Open BlackHole Online Update
This problem usually is due to the Internet connection or network configuration or DNS, surely not to the feeds, otherwise you would get a different error message.
And there is also the command line to try an update, as usual:
opkg update && opkg upgrade
Hello,
I have a VU+ Ultimo 4k and since the 4.3.024 (including) update all channels on satellite freeze (no matter if free or encrypted). It work fine for about 5 to 10 seconds, then it freezes, and again 5 to 10 seconds work fine. If it helps my configuration uses JESS. All images prior to 024 work fine with same configuration. After each update I have to revert to 023.
I'd try (as you clearly have the good habit of a daily backup) to install from scratch: then immediately (with a clean image) do a manual search.
Do you use by chance any of those plugins for autosettings? I wouldn't use them.
So, after the reinstalling, without installing any plugins, try the manual scan.
after the latest update (4.3.31) the signal level indicator increased for me by +11 .....
Signal level means nothing: a STB is not a signal meter. These values must be meant as relative measuring. So you can compare by them two channels but you can't know anything as an absolute value.
This has been discussed many, many times.
