Open BlackHole Online Update
I fear there's another bug. Said that I had it does not depend on skins (it occurred also with the standard BlackShadow_SE), after 031 update, image crashes trying to set an Instant Timer, whatever of the options [1 to 4] you choose, and this is a real problem, because especially the 3 it's something useful very often.
No problems, instead, creating a timer by EPG.
Could anyone try to see if it's not only mine? I have it with a Solo4K.
Same here with me. I've got an Ultimo 4K
Why do you have 767 E2 re-starts?
Can you please post your crash log, or probably logs.
Apart from using a different skin what other changes, have you made, that could cause a crash?
He he i have alot more then 767 E2 Restarts ;) this is just my OBH image in multiboot
and you can thank @Ev0 and @nunigaia for all those restarts ;)
My crashlog is just a true copy of @Alexwilmac crashlog so did not see any reason for adding the same.
I am also pretty sure that Ev0 is on this and have a fix on its way.
Has been anything related to the last changes at InfoBarGenerics and RecordTimer ( new code ), that has implemented this bug on image.
Hi guys, after updating to 4.3.031 when I press the record button on my Duo4k it crashes and reboots, can you please advise as it was fine before.
You better do some more tests then.
I have over 4155 restarts and that is just on this install of obh 4.3 (I have 4 installs).
Oh... poor me: I'm only at 515 on this and other 350 in the other install in flash. I'm far from you all! :-)
Well, 75% of them are due to localization's tries ;)
Temporary FIX Timeshift Issue.
1) Just unpack the attached file and by FTP overwrite the file "InfoBarGenerics.pyo to:
/usr/lib/enigma2/python/Screens
2) Execute the following command or restart enigma2
killall -9 enigma2
Accully one tiny tiny little bug but that might have been there a long time.
But i did discover it today while doing some testing of the new update.
If you start to create a timer based on duraion and you cancel this timer with exit button it still gets created
Now its not a big issue since its set to zero minute and therfore becomes marked as done in the timerlist.
Could some one test this and confirm? i must admit that i do such a lot of work on my OBH image that i might
have been corrupting the image and created this bug my self
