Open BlackHole Online Update
No, you did not have different indications.
See post 388 by Ev0 and 396 by nunigaia, not to mention that this has been discussed many many many times.
Then there are slight variations but the core of the updating process is in the two commands "opkg update" and "opkg upgrade", that you can send one by one or altogether or along with some others (like init or reboot, but they are not indispensable).
I advice you to save in a text file all the most useful linux command for telnet/putty/whatsoever otherwise you'll be asking the same things each time.
@Alexwilmac
I apologize,
you are right
I was wrong to read Evo's post 388 where I read everything is clear now
I had stopped at the first epkg update command followed by reboot and I was convinced a little while ago that I had read correctly ... so much so that I repeated the command several times ....
Come on …. sooner or later I will learn
later, as always... :)
Follow my advice: create a text file with all the useful commands. I did, and it makes everything quicker. One by one you'll add whet you need. BUT.... Add them only when you are sure you understood them and they work!!!
@Alexwilmac
I apologize,
you are right
@Alexwilmac has mentioned my post --> https://www.vuplus-community.net/bo...khole-online-update.35824/page-20#post-267007
Note: Just copy / paste the lines you prefer. The more completed entry line, does completely the job for you.
Dear all,
I would like to re-flash my duo 4k and solo 4k with the latest OBH 4.3019 but I don't find the direct download link (in the forum there is up to 15 version). Can anyone help me?
Many thanks in advance.
Kind regards
Roberto
No: there is NEVER the last update published as full install except every now and then when they publish (in the first post), a step forward in the offline installer. But then you have to update online.
As stated in post #408, I've found in the downloads section the 4.3015. Since I've never re-flashed from 4.301, I would like to know if at least was fixed the problem of "4 updates available" if I re-flash with 4.3015 and after I update from 15 to 19?
I Hope I was clear...
Inviato dal mio ONEPLUS A6003 utilizzando Tapatalk
Hallo,ich habe eins zero4K,ich habe huete versucht neues upda instalieren,nach dem update der zero4k kann nicht hoch fahren,da ist immer wieder neustarten,
wo ran kann das problem liegen? kann mir einer helfen.
mfg
tr-22
mfg
tr-22
If you are using Open BlackHole, and if you haven´t set any other location for logs:
By FTP try connect to your STB and look at:
/home/root/logs
If you have any crashlog, and post it here!
Google translation to German:
Wenn Sie Open BlackHole verwenden und keinen anderen Speicherort für Protokolle festgelegt haben:
Versuchen Sie per FTP, eine Verbindung zu Ihrer STB herzustellen, und sehen Sie sich Folgendes an:
/home/root/logs
Wenn du ein Crashlog hast, poste es hier!
Hi dears
in our country Iran the spring session started and for us start a new year 1399 in shamsi calendar
i have a proposal for VU+ OBH
please release a full new image for install whit usb
thanks
so its a proposal only
/home/root/logs
/home/root/logs
Hallo,erst ich bedanke ihnen,ich habe jetz nochmal update gemacht problem ist wieder da,ingh bin mit filazilla verbunden,home,root,logs,der logs ordner ist leer,ist noch zwei ordner mir,ipkgung und wget-log.
mfg
tr-22
mfg
tr-22
PS:das ist erste mal nur an dieses update bekommen,vorher nicht.
/home/root/logs
/home/root/logs
wie kann ich wieter machen,sie heben recht,der postet nur Crashlog
