Open BlackHole Online Update
This is the International section: ONLY ENGLISH, please!
There´s no international section for Open BlackHole support ;)
wie kann ich wieter machen,sie heben recht,der postet nur Crashlog
If there´s no "crashlog", you must reflash from scratch and do an "ONLINE UPDATE" to get Open BlackHole 4.3.019.
The cause, could be a plugin that you have installed ( for ex: a third party panel that breaks the code ).
Google German translation:
Wenn es kein "Crashlog" gibt, müssen Sie von Grund auf neu flashen und ein "ONLINE-UPDATE" durchführen, um Open BlackHole 4.3.019 zu erhalten.
Die Ursache könnte ein Plugin sein, das Sie installiert haben (zum Beispiel: ein Panel eines Drittanbieters, das den Code bricht).
Ps: https://www.vuplus-community.net/bo...khole-online-update.35824/page-20#post-267007
But the last is very, very fresh, it's the 4.3.015 and we are at 019, now: not such a big difference. Have you flashed the 015?
yes im in 019 i update every time
i mean a fresh image install
i thinks full image install fix my wifi problem . my box,s wifi not working so i cannot see anything about wifi in my box settings its Duo2
Hi dears
in our country Iran the spring session started and for us start a new year 1399 in shamsi calendar
i have a proposal for VU+ OBH
please release a full new image for install whit usb
thanks
so its a proposal only
I think that a difference of 106764 years is absolutely irrelevant to whether or not you can create a new version of OBH ...
I think that at this moment and in particular in Iran, there is more to worry about ...
There´s nothing wrong with embedded Wify with Duo2. There´s nothing wrong also, with ONLINE UPDATE ( from 4.3.015 until get 4.3.019 ). So, for now, there´s no need to build another version image.
Best regards
hello,
with the latest online update 4.3.019 the full backup not recongize the usb (vu zero 4k)
with 4.3.015 no problem
is it possible
THX
Although is possible a different behaviour in different models (it happens, for instance a bug in BIG PiP only for Solo4K but not Ultimo4K), I can confirm there is no problem in the 019 for Solo4K (arm as it's the Zero4K) and in Duo2.
The pictures are from Solo4K.
Hi guys,
i'm using Vu+ Zero 4k, i'm already clean flash with 4.3.015, then I try to online update to version 4.3.019 but how come it fails/error huh? any solution?
Sorry, my english is bad :). :thanks:
It's always advisable to perform updates by the command line, first of all because they, for some reasons, tend to avoid any troubles.
Secondly, because you can check what has been downloaded and possible errors or warnings.
And finally, and above all, because you can do it in background, without "disturbing" your viewing of the STB. You'll send the reboot command only when you are comfortable.
So, I prepare the box directly by the usual command we've read many times
opkg update && opkg upgrade
(you can give it at once or in two separate lines, as in the previous post), which downloads and prepares everything. Then when I don't need the box, I give the
reboot
for a complete restart of the STB.
This panel is exlusive for Blackhole and are also depended on things in BH that are not in OBH
Then when all is said about this, nothing is impossible but this is and allways have been a Blackhole panel
so see no future where this panel will appear in OBH Image
@casco
Please, learn how to quote a message. You (even!) quoted your own message just to perform a so called UP action, because you did't add anything to the quoted post.
When you want to quote a message, it's not compulsory at all to quote the whole of it but you can delete as many part of the original post included between the start
.............. said:
and the end
This way other user won't be in the need of "open" the quote and then, even, as in this case, find out that you did not add a single line to the original post!
To perform an UP just post... "UP".
Thanks.
Ciao a tutti, non mi fa l'aggiornamento da 19 a 20, rimane sul 19, con ultimo4k
Aspetto suggerimenti
Grazie e un abbraccio a tutti
