Open BlackHole Online Update
And where you two are supposed "to see" such an update? There is nothing, at the moment, at least for Solo4K.
Ad, the updates are usually released for every model at the same time, I suppose that the same situation concerns the other models.
Hi
By magic as in the best fairy tales.....;)
Without touching anything only with update now I can see the folders of my NAS.:eek:
Strange .... because until a few months ago when I reported the bug I was considered a visionary !!!:chair:
Thanks anyway :thanks:
Hall
Here is what has OBH 4.4 that does not appear on the network... Uno 4K SE is with OPLI is detected.
The Zero 4K that appears is the one that made the network scan.
It's an oe-a issue, libx264 didn't get updated correctly for some reason when they bumped kodi from 18.8 to 18.9
Only way to fix it, is remove kodi, do a settings backup then reinstall 4.4.001 restore your backup and then update to 4.4.002
I was having the same problem with my vusolo4k not updating so decided to do a bit more investigation into it before I just reflashed the box, something weird doing on with dependancies here. I noticed that package: libx264-161 is being reported as unstable for one platform.
Never had Kodi installed either, will just reflash, think that’s the next step.
root@vusolo4k:/usr/lib# opkg update && opkg upgrade
Downloading http://feeds.vuplus-community.net/openbh/4.4/vusolo4k/3rdparty/Packages.gz.
Updated source 'openbh-3rdparty'.
Downloading http://feeds.vuplus-community.net/openbh/4.4/vusolo4k/all/Packages.gz.
Updated source 'openbh-all'.
Downloading http://feeds.vuplus-community.net/openbh/4.4/vusolo4k/cortexa15hf-neon-vfpv4/Packages.gz.
Updated source 'openbh-cortexa15hf-neon-vfpv4'.
Downloading http://feeds.vuplus-community.net/openbh/4.4/vusolo4k/vusolo4k/Packages.gz.
Updated source 'openbh-vusolo4k'.
Downloading http://feeds.vuplus-community.net/openbh/4.4/vusolo4k/vusolo4k_3rdparty/Packages.gz.
Updated source 'openbh-vusolo4k_3rdparty'.
Not selecting libx264-161 r2970+git0+0d754ec360 as installing it would break existing dependencies.
root@vusolo4k:/var/lib/opkg/info# cat libx264-161.control
Package: libx264-161
Version: r2970+git0+4121277b40-r0
Description: H.264/MPEG-4 AVC video encoder
A free software library and application for encoding video streams into
the H.264/MPEG-4 AVC format.
Section: base
Priority: optional
Maintainer: OE-Core Developers <openembedded-core@lists.openembedded.org>
License: GPLv2
Architecture: cortexa15hf-neon-vfpv4
OE: x264
Homepage: http://www.videolan.org/developers/x264.html
Depends: libc6 (>= 2.30)
Provides: x264
Source: x264_git.bb
root@vusolo4k:/var/lib/opkg/info# cat libx264-161.list
/usr/lib/libx264.so.161 0100755
root@vusolo4k:/usr/lib# opkg search /usr/lib/libx264.so.161
libx264-161 - r2970+git0+4121277b40-r0
root@vusolo4k:/# find | grep libc6
./var/lib/opkg/info/libc6.postinst
./var/lib/opkg/info/libc6.control
./var/lib/opkg/info/libc6.list
root@vusolo4k:/#
root@vusolo4k:/var/lib/opkg/info# cat libc6.control
Package: libc6
Version: 2.30-r0
Description: GLIBC (GNU C Library)
The GNU C Library is used as the system C library in most systems with
the Linux kernel.
Section: libs
Priority: optional
License: GPLv2 & LGPLv2.1
OE: glibc
Homepage: http://www.gnu.org/software/libc/libc.html
Provides: eglibc, glibc, rtld(GNU_HASH)
Source: glibc_2.30.bb
Section: base
Priority: optional
License: GPLv2
OE: x264
Provides: x264
Source: x264_git.bb
root@vusolo4k:/#
Package: libc6
Version: 2.30-r0
the Linux kernel.
Section: libs
Priority: optional
OE: glibc
Yes the problem seems to have re-appeared.
I don't know where the issue is, or why it keeps returning, hopefully it gets fixed soon.
FYI, the reinstall fixed the problem.
All good again.... thank you for running this site, very helpful!
Nothing substantially changed. The VPS plugin, for instance, is still incompatible. But this comes from the "cousin" ViX, unfortunately.
Hi, I'm on the latest obh on my vu+ duo2 and have a crash that needs power off with the rear switch every time I press exit button from the recording list page, after viewing a recording.
This is the same with the previous version.
Everything works, but after viewing a recording we know that the circle in to left corner will force a power cycle.
Is there anyone with that same problem?
i have the same problem
After the last update, are you having problems with HDMI-CEC?
The point is, you can't see the assignment addresses ...
... and we have 4.4.006
Hi,
at vu zero I tried to update with putty several times. Unfortunately it didn't work to update 4.4.006. at the end the receiver is on the screen and no longer reacts. I had to refill it again. The Vu zero 4K update worked very well.
many thanks
