Open BlackHole Online Update
I'm sorry, it was #613 ...
It's been said MANY times, there are occasions where the version number does not update.
But if you ran the update and then check again and there are no updates available then you have the latest updates, just the version number did not update.
Well, I had been convinced, too, that releases were always for every models and I used to communicate the release without specifying anything else; until, a couple of times, there was a different situation.
But, as you say so, from now on, we'll get back to the old habit ;)
In case someone will not be able to update their model, they will let us know.
It may even be because after the update, it indicated that there was no more update.
But, as I described, the notification for the update existed on the infobar, I did not update it, when I went to update that indication it did not exist ...
Even today, for the 4.3.038 update, only Duo 4K indicated on the infobar the existence of this update.
But all the problems were these ... here, today, they are over 40ºC, this is a problem, I had to invest in beer!:p
I chose the best time to change all the cables and LNBs of my antennas, eheheh
Hello!
On OpenBH I faced with several problems:
1. Doesn't work Green Panel when watching IPTV, I use 5002 (exteplayer3) (On Black Hole 3.0.9 - Ok)
2. I cannot change the IPTV quality, a very useful function for old devices like Solo2. Here's an example of running on Black Hole 3.0.9
1.jpg 2.jpg​
@Alexwilmac wait patiently:
Openvix released production version: Commits on Oct 7, 2020 openvix: release 5.4.001 (developer version were before), give @Ev0 some time (days) to adapt changes (thank you for your work), priority is BH & Duo4kSE now, version number (4.4/5.x/3.14) is useless talk
...so, please wait patiently...
HELLO
OBH LOVERS
my duo4k remote control volume button not working .can you please give me idea how to fixed ?
and waiting new version OBH IMAGE
THANK YOU
HELLO
OBH LOVERS
THANK YOU
It's a bit of an out there solution, but you could try.....
Buying a new remote control ;)
