Open BlackHole Online Update
The error is caused by the third-party skin, which is likely to be related to the skin, but it has been very stable since 4.3001. This time, it has been reporting errors after the new. The skin is stable and there is no problem. An error log is attached. Please help. Thank you
Sorry, but you can't ask for help to OBH coders!
First of all it's not an OBH component that causes your problems: so you must ask to the skin author.
And, finally, there a lot of beautiful skins, certified by OBH, and you need a third-party one? Nonsense.
Do you know that skins are not just a piece of graphic but they heavily interact with the image code? It's very risky to use a not certified skin.
Versione firmware: Vu+Duo2 OpenBH 4.3.016 (2020-02-12)
Hall
Just ran an update on my solo2 to 4.3.016 and now I can't find the menu point for downloading picons.
It could be I can't see the wood for the trees or I am tired.
Would somebody be so kind as to point me in the right direction? I.e. which menu to use.
Thanks in advance.
Valb
Thanks in advance.
Valb
Sorry to have troubled you. I've found it. Green, yellow , addons download manager.
Valb
At this moment I can only update the Duo 4K ... it was the only one with the symbol that indicates the update. Zero 4K and Uno 4K SE without the symbol and do not update.
Hi
I am updated 4.3.017 online my duo4k & ultimo4k both problem
Not working
I own Duo4K, Ultimo4k, Zero4K, Duo2 ( not updated yet ). but i will report ASAP, just Uno4KSe was not uupdatet and remains 4.3.014 version.
I will report the issue to our developers team. Thanks for your feedback.
Note: For those that have time ( Uno4kSE ), it you have the desired time to test, flash the box, with the lastest compiled image --> https://www.vuplus-community.net/board/threads/openbh-4-3-vu-uno4k-se.39745/ , and report "the online update issues, if you found any"! This will update your STB from 4.3.015 to 4.3.017 ... as expected, at least i hope! :)
Hi
Not working
What did you mean as:
" Nothing Working "?
Note: This is not a report ... are you stucked? why? I have no issues with DUO4K and ULTIMO4K ....
And for lastest ... just to give info to all members that owns DUO2 as I, ... no issues during update ...
Proof:
