Open Black Hole Vu+ Solo2 0.1
Ok, sorry, i was only making a question, i think a forum is for that, but sorry again.
Your question breaks our Board rules and I'm refering to my (Italian) post directly. If you have in this situation take my previous reply as a warning: we not tolerate EMU, software CAM or illegal usage of our Image and we not support that kind of third-party softwares.
Ho installato OBH in multiboot e devo dire che la pennetta Happauge che con la BH 2.16 in flash fa i capricci con questa immagine fila via liscio. Vorrei saper dovo posso trovare scaricare skin compatibili visto che mi sembra di aver capito che quelli della openPli dovrebbero essere compatibili.
I usually just use the Blackhole image 2.1.6 etc but I've given this one a go and really like it, The only issue I have at the moment is making a full backup, On BH 2.1.6 it was easy to do you just went to the backup menu and chose full backup and it would make a full backup, I then just put in on a USB stick and flashed it like normal I used that a lot for when I had installed all the extra plugins etc I wanted after an update and could then send the backup to my friends as well so they could have it all setup for them.
From what I can see there is no full backup option in the menu's, I've found 'Autobackup' in the green panel but that only seems to create a 'pli-autobackup.tar.gz' file so I'm wondering if there is a fullbackup option in this 0.1 Image??, If not is there I program I can get to do that or what do I have to do to get an image from this 'pli-autobackup.tar.gz' file.
Thanks
A few more issues:
1) EPG - for some reason, the current program isn't shown right in the channel list, and after I chose the channel, the correct EPG and program show up after a second or so.
This happens even after I update EPG through EPGdownloader.
2) UPDATES - Will there be regular updates as with previous images, or will we have to constantly update the image through the "Online image update"?
How often should we update it?
Nilox N20 (AF9035a) not reconized Open Black Hole
It seems there are some problems with AF9035 kernel module dependencies. I fixed my AVerMedia HD Volar A867 (AF9035) with:
opkg install kernel-module-af9033
opkg install kernel-module-mxl5007t
(remove and insert again the tuner and restart gui)
