Open BlackHole Online Update
The crashlog doesn't tell so much... I would say it could be another issue...
Please could you do some tests for us?
1 - try connecting the disk to your pc.
2 - try doing a disk check and eventually fix it.
3 - check the filesize of that ts.
4 - try playing that ts with vlc.
5 - try connecting a new freshly formatted disk
6 - please upload that ts somewhere (mega?)...maybe someone can replicate the error
It worked on 5.0.001, previous installed version
I can understant that it worked on 5.0.001.
The crashlog didn't give any userful information.
Unproperly mounted external device and power loss could corrupt the file system alloctation table and the effects couln't be immediate.
Please do these tests just to exclude problems with the disk.
I think you had misunderstood my query. I have tried playing a recording from /hdd/movie and it’s fine. Even creating a new folder was fine. So something got corrupted in the update and I will rebuild the folders
Hi
error in Making a Full Backup in ver 5.00.9
i Update my box whit telnet
first in the box make a stable Openvpn connection
and after that update from telnet
thanks all dear admin s
hello, could you add the appropriate driver for the xbox one tuner in the duo2?
It works for me in the openspa image but not in the opbh
in my vu+ duo2 its works fine with the last openspa 7.5004
but not in obh
Though post the drivers, unfortunately my DUO2 is out of service ( dead ) ... for now, I hope that I can repair ! ...
I thought it was working only on 4K STB´s ( where our team ) afair, has been involved to get it running on it!
when upgrading i have this message "Not selecting libx264-164 r2970+git0+0bb85e8bbc as installing it would break existing dependencies"
