Open Black Hole Vu+ Solo2 0.1
It seems that you're right
It worked last time I tested
However now is not working with OBH image with solo2 and with duo2 works.
You can test with Black Hole standard image .
I tested 2.1.6.1 - works fine on solo2. FTA and not FTA channels...
Will wait for updated OBH on solo2
thanks a lot I found it..
where does it store the epg..it is not in the usb? there is no way to define the location of the epg? I heard that the internal flash is not recommended.. is it taking the disk by default?
I think default is HDD
You can set the storage device for the epg.dat file by editing the settings file in /etc/enigma2 when enigma is stopped.
init 4 (to stop enigma)
edit now /etc/enigma2/settings
add or change
config.misc.epgcache_filename=/media/usb/epg.dat (or another location to your choice)
init 3 (to restart enigma)
Open Black Hole 0.1
Main Features:
  • Full Hd skin (1920x1080)
  • HbbTv
  • Open GLes animations (Duo2, Solo2, SoloSE)
  • Xbmc (Duo2, Solo2, SoloSE)
Black Hole:
  • Blue panel
  • Green Panel
  • Extra Settings
  • Addons panel
  • Compatible with Pli plugins and Skins
What is Open Black Hole ?
It is an exciting new project from the same team that produce the Black Hole images.
This new project is based on the PLi git and coding infrastructure, which means it is not only Open Source, but it is also compatible with all PLi plugins, feeds and skins and it also features full online update support (for those users that do not like having to do a full reflash everytime there is an image update). We have just given it the Black Hole touch.
This means it has the Green Panel and Blue Panels as found in the standard Black Hole images, we have also added the Black Hole addons panel and included Full HD skin support, OpenGLes Animations and of course included Xbmc .
As with the standard Black Hole images, we continue to support Genuine Vu+ Boxes only and therefore our images are optimised for Vu+ boxes and will only work on these models (any Open Black Hole, or Black Hole images you see on the internet for other box models or clone models are not official images and we offer no support for those boxes or images).
Do I have to upgrade to this new Open Black Hole image ?
No you don't have to upgrade to the new Open Black Hole image, this image is completely separate from the original Black Hole image, this is simply a new image so we can offer our users more choice, if you are happy with your current image, then you can continue to use that image, if you want to try the new Open Black Hole image then you can do so.
What about the Black Hole and Black Hole Prism Images ?
For those of you worried about the standard Black Hole and Prismcube image, please don’t worry, we remain committed to the standard Black Hole and Black Hole Prism images and image updates will continue as normal, this new Open Black Hole image is an additional project and we are fully committed to all images.
Where can I find the Open Black Hole git ?
The Open Black Hole git is located here: http://git.vuplus-community.net
DISCLAIMER
THE OPEN BLACK HOLE IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPEN BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
graet image but i m italian not see av 867 dvdt 2
Hello. I have a problem in my SOLO2.
I set my tuner like this:
tuner A: DiSEqC A/B A-> Astra 1KR Astra 19.2E ... ku band,
B-> 13.0E Eutelsat Hotbird
tuner B: loop trough to Tuner A.
The problem is I can not record one channel and watch another whether FTA or encrypted. However, if I put a shunt antenna with two cables, one for each tuner without changing the configuration, if I can record one and watch another. Is there a problem with the configuration trough loop ?.
Thank you.
Be careful to use the correct tuner A to B or B to A, based on cable connection.
Try a channel search selecting the B tuner and see if it works.
You need to configure this tuner settings exactly as the A, then add the value tuner A into the Connected to field
