Open BlackHole Online Update
I installed new OBH 4.3.011 release (openbh-4-3-011-release-vusolose_usb_release_96e984d-zip) and I am suprised.
Do you know why old Kodi (17.6 krypton) was installed from 'Black Hole Speed Up' menu instead of new Kodi 18?
Do you have similar issue?
You clearly didn't read the release post.
It says Kodi 18 is only for Vu+ 4K ARM boxes, it does not work with Mips boxes (which is what the SoloSE is).
So that is why you have Kodi 17.6
Actually, so far (apart from a single exception) images had been released for every model and, as a matter of fact, this thread is generic.
But, in these last days there's something strange going on, because we are having updates only for some models.
So, I personally won't give any "announcements" any longer.
I hope this "unparallel" system is only temporary. ;)
About profile, is strange it's the 2nd time I need to write such a thing in two days: do you ever read, for each single post you consult in this forum, the user's profile? I don't for sure.
UP: is it only my problem I can't update from 010 to 011 my Solo4K or it's possible that the last consistent online update was the 011 but the INFO shows 010 because of a bug?
Retry using the method 1) indicated by @Ev0 at #1.--> https://www.vuplus-community.net/board/threads/open-blackhole-online-update.35824/
If it not suceeds, reflash your STB using the lastest OpenBH 4.3.011 --> https://www.vuplus-community.net/board/threads/openbh-4-3-vu-solo4k.39747/
Is there some issue you want to see fixed?
The issues I'm aware of, for instance, and existing in the last updates, are very, very old and they are there since at least 4.1.023: the examples I'm referring to are:
1) Big PiP issues in some models (like Solo4K)
2) Difficulties in managing some peculiar tuner configurations, where SCR and Universal are connected to a normal DiseqC switch.
But, as I said, they have been there for a long time. So, if there is nothing special to fix, what the updated for? Just for compulsive need of news?
Same for Solo4K. This time (as it was normal in the past), probably every images for each box, have been released at the same time. ;)
Not an image problem, of course, otherwise we would have been invaded by messages... It must be some plugins of yours.
Have you tried to switch the power off from the main power switch?
