /media/usb
when you download the picons i said it will create the directory /media/usb/picon, and the picons png files are there!
reboot the box as i said, you´ll have picons on channelinfo and channellist.
yes they are there, but when i unplug the usb Stick, the icon´s are gone, that´s my problem or is that the way it works, only with the usb stick?
Note: If they are there --> you must leave the usb pendrive " ALLWAYS " connected to your STB ( and mapped ), only take it off when you want upgrade or remount a new or backup firmware ( image ). To make it ( install or remount the firmware ), use a new pendrive, or make a backup of your picons files to your PC.
Thank you for Romanian language!!!!
I'm looking for CRON MANAGER, FULL BACKUP and PERSONAL BACKUP in this image....
Open Black Hole 0.1
Main Features:
  • Full Hd skin (1920x1080)
  • HbbTv
  • Open GLes animations (Duo2, Solo2, SoloSE)
  • Xbmc (Duo2, Solo2, SoloSE)
Black Hole:
  • Blue panel
  • Green Panel
  • Extra Settings
  • Addons panel
  • Compatible with Pli plugins and Skins
What is Open Black Hole ?
It is an exciting new project from the same team that produce the Black Hole images.
This new project is based on the PLi git and coding infrastructure, which means it is not only Open Source, but it is also compatible with all PLi plugins, feeds and skins and it also features full online update support (for those users that do not like having to do a full reflash everytime there is an image update). We have just given it the Black Hole touch.
This means it has the Green Panel and Blue Panels as found in the standard Black Hole images, we have also added the Black Hole addons panel and included Full HD skin support, OpenGLes Animations and of course included Xbmc .
As with the standard Black Hole images, we continue to support Genuine Vu+ Boxes only and therefore our images are optimised for Vu+ boxes and will only work on these models (any Open Black Hole, or Black Hole images you see on the internet for other box models or clone models are not official images and we offer no support for those boxes or images).
Do I have to upgrade to this new Open Black Hole image ?
No you don't have to upgrade to the new Open Black Hole image, this image is completely separate from the original Black Hole image, this is simply a new image so we can offer our users more choice, if you are happy with your current image, then you can continue to use that image, if you want to try the new Open Black Hole image then you can do so.
What about the Black Hole and Black Hole Prism Images ?
For those of you worried about the standard Black Hole and Prismcube image, please don’t worry, we remain committed to the standard Black Hole and Black Hole Prism images and image updates will continue as normal, this new Open Black Hole image is an additional project and we are fully committed to all images.
Where can I find the Open Black Hole git ?
The Open Black Hole git is located here: http://git.vuplus-community.net
DISCLAIMER​
THE OPEN BLACK HOLE IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.​
THE OPEN BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.​
thanks to all involved for all your hard work.
Today I Tried Once Again to Install Permanent-Time-Shift plugin in OBH, and my Duo2 gone crashed & never start normal, kept on restarting until I Re-Installed OBH in Flash. I Preffered to have Permanent-Time-Shift In BAR SHAPE not In NUMERICAL SHAPE
The problem is into the PTS plugin.
Hi,
I also had the same problem tried twice, locked the system down at boot. Also tried the : "Permanentclock" in downloadable plugins, this does the same again I tried twice, each time it locked the system at boot. The only way to start is to re flash, various weather programs do not work or are mainly usable in Germany or Italy with very little options for the UK. I have noticed on other VU flashes "
Does any test these recommended downloads, I have spent so much time trying to set this OS up I could have built 7/8 PC's.
The OS looks good but be very carful on extras!!
Today I Tried Once Again to Install Permanent-Time-Shift plugin in OBH, and my Duo2 gone crashed & never start normal, kept on restarting until I Re-Installed OBH in Flash. I Preffered to have Permanent-Time-Shift In BAR SHAPE not In NUMERICAL SHAPE[/QUOTE
