Open BlackHole Online Update
Accully one tiny tiny little bug but that might have been there a long time.
But i did discover it today while doing some testing of the new update.
If you start to create a timer based on duraion and you cancel this timer with exit button it still gets created
Now its not a big issue since its set to zero minute and therfore becomes marked as done in the timerlist.
Could some one test this and confirm? i must admit that i do such a lot of work on my OBH image that i might
have been corrupting the image and created this bug my self
Not for me :)
Yes but you have gone through the whole cykle and created the timer so therefore it should show up.
But if you do the same, but when the input box is showing you press Exit button instead of OK to abort
then there will still be created a timer.
But as i said i could have corrupted my image my self so maybe ;)
Yes I can confirm this.
I think the reason for this is you have less than 5000 restarts :D
Yes, Thomas: I remember a thread open about 8-10 months ago. It also happens if you choose to create a timer based on the end time.
And it also creates a 0 byte file when you do that.
Fortunately, they are not serious or annoying bug and, above all, it does not cause any crash.
But surely it's a peculiar behaviour and, as I was still a programmer, I'd like to remove these little bugs from a software of mine.
Just as matter of principle ;)
Ha ha @Ev0 you of anyone nows i probable are at a good second place behaind the Reboot King him self do @Matrix10 ;)
and half of yours i am responsible for so they should count as mine ;)
And i agree with Alex this little bug i just have to see if i cant get ride of because BH and OBH are prime images and we dont leave crapp in our beloved images :cool:
I'm very happy thanks OBH & BH ,the best team
Thank you brother @Ev0 for ur great help
Finally Arabic language
openbh: release 4.3.033 has been released
Since openbh: release 4.3.015, youtbe cannot be used, the interface is displayed normally, the login account is also normal, and the video is played incorrectly. I thought it was my own installation problem. I re-painted the other firmware and it played normally. It is fast, stable, and does not generate heat. It is a very good firmware. Please fix the problem of playing video under youtbe.
There is no problem with Youtube tv I am watching it now.
Hello,
İ cannot update my VU+ Uno 4K to 4.3.033. Message is: "There are 821 new packages. İt is recommended to flash new." Where can I find the new image please?
Hello,
So you haven´t update your UNO4K, since long time ago! :wallbash:
Reflash your STB with the lastest version, then do an "ONLINE UPDATE"!
or
using command line, past and copy:
init 4 && opkg update && opkg upgrade && init 6
Note: good luck ;)
I confirm: there is no problem with Youtube, at least with Solo4K.
@nunigaia: I think he is already running 033. Only he says Youtube does not work since 015.
My advice is to download again the last installer available form this forum, that's the 027, and then update it.
Accully i have never use YouTube on my Vu+ but installed from Addons and all works but i get error msg
No feeds and of cause after try 50 times i also get the "To many Request" error ;)
How do we update the feeds??
Youtube TV is part of the image, it's in the main menu or extensions menu.
The youtube plugin on the feeds is NOTHING to do with the image, it's a 3rd party plugin so complain to the author (whoever that is).
If you have problem with Youtube plugin (not Youtube TV), try this
#List installed version
 opkg list-installed enigma2-plugin-extensions-youtube
#Reinstallation steps
#Stop enigma
 init 4
#Remove old plugin
 opkg --force-depends remove enigma2-plugin-extensions-youtube
#Update sources
 opkg update
#Install current version
 opkg install enigma2-plugin-extensions-youtube
#Restart
 init 6
If you still have problem, ask here https://www.vuplus-community.net/board/threads/youtube-for-openbh-4-2-blackhole-3-0-9.24140/
Then i am blind because i have no Youtube TV in my Menu thats why i downloaded the plugin from the BH Addons
I also looked at Speedup to see if it could be activated there but nothing
Nothing in Extension or Plugin
So no YouTube TV
  • Like
Reactions: KFL
