Open BlackHole Online Update
A situation that does not interfere with anything in the function ...
The disc is in a 4K Duo and Zero 4K has mounted it in a network.
In version 4.2.020 the network assembly:
Opening the Media Player:
Opening E2iStream:
Installed version 4.2.025, by Media Player:
Indicates 2x the Duo 4K disk ...
I used the Zero 4K backup to revert to 4.2.020 but continued to assume the values acquired by the update to 4.2.025.
I have a Uno 4K SE with disk and the same is true for Duo 4K and Duo 4K for Uno 4K SE.
I do not know if in versions 4.2.021 / 22 the same happens, I only have backup of 4.2.023 and then it happens.
Problem persist, update 4.3.024/4.3.025 kills uno. Enigma2 can not start.
Can somebody help? Logs are in my previous post (clean install of 4.3.015 + update is not working too).
Opening E2iStream:
Sorry, version is 4.3.0xx
I have taken a look at ( automounts.xml ) , located at:
etc/enigma2
The issue was there, renamed the automounts.xml to "automounts.xml-save" as suggested, rebooted the STB, the issue was gone. :)
Then i have deleted the "automounts.xml-save", because it was not needed.
I try investigate problem self. I have working backup 4.3.019
It takes a lot of time due to long restarts.
Current status: Uno/Duo can not start enigma2 for image version 4.3.024/4.3.025
Be patient....
= = = = = Attention!!! = = = = =
Do not update OBH image of older models UNO/DUO! It kills your receiver!!! (Enigma2 can not start)
Problem started with version OpenBH 4.3.024 and still persist in latest version 4.3.026
BH Team, please make corrections or rollback feeds for older models to date of release 4.3.023 (if possible) or make downloadable working image.
I tried to find out where the problem is, but too much changes for me.
My working backup is 4.3.019
p.s.UNO4KSE is working OK with 4.3.026
I have the same problem with Zero, also from .024. After updating enigma does not start, after booting box is frozen with enigma starting ...
In the meantime, updates on 4Ks (Solo, Zero) work perfect. Problem is on HD versions.
