Open BlackHole Online Update
Nope nothing there either. No YouTube TV but for me it does not matter i want use YouTube on my Vu+ when i have it on the TV
And now i know your answer Ev0 ;) so please spare me :D:D:D
You need chromiumOS installed.
Youtube TV is installed with that.
  • Like
Reactions: KFL
What... would be better to rename this in speedup to YouTube TV
I am sure the other guy have missunderstod this like me and installed the none working plugin from BH Addons server ;)
Ha ha ha yes those bastards ;) well then we sorted it out without me needing to re install my corrupted image :)
Thanks my friend :)
I bought Uno4kSE (YoutubeTV, other features). "Youtube is there, sure, but I don't see it, where is it?" I was confused. But one tech-vu+-night I found it: ChromiumOS Enable.
Who would have guessed that ChromiumOS is YoutubeTV?:huh:
That was my story.;)
...ok, end of youtube talk, back to update issues...
In (Recording & playback) settings when I set (Behavior when a movie reaches the end) to "Continues play (loop), or Ask user or whatever choice, and save this change. it is not apply when I play a movie from movies list and reached the end. always returnes me to movies list !!
When I double check (Recording & playback) I find the setting changed to (Returne to movie list) !
I dont know if this is a bug or there are some settings to go through.
Vu+Duo
Open Black Hole 4.3.033
Try using youtube on Kodi ... now you need to create an API key. So the plugin no longer supports the possibility of login ... now you have to go through the browser on the Vu ...
Long ago I stopped watching youtube through Vu ... smartv for youtube it's the best way.
Duo2 was the first box the update was available for.
Pressing the yellow button finds no updates (apart from the usual 1 that has been appearing for years but has not been resolved)
I also used the command from telnet:
init 4 && opkg update && opkg upgrade && init 6
but the version remains the 034...
Hall
Yes, I think that for Mips VU+ the version release wasn't update. But it's only a number. The updates you applied were real.
