Open Black Hole Vu+ Solo2 0.1
Well, thank you team for this excellent work.
I'm trying this in meoboot and is running ok! Just a small thing, about openvpn
I had to reinstall it to make it work, also there's some issues on reboot. It seems to be working but no tun device is created. Restarting by CLI solves the issue, but not by remote.
Don't know if this helps and remember, tested in meoboot.
Just re-installed my BH 2.1.6.1 backup which is more compatible with my preferences. Good to have multiple choice of Images though.
How can locate drivers for my DVB-T Usb stick Nilox N20 AF9035 Chip (Work with normal BH)
dmseg
root@vusolo2:~# dmesg
ehci-brcm ehci-brcm.0: irq 69, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 70, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ehci-brcm ehci-brcm.2: Broadcom STB EHCI
ehci-brcm ehci-brcm.2: new USB bus registered, assigned bus number 3
ehci-brcm ehci-brcm.2: irq 74, io mem 0x10490300
ehci-brcm ehci-brcm.2: USB 0.0 started, EHCI 1.00
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
ehci-brcm ehci-brcm.3: Broadcom STB EHCI
ehci-brcm ehci-brcm.3: new USB bus registered, assigned bus number 4
ehci-brcm ehci-brcm.3: irq 75, io mem 0x10490500
ehci-brcm ehci-brcm.3: USB 0.0 started, EHCI 1.00
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 5
ohci-brcm ohci-brcm.0: irq 71, io mem 0x10480400
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 1 port detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 6
ohci-brcm ohci-brcm.1: irq 72, io mem 0x10480600
ata2: SATA link down (SStatus 0 SControl 300)
hub 6-0:1.0: USB hub found
hub 6-0:1.0: 1 port detected
ohci-brcm ohci-brcm.2: Broadcom STB OHCI
ohci-brcm ohci-brcm.2: new USB bus registered, assigned bus number 7
ohci-brcm ohci-brcm.2: irq 76, io mem 0x10490400
usb 1-1: new high-speed USB device number 2 using ehci-brcm
hub 7-0:1.0: USB hub found
hub 7-0:1.0: 1 port detected
ohci-brcm ohci-brcm.3: Broadcom STB OHCI
ohci-brcm ohci-brcm.3: new USB bus registered, assigned bus number 8
ohci-brcm ohci-brcm.3: irq 77, io mem 0x10490600
hub 8-0:1.0: USB hub found
hub 8-0:1.0: 1 port detected
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR SANYO protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
usbcore: registered new interface driver btusb
Bluetooth: Generic Bluetooth SDIO driver ver 0.1
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
hidraw: raw HID events driver (C) Jiri Kosina
input: Afa Technologies Inc. AF9035A USB Device as /devices/platform/e
/usb1/1-1/1-1:1.1/input/input0
hid-generic 0003:15A4:1001.0001: input,hidraw0: USB HID v1.01 Keyboard
nologies Inc. AF9035A USB Device] on usb-ehci_hcd-1/input1
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP: cubic registered
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
Key type dns_resolver registered
PM: CP0 COUNT/COMPARE frequency does not depend on divisor
EBI CS0: setting up NAND flash (primary)
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB
t)
NAND device: 256MiB, SLC, page size: 2048, OOB size: 64
brcmnand brcmnand.0: 256MiB total, 128KiB blocks, 2KiB pages, 16B OOB,
mming ECC
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
nand_read_bbt: bad block at 0x0000012a0000
nand_read_bbt: bad block at 0x000008fc0000
nand_read_bbt: bad block at 0x00000ce80000
nand_read_bbt: bad block at 0x00000cea0000
nand_read_bbt: bad block at 0x00000f480000
Creating 4 MTD partitions on "brcmnand.0":
0x000001f00000-0x000010000000 : "rootfs"
0x000001f00000-0x000010000000 : "rootfs(redundant)"
0x000000200000-0x000000900000 : "kernel"
0x000000900000-0x000000a00000 : "mac"
UBI: attaching mtd0 to ubi0
random: nonblocking pool is initialized
usb 2-1: new high-speed USB device number 2 using ehci-brcm
usb-storage 2-1:1.0: USB Mass Storage device detected
scsi2 : usb-storage 2-1:1.0
UBI: scanning is finished
UBI: attached mtd0 (name "rootfs", size 225 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 1792, bad PEBs: 8, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 274/171, WL threshold: 4096, image sequen
431808943
UBI: available PEBs: 0, total reserved PEBs: 1792, PEBs reserved for b
dling: 32
UBI: background thread "ubi_bgt0d" started, PID 55
ALSA device list:
No soundcards found.
UBIFS: parse sync
UBIFS: background thread "ubifs_bgt0_0" started, PID 58
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 204
48 bytes
UBIFS: FS size: 221573120 bytes (211 MiB, 1745 LEBs), journal size 902
(8 MiB, 72 LEBs)
UBIFS: reserved for root: 0 bytes (0 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID 91DCF2BB-9183-4016-
D0A32F3, small LPT model
VFS: Mounted root (ubifs filesystem) on device 0:12.
devtmpfs: mounted
Freeing unused kernel memory: 216K (807ea000 - 80820000)
scsi 2:0:0:0: Direct-Access Generic Flash Disk 8.07 PQ: 0 A
sd 2:0:0:0: [sda] 7886848 512-byte logical blocks: (4.03 GB/3.76 GiB)
sd 2:0:0:0: [sda] Write Protect is off
sd 2:0:0:0: [sda] Mode Sense: 03 00 00 00
sd 2:0:0:0: [sda] No Caching mode page found
sd 2:0:0:0: [sda] Assuming drive cache: write through
sd 2:0:0:0: Attached scsi generic sg0 type 0
sda: sda1
sd 2:0:0:0: [sda] Attached SCSI removable disk
usb 1-1: dvb_usb_af9035: prechip_version=00 chip_version=03 chip_type=
usb 1-1: dvb_usb_v2: found a 'Afatech AF9035 reference design' in cold
usb 1-1: dvb_usb_v2: downloading firmware from file 'dvb-usb-af9035-02
EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null
usb 1-1: dvb_usb_af9035: firmware version=12.13.15.0
usb 1-1: dvb_usb_v2: found a 'Afatech AF9035 reference design' in warm
usb 1-1: dvb_usb_v2: will pass the complete MPEG2 transport stream to
re demuxer
DVB: registering new adapter (Afatech AF9035 reference design)
DVB: Unable to find symbol af9033_attach()
usbcore: registered new interface driver dvb_usb_af9035
procmk_init
bcm_event: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (_vuplus_solo2_)
bcm7356: hotplug_callback():
Hotplug - status.connected 1:0:0
Hotplug - connecting HDMI to display 0xe
[GP]:brcm_pwm_init
Hotplug - status.connected 1:1:2
brcm_demux_init: $Id: bcm_demux.c,v 0.7 $
[MPVR]: >> misc_pvr_init
[VID]: ☺6bcm7335_video_init
[AUD]: ☺6bcm7335_audio_init
BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (BCM7346 FE)...
BKNI_P_GetTrackAllocEntry_resize: resizing from 5376->8704
BKNI_Malloc(linuxkernel) top users:
blocks, bytes, filename:line
1024, 176128, portinginterface/hsm/src/common/bhsm.c:500
601, 132308, BSEAV/lib/utils/balloc.c:31
388, 24832, magnum/commonutils/mrc/src/bmrc_monitor.c:666
input: dreambox advanced remote control (native) as /devices/virtual/i
1
[LCD]: registered
0:0
[CI]: registered ci0
[CI]: CI interface initialised
[DFP]: registered dbox fp
[DFP]: Scart 9597 is found 4
[SC]: registered sci0
[SC]: registered sci1
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc4
__clk_enable: network [1]
__clk_enable: enet [1]
bcm40nm_pm_genet_enable 00
bcmgenet bcmgenet.0 eth0: link up, 100 Mbps, full duplex
NET: Registered protocol family 10
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1 0
[VID]: VIDEO_PLAY 1 2 0
[VID]: VIDEO_CONTINUE 1 1
[VID]: VIDEO_CLEAR_BUFFER 1 1 0
[VID]: VIDEO_STOP 0 1
[VID]: VIDEO_SELECT_SOURCE 0 0
[LCD]: unknown cmd 0x1015
UBI error: ubi_open_volume: cannot open device 0, volume 0, error -16
[AUD]: AUDIO_SET_MUTE 0
[AUD]: AUDIO_SET_MIXER -843244048
[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
[AUD]: AUDIO_SET_MIXER : amixl 7, amixr 7
[AUD]: AUDIO_SET_MIXER : next left volume -570, right volume -570
FE tune
[AUD]: AUDIO_SELECT_SOURCE 0
[AUD]: AUDIO_SET_BYPASS_MODE 1
[AUD]: downmix 0 state : 0
[AUD]: AUDIO_PAUSE 6520064
[AUD]: AUDIO_PLAY 6520064 decoder start : 0
[VID]: VIDEO_GET_SIZE src w: 1920 h:1080 display w:1920 h:1080
[VID]: VIDEO_GET_SIZE aspect: 1 1
[VID]: VIDEO_FREEZE 6520064 0
[VID]: VIDEO_PLAY 6520064 2 2
[VID]: VIDEO_SLOWMOTION 0 1
[VID]: VIDEO_FAST_FORWARD 0 1
[VID]: VIDEO_CONTINUE 6520064 1
[AUD]: AUDIO_CONTINUE 6520064 1 aph=0xca025500
[AUD]: Mute : 0
[AUD]: AUDIO_CHANNEL_SELECT 0
Tank you for great job.
I just installed and there are the first impression:
  1. picons autoscale in automatic in infobar and channel list :thanks::thanks:(this function is not supported in normal BH)
  2. the restart of enigma2 is very fast
  3. I don't look when I can install the driver of DTT USB tuner
Tank you in advance
Tank you in advance
3. some drivers are already included but if your DVB-T USB device is not detected, post the debug DVB files (http://www.vuplus-community.net/boa...images-debug-script-per-le-immagini-bh.21512/)
Box Info
Kernel: Linux vusolo2 3.13.5 #1 SMP Tue May 19 09:48:51 CEST 2015 mips GNU/Linux
BH Ver:
USB devices
Bus 001 Device 002: ID 090c:1000
Bus 002 Device 002: ID 07ca:a867
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0002
Bus 003 Device 001: ID 1d6b:0002
Bus 004 Device 001: ID 1d6b:0002
Bus 005 Device 001: ID 1d6b:0001
Bus 006 Device 001: ID 1d6b:0001
Bus 007 Device 001: ID 1d6b:0001
Bus 008 Device 001: ID 1d6b:0001
Kernel Messages
[AUD]: AUDIO_CONTINUE aph=0 0 0
FE tune
dvb_demux_feed_del: feed not in list (type=0 state=0 pid=ffff)
[AUD]: AUDIO_SET_BYPASS_MODE 0
[AUD]: AC3 downmix 0  state : 0
[VID]: VIDEO_SET_STREAMTYPE 1
[VID]: VIDEO_PLAY 6520064  5 2
[AUD]: AUDIO_CONTINUE 6520064 1 aph=0xcc206580
[AUD]: Mute : 0
[VID]: VIDEO_GET_SIZE src w: 0 h:0 display w:0 h:0
[VID]: VIDEO_GET_SIZE aspect: 1 0
[VID]: VIDEO_STOP 1  1
[AUD]: AUDIO_STOP 6520064
[AUD]: AUDIO_CONTINUE 6520064 0 aph=0x0
FE tune
[AUD]: AUDIO_CONTINUE 6520064 1 aph=0xcc207d80
[AUD]: Mute : 0
### XPT_MSG (W2, bit 15) fired 10000 times
FE tune
[AUD]: AUDIO_CONTINUE 6520064 1 aph=0xcc085300
[AUD]: Mute : 0
FE tune
[AUD]: AUDIO_CONTINUE 6520064 1 aph=0xcc260700
[AUD]: Mute : 0
FE tune
[AUD]: AUDIO_CONTINUE 6520064 1 aph=0xcc260500
[AUD]: Mute : 0
[AUD]: AUDIO_SET_MIXER -847389200
[AUD]: AUDIO_SET_MIXER : next left volume -784, right volume -784
[AUD]: AUDIO_SET_MIXER : amixl 10, amixr 10
FE tune
[AUD]: AUDIO_CONTINUE 6520064 1 aph=0xcd7db880
[AUD]: Mute : 0
[AUD]: Mute : 0
FE tune
[AUD]: AUDIO_CONTINUE 6520064 1 aph=0xcc113280
[AUD]: Mute : 0
[AUD]: Mute : 0
FE tune
[AUD]: AUDIO_CONTINUE 6520064 1 aph=0xcc1f7800
[AUD]: Mute : 0
FE tune
[AUD]: AUDIO_CONTINUE 6520064 1 aph=0xcc202e00
[AUD]: Mute : 0
[AUD]: Mute : 0
FE tune
[AUD]: AUDIO_CONTINUE 6520064 1 aph=0xcc1f7c00
[AUD]: Mute : 0
FE tune
[AUD]: AUDIO_CONTINUE 6520064 1 aph=0xcece9c00
[AUD]: Mute : 0
FE tune
[AUD]: AUDIO_CONTINUE 6520064 1 aph=0xcd78d680
[AUD]: Mute : 0
FE tune
[AUD]: AUDIO_CONTINUE 6520064 1 aph=0xcc1daf80
[AUD]: Mute : 0
NIM Sockets
NIM Socket 0:
   Type: DVB-S2
   Name: BCM7356 DVB-S2 NIM (internal)
   Frontend_Device: 0
NIM Socket 1:
   Type: DVB-S2
   Frontend_Device: 1
Modules Loaded
Module  Size  Used by
ipv6  365909  26
brcmfb  1590  4
dvb_bcm7356  1416805  33 brcmfb
dvb_base  4584137  187 dvb_bcm7356
bcm_event  2789  5 dvb_bcm7356
procmk  1668  2 dvb_bcm7356,bcm_event
dvb_usb_af9035  13245  0
dvb_usb_v2  14734  1 dvb_usb_af9035
Kernel Objects
/lib/modules/3.13.5
/lib/modules/3.13.5/modules.builtin.bin
/lib/modules/3.13.5/modules.symbols.bin
/lib/modules/3.13.5/kernel
/lib/modules/3.13.5/kernel/net
/lib/modules/3.13.5/kernel/net/802
/lib/modules/3.13.5/kernel/net/802/stp.ko
/lib/modules/3.13.5/kernel/net/llc
/lib/modules/3.13.5/kernel/net/llc/llc.ko
/lib/modules/3.13.5/kernel/net/ipv6
/lib/modules/3.13.5/kernel/net/ipv6/ipv6.ko
/lib/modules/3.13.5/kernel/net/wireless
/lib/modules/3.13.5/kernel/net/wireless/lib80211.ko
/lib/modules/3.13.5/kernel/net/bridge
/lib/modules/3.13.5/kernel/net/bridge/bridge.ko
/lib/modules/3.13.5/kernel/net/mac80211
/lib/modules/3.13.5/kernel/net/mac80211/mac80211.ko
/lib/modules/3.13.5/kernel/drivers
/lib/modules/3.13.5/kernel/drivers/net
/lib/modules/3.13.5/kernel/drivers/net/tun.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k/ath9k_common.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k/ath9k_hw.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k/ath9k_htc.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/carl9170
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/carl9170/carl9170.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/8192cu.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/hostap
/lib/modules/3.13.5/kernel/drivers/net/wireless/hostap/hostap.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rtl818x
/lib/modules/3.13.5/kernel/drivers/net/wireless/rtl818x/rtl8187
/lib/modules/3.13.5/kernel/drivers/net/wireless/rtl818x/rtl8187/rtl8187.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/zd1211rw
/lib/modules/3.13.5/kernel/drivers/net/wireless/zd1211rw/zd1211rw.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt73usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2x00usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2800usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2500usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2x00lib.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2800lib.ko
/lib/modules/3.13.5/kernel/drivers/media
/lib/modules/3.13.5/kernel/drivers/media/pci
/lib/modules/3.13.5/kernel/drivers/media/pci/ttpci
/lib/modules/3.13.5/kernel/drivers/media/pci/ttpci/ttpci-eeprom.ko
/lib/modules/3.13.5/kernel/drivers/media/usb
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dibusb-common.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dw2102.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dib0700.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dibusb-mc.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-pctv452e.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dtt200u.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/siano
/lib/modules/3.13.5/kernel/drivers/media/usb/siano/smsusb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-af9015.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-af9035.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-it913x.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-rtl28xxu.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb_usb_v2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/vuplus
/lib/modules/3.13.5/kernel/drivers/media/usb/vuplus/vuplus_tuner_turbo_driver.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/em28xx
/lib/modules/3.13.5/kernel/drivers/media/usb/em28xx/em28xx.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/em28xx/em28xx-dvb.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf2-memops.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf2-vmalloc.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf2-core.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib8000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dibx000_common.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib7000m.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib7000p.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib0070.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib0090.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/rtl2830.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/rtl2832.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib3000mc.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners
/lib/modules/3.13.5/kernel/drivers/media/tuners/r820t.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/e4000.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/fc0013.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt2266.ko
/lib/modules/3.13.5/kernel/drivers/media/common
/lib/modules/3.13.5/kernel/drivers/media/common/cypress_firmware.ko
/lib/modules/3.13.5/kernel/drivers/media/common/tveeprom.ko
/lib/modules/3.13.5/kernel/drivers/media/common/siano
/lib/modules/3.13.5/kernel/drivers/media/common/siano/smsmdtv.ko
/lib/modules/3.13.5/kernel/drivers/media/common/siano/smsdvb.ko
/lib/modules/3.13.5/kernel/drivers/staging
/lib/modules/3.13.5/kernel/drivers/staging/rtl8712
/lib/modules/3.13.5/kernel/drivers/staging/rtl8712/r8712u.ko
/lib/modules/3.13.5/kernel/drivers/staging/winbond
/lib/modules/3.13.5/kernel/drivers/staging/winbond/w35und.ko
/lib/modules/3.13.5/kernel/drivers/staging/media
/lib/modules/3.13.5/kernel/drivers/staging/media/as102
/lib/modules/3.13.5/kernel/drivers/staging/media/as102/dvb-as102.ko
/lib/modules/3.13.5/kernel/drivers/staging/wlan-ng
/lib/modules/3.13.5/kernel/drivers/staging/wlan-ng/prism2_usb.ko
/lib/modules/3.13.5/modules.dep
/lib/modules/3.13.5/extra
/lib/modules/3.13.5/extra/dvb_base.ko
/lib/modules/3.13.5/extra/brcmfb.ko
/lib/modules/3.13.5/extra/fpga_directc.ko
/lib/modules/3.13.5/extra/bcm_event.ko
/lib/modules/3.13.5/extra/cdfs.ko
/lib/modules/3.13.5/extra/dvb-bcm7356.ko
/lib/modules/3.13.5/extra/procmk.ko
/lib/modules/3.13.5/modules.dep.bin
/lib/modules/3.13.5/modules.devname
/lib/modules/3.13.5/modules.softdep
/lib/modules/3.13.5/modules.alias
/lib/modules/3.13.5/modules.order
/lib/modules/3.13.5/drivers
/lib/modules/3.13.5/drivers/net
/lib/modules/3.13.5/drivers/net/wireless
/lib/modules/3.13.5/drivers/net/wireless/rt5370sta.ko
/lib/modules/3.13.5/modules.alias.bin
DVB devices
/dev/dvb
/dev/dvb/adapter0
/dev/dvb/adapter0/audio1
/dev/dvb/adapter0/ca8
/dev/dvb/adapter0/ca7
/dev/dvb/adapter0/ca6
/dev/dvb/adapter0/ca5
/dev/dvb/adapter0/ca4
/dev/dvb/adapter0/ca3
/dev/dvb/adapter0/ca2
/dev/dvb/adapter0/ca1
/dev/dvb/adapter0/ca0
/dev/dvb/adapter0/frontend1
/dev/dvb/adapter0/frontend0
/dev/dvb/adapter0/audio0
/dev/dvb/adapter0/video1
/dev/dvb/adapter0/video0
/dev/dvb/adapter0/net8
/dev/dvb/adapter0/dvr8
/dev/dvb/adapter0/demux8
/dev/dvb/adapter0/net7
/dev/dvb/adapter0/dvr7
/dev/dvb/adapter0/demux7
/dev/dvb/adapter0/net6
/dev/dvb/adapter0/dvr6
/dev/dvb/adapter0/demux6
/dev/dvb/adapter0/net5
/dev/dvb/adapter0/dvr5
/dev/dvb/adapter0/demux5
/dev/dvb/adapter0/net4
/dev/dvb/adapter0/dvr4
/dev/dvb/adapter0/demux4
/dev/dvb/adapter0/net3
/dev/dvb/adapter0/dvr3
/dev/dvb/adapter0/demux3
/dev/dvb/adapter0/net2
/dev/dvb/adapter0/dvr2
/dev/dvb/adapter0/demux2
/dev/dvb/adapter0/net1
/dev/dvb/adapter0/dvr1
/dev/dvb/adapter0/demux1
/dev/dvb/adapter0/net0
/dev/dvb/adapter0/dvr0
/dev/dvb/adapter0/demux0
/dev/dvb/adapter1
USBTuner revision
DVB Drivers revision
Vu+ Kernel Drivers
-rw-r--r--  1 root  root  7784 May 19 10:35 /lib/modules/3.13.5/extra/bcm_event.ko
-rw-r--r--  1 root  root  5780 May 19 10:35 /lib/modules/3.13.5/extra/brcmfb.ko
-rw-r--r--  1 root  root  35580 May 19 11:04 /lib/modules/3.13.5/extra/cdfs.ko
-rw-r--r--  1 root  root  1297168 May 19 10:35 /lib/modules/3.13.5/extra/dvb-bcm7356.ko
-rw-r--r--  1 root  root  6549904 May 19 10:35 /lib/modules/3.13.5/extra/dvb_base.ko
-rw-r--r--  1 root  root  2376 May 19 10:35 /lib/modules/3.13.5/extra/fpga_directc.ko
-rw-r--r--  1 root  root  4412 May 19 10:35 /lib/modules/3.13.5/extra/procmk.ko
Box Info
BH Ver:
USB devices
Kernel Messages
FE tune
[AUD]: Mute : 0
FE tune
[AUD]: Mute : 0
FE tune
[AUD]: Mute : 0
FE tune
[AUD]: Mute : 0
FE tune
[AUD]: Mute : 0
FE tune
[AUD]: Mute : 0
[AUD]: Mute : 0
FE tune
[AUD]: Mute : 0
[AUD]: Mute : 0
FE tune
[AUD]: Mute : 0
FE tune
[AUD]: Mute : 0
[AUD]: Mute : 0
FE tune
[AUD]: Mute : 0
FE tune
[AUD]: Mute : 0
FE tune
[AUD]: Mute : 0
FE tune
[AUD]: Mute : 0
NIM Sockets
NIM Socket 0:
   Type: DVB-S2
   Frontend_Device: 0
NIM Socket 1:
   Type: DVB-S2
   Frontend_Device: 1
Modules Loaded
Module  Size  Used by
ipv6  365909  26
brcmfb  1590  4
Kernel Objects
/lib/modules/3.13.5
DVB devices
/dev/dvb
/dev/dvb/adapter0
/dev/dvb/adapter1
USBTuner revision
Vu+ Kernel Drivers
Reboot your box, rerun the DVB debug and upload here the generated file.
non si istalla nemmeno ts pannel....esce la scritta (bad magic number in /usr/lib/enigma2/python/plugins/extension/TSpannel/plugin.pyo
