Open BlackHole Online Update
What's your problem? Please explain.
The last "." is just the punctuation and you can remove it, but the link is perfectly working and links is correct.
You just have to click it, if you need to download it, or copy to a browser without the "." or, also, copy to a text editor.
When I try to update via telenet, none of the addresses are downloaded at all and I encounter an error
While in telenet the addresses are like this and at the end of each of them is a sign "." Yes, and if I copy the above addresses and enter them in the browser, they will be downloaded easily
The update download schedule is not correct and these points should be removed, of course I think so
For more explanation, I have to post a photo from Telenet
Also, in the 5.00.7 update, there is a problem with the feed, and the feed image is not the same as the feed image of your site.
I put the image down
The new feed image has only settings, but the feed version 5.00.4 is much better and wider and has more options.
Please take care
A world of thanks, love and appreciation for Iran
Please take care
Are you sure you don't have another problem
Plugins Panel ,It works
Maybe something is blocking you.
Yes internet blocks in his country, he's complained about it many times in the past that he can't connect to our feeds, but he still comes back to try again and then complains that he still can't connect, like we can do something about it.
OMG... now I remember!
@khafanpardaz : NOW, if you don't want to use a paid VPN to elude your country's problem, at least you have a new option, as you can't update the image online: to download the offline installer you can find always update to the last version in the new OpenBH forum:
https://images.openbh.net/?b=5.0/vuplus
Obviously, is not as comfortable as an online update but, if you save a Personal Backup, you can flash and then import the Personal Backup in order to get to the same result.
Hi dear
its not blocked
i see it
so in second and Third pic you can see feed in 5.00.7 ver Third Pic FEED7.jpg info7.jpg
so i try to show you in the fourth pic the feed menu in 5.00.4 ver feed 4.jpg info4.jpg
Please compare and test
Now I understand even less what is your problem ?
In the first post you say you only have settings.
I also use the 007 version and have it all
if that's not the case with you then it's weird
True, I tested only with Ultimo 4k, but there should be no difference.
So something is wrong with the image.
Yes
Thanks
This is the best solution and I understood it myself
Thank you for giving us good tips on helping us with the worst filters
yes in new update 5.00.7 i have only setting
in 5.00.4 its complete
Thanks
I use this part of the feed, which is more complete As ver 5.00.4 , to install some plugins and tools and softcams
But in the new version, it is incomplete and inaccessible
Thanks
If I remember correctly,
I have the same in all versions it should be no difference.
I'll check tonight, again.
I experienced problems, with my VU+ Duo2, updating from version 5.0.004, even when I tried to use Telnet, but as I'd been using my Duo2 to test OpenBh 5.0, and changed all settings, installed, and removed, plugins, and generally tested everything I could think of, or had time to, I simply downloaded the latest version, of OpenBh, and re-flashed my receiver.
Why not try that?
https://images.openbh.net/?b=5.0%2Fvuplus
Thanks
Tested again
I have no problems with Plugins feed and 5.0.007 Open Black Hole.
I also had no problems with the upgrade.
So something is not OK in your image.
Tested again
Thank you for your effort Dear Matrix10
I just flashed it again, but the feed problem still persists
I know it is a little unlikely that the problem is related to my country's internet
The update problem persists due to the same previous post and the dot mark at the end of the addresses and can not be downloaded in Telenet.
It has nothing to do with telnet.
I don't understand why you need telnet for plugins ?
Plugins can be downloaded from the image.
And the image upgrade uses another command in telnet
opkg update && opkg upgrade
"the dot mark at the end of the addresses and can not be downloaded in Telenet"
In which image version do you have dot mark at the end
Maybe that causes a problem for telnet
but last night I tested Plugins feed and 5.0.007 Open Black Hole version on VU + Ultimo 4k
and download from the image goes without problems.
Hi Again Dear Matrix10
i use telnet Only for Update but not answer for it
The only thing that can be imagined for me
This is because there have been changes in the image of the 4k Series that have been omitted in the HD series.
In my case, whether with VPN or any other mode, I can not use this feature and update my talent receiver.
It's easy to test if you have a block or not on your internet connection.
If you can open this link all should work just fine. If not then there is an problem.
Your feeds settings in folder /etc/opkg can be corrupted.
Or you can browse but not download due to block of Internet.
My guess is option nr 1 ;)
Click me to check
Click me to check
so
thanks
what can i do whit this packages.gz file ??
I prefer to use the same version 5.00.4
It was much better and more complete
And wait for the perfect image or the right update
I don't know other friends but... I'm loosing hope with you... ;)
Have you tried to install 5.0.007 from scratch? Can you imagine an image "incomplete" of what you say? As I wrote: we finally have the offline installer for each single subversion released (and I remember when you kept asking for a new installer more updated in the past) you claim it is incomplete.
Try again and if I'm wrong I'll apologise. Install OBH from scratch and, better if you don't import your current "Personal backup", just to be sure not to restore also a buggy setting.
Configure Internet for your box and go to the Addons section and check.
You do nothing this file is what the software update is using to find upgrades. It was just a test to see if your internet is blocking the OpenBH feeds.
We can now establish that is not a problem. So try from Terminal/Telnet/Putty and run the opkg update command. If you get any error message post them here.
Good morning to everyone,
My current version is 5.0.007.
Yesterday i noticed an update of about 250+ files but, after updating via Telnet, always 250+ updates available and always version 5.0.007.
The problem is in both my Vu+ duo 4k and solo 4k.
Inviato dal mio CPH2173 utilizzando Tapatalk
Why should be this a problem? "Update" does not mean always "change of version". What matters is that the updates exists, not the version number.
OBH5 is still at .007 even for Solo4K, for instance.
