Open BlackHole Online Update
Why should be this a problem? "Update" does not mean always "change of version". What matters is that the updates exists, not the version number.
OBH5 is still at .007 even for Solo4K, for instance.
Yes: I agree with you but, after the update always 250+ updates available (looping).
This is the problem...
Inviato dal mio CPH2173 utilizzando Tapatalk
Good morning to everyone,
My current version is 5.0.007.
Yesterday i noticed an update of about 250+ files but, after updating via Telnet, always 250+ updates available and always version 5.0.007.
The problem is in both my Vu+ duo 4k and solo 4k.
Already again look for updates... I always stay "hanging" in a package. Nothing serious...
But you didn't mention it ;)
In my case there was no problem. But I almost never update by GUI: I want to be free of using my box during the update and to reboot only when it's more comfortable for me, not for the box. Have you tried to update again by telnet/ssh? After a complete reboot, of course.
If you look my post #1179 I said I have updated with Telnet but the problem of looping still persist...
I updated my Solo4K by command line and, now, there is only the "famous" message already seen sometimes in the past
Not selecting libx264-164 r2970+git0+19856cc41a as installing it would break existing dependencies
but which does not affect in any way the image. (In my case is probably due to ServiceApp, but it's not important and it appeared also in the past OBHs).
You need to follow what it's doing in telnet then, it should be showing you the errors (they must be there if the updates are constantly showing over and over again).
Same only in my Duo 4K... Uno 4K SE ok.
I always follow the update in Telnet but, both I'm a normal Vu+ user and because the update Is very fast, I did not see anything strange in the log.
I think It Is something related to unresolved dependencies of some plugin even it looks very strange that a big number of update (250) is always available even if the build Is always 007.
Moreover, It Is not the first time I face this problem from when I have obh 5 so I think that next time I'll face this problem, I'll post also the update log so you can study it.
Thanks
can anyone plez tell me if online addon/plugin server feed is currently working or not? i have connection issue to the server !
