openBH 0.4 Vu+ Duo2
nunigaia, thank you for the help,
Still the same, no idea where come from the openatv when i install the openBH
thank you
regards
Jose
I've just upgraded to 0.4 today and am loving it so far. I have one issue though, with kodi 16.1 RC. When I start Kodi up, it connects to my central mysql instance and all looks good until I go to play a video, the screen just goes black and the kodi.bin process takes up 80% cpu resource on the system. I've browsed the files and it looks like it is able to access the shared filesystem properly. I can play the same media files via the standard mediaplayer with obh 0.4, but I cannot seem to be able to play them via kodi.
Has anyone any suggestions I could try to get it working please, its the last little hicup I have with this image.
PS: There is no crash dump created so I cannot upload anything. When kodi gets into this state I need to physically power off/on the system to get it back.
Any tips/suggestions would be appreciated.
This still is not working for me with kodi 16.1 RC, with the OBH 0.1 image xbmc 15.2 worked like a charm, has anyone got any ideas where I can look to try debug it? Where is the kodi log file kept? It's usually in ~/.kodi/userdata/temp/kodi.log, but I dont see this on the obh 0.4 image anywhere, I checked /media/hdd/.kodi/userdata/temp, but there is nothing in there. Any ideas where I can find the log file to try and see what kodi is doing?
Just found this post in the "Kodi freezes box" thread:
Install the attached file by telnet, reboot your STB, and reply if it solves your issue.
Howto:
Upload this file to your STB, by using an FTP tool to:
/tmp/ folder:
by telnet run this commands ( one by one ):
opkg install --force-reinstall /tmp/*.ipk
reboot
Go to plugins browser and push Kodi to start ( try it ).
This is important for us, so please, don´t forget to reply.
thanks in advance
This worked for me, thank you!!
Can you post a screenshot of INFORMATION / ABOUT menu?
this happen when restarted the GUI.
Yesterday i decide to install the latest version of BH and just fine, after i installed the openbh and is just fine. i will try tomorrow to restart the GUI again to see if after reboot the openatv show up.
Regards
Jose
Hello, I have a problem since yesterday I have no more access to the network, no more by LAN (previously standard solution) than trying to use WLAN.
What happens ?
I use DHCP on my DUO2 and my router have fixed DHCP address (associated with MAC id), a ping from my PC or from my tablet doesn't respond.
Corto40 - I had the same problem, There are a lot of bugs in the version of OBH. I reported a problem with BlindScan which part way through crashes, Was told to wait for update this was over 2 weeks ago. I downgraded to the previous version now all ok.
Support you need to sort out these problems. I purchased this sat rx because it had Blindscan. Now on the latest version it no longer works, I hate to say it but support is not as good as it used to be. I like Blackhole software or I would be looking at another system, so come on get networks and Blindscan sorted.
How can I fix the problem to skip forward o bacward butto on VOD files iptv?
I try with 3/6/9 buttons, but let me switch only the channel and not to go forward.
I'm running 0.4 for vu+ solo2 image in boot.
I have a problem with Open Blackhole 0.4 on my Vu+ Duo 2.
When I run Media Player from Plugins I get a blue screen and the box crashes and restarts.
Here you go, this is the only way it would let me send the log file. cheers.
</openBH> </crashlogs> </enigma2crashlog>]]>20:31:02.242 [ E ] python/python.cpp:209 call (PyObject_CallObject(<bound method ActionMap.action of <Components.ActionMap.ActionMap instance at 0x61bd5d00>>,('SetupActions', 'ok')) failed)20:31:02.241 { D } NameError: global name 'SCOPE_ACTIVE_SKIN' is not defined20:31:02.241 { D }  File "/usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/plugin.py", line 60, in applySkin20:31:02.241 { D }  File "/usr/lib/enigma2/python/Components/GUISkin.py", line 30, in createGUIScreen20:31:02.240 { D }  File "/usr/lib/enigma2/python/Components/GUISkin.py", line 114, in applySkin20:31:02.240 { D }  dlg.applySkin()20:31:02.239 { D }  File "/usr/lib/enigma2/python/mytest.py", line 288, in doInstantiateDialog20:31:02.239 { D }  return self.doInstantiateDialog(screen, arguments, kwargs, self.desktop)20:31:02.239 { D }  File "/usr/lib/enigma2/python/mytest.py", line 259, in instantiateDialog20:31:02.238 { D }  dlg = self.current_dialog = self.instantiateDialog(screen, *arguments, **kwargs)20:31:02.238 { D }  File "/usr/lib/enigma2/python/mytest.py", line 321, in open20:31:02.237 { D }  File "/usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/plugin.py", line 1149, in mainCheckTimeshiftCallback20:31:02.237 { D }  File "/usr/lib/enigma2/python/Tools/BoundFunction.py", line 9, in __call__20:31:02.237 { D }  File "/usr/lib/enigma2/python/Components/Timeshift.py", line 567, in checkTimeshiftRunning20:31:02.236 { D }  File "/usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/plugin.py", line 1152, in main20:31:02.236 { D }  File "/usr/lib/enigma2/python/Screens/PluginBrowser.py", line 176, in run20:31:02.236 { D }  File "/usr/lib/enigma2/python/Screens/PluginBrowser.py", line 172, in save20:31:02.235 { D }  File "/usr/lib/enigma2/python/Components/ActionMap.py", line 48, in action20:31:02.235 { D } Traceback (most recent call last):20:31:02.234 { W } Components/GUISkin.py:35 createGUIScreen warning, skin is missing element currenttext in <class 'Plugins.Extensions.MediaPlayer.plugin.MediaPlayer'>20:31:02.233 { W } Components/GUISkin.py:35 createGUIScreen warning, skin is missing element genre in <class 'Plugins.Extensions.MediaPlayer.plugin.MediaPlayer'>20:31:02.231 { W } Components/GUISkin.py:35 createGUIScreen warning, skin is missing element repeat in <class 'Plugins.Extensions.MediaPlayer.plugin.MediaPlayer'>20:31:02.231 { W } Components/GUISkin.py:35 createGUIScreen warning, skin is missing element genretext in <class 'Plugins.Extensions.MediaPlayer.plugin.MediaPlayer'>20:31:02.224 { W } Components/GUISkin.py:35 createGUIScreen warning, skin is missing element PositionGauge in <class 'Plugins.Extensions.MediaPlayer.plugin.MediaPlayer'>20:31:02.223 {  } Components/ServicePosition.py:164 setSeekPosition set instance.20:31:02.223 {  } Components/ServicePosition.py:161 setSeekPosition set seek position: 020:31:02.171 {  } skin.py:1034 readSkin [SKIN] processing screen MediaPlayer:20:31:02.128 { W } skin.py:315 applyAll [Skin] Attribute not implemented: alphatest value: blend20:31:02.036 {  } skin.py:1034 readSkin [SKIN] processing screen MoviePlayer:20:31:01.957 [  ] dvb/dvb.cpp:1254 DVBChannelStateChanged start release channel timer20:31:01.949 <  > dvb/decoder.cpp:786 stop DEMUX_STOP - ttx - ok20:31:01.942 <  > dvb/decoder.cpp:201 unfreeze AUDIO_CONTINUE - ok20:31:01.942 <  > dvb/decoder.cpp:165 stop DEMUX_STOP - audio - ok20:31:01.917 <  > dvb/decoder.cpp:157 stop AUDIO_STOP - ok20:31:01.914 <  > dvb/decoder.cpp:422 stop VIDEO_STOP - ok20:31:01.907 <  > dvb/decoder.cpp:413 stop DEMUX_STOP - video - ok20:31:01.907 <  > dvb/decoder.cpp:710 stop DEMUX_STOP - pcr - ok20:31:01.907 [  ] dvb/decoder.cpp:815 setState decoder state: play, vpid=-1, apid=-1, pcrpid=-120:31:01.898 [  ] dvb/cahandler.cpp:474 ~eDVBCAService [eDVBCAService] free service 1:0:1:A2B:1A:F020:FFFF0000:0:0:0:20:31:01.897 [  ] dvb/cahandler.cpp:329 unregisterService [eDVBCAService] free slot 0 demux 0 for service 1:0:1:A2B:1A:F020:FFFF0000:0:0:0:20:31:01.865 {  } skin.py:1034 readSkin [SKIN] processing screen Screensaver:20:31:01.858 {  } Components/ActionMap.py:46 action action ->  SetupActions ok20:31:01.857 {  } Screens/InfoBarGenerics.py:204 actionA KEY: 352 0 KEY_OK OK20:31:01.850 [  ] driver/rcinput.cpp:23 handleCode 1 160 120:31:00.923 {  } Screens/InfoBarGenerics.py:204 actionA KEY: 103 1 KEY_UP UP20:31:00.922 [  ] driver/rcinput.cpp:23 handleCode 0 67 120:31:00.692 {  } Screens/InfoBarGenerics.py:204 actionA KEY: 103 0 KEY_UP UP20:31:00.691 [  ] driver/rcinput.cpp:23 handleCode 1 67 120:30:58.797 {  } Screens/InfoBarGenerics.py:204 actionA KEY: 2 1 KEY_1 1ile /media/hdd/movie/20160329 1400 - ITV HD - Judge Rinder - .ts (vide20:30:58.795 [  ] driver/rcinput.cpp:23 handleCode 0 2 120:30:58.789 {  } Plugins/Extensions/MediaScanner/plugin.py:7 execute execute ('View Movies...', <Scanner Movie>, [<ScanFile /media/hdd/movie/20150313 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20160107 1400 - ITV HD - Judge Rinder - .ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20160518 1400 - ITV HD - Judge Rinder - .ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20150325 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20160513 2235 - BBC One HD - The Graham Norton Show - .ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20160527 1030 - Sky Premiere HD - Self_Less - .ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20151231 2135 - ITV HD - Birds of a Feather - .ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20150427 0938 - Animal Planet CE - MÆ pekelnÆ koŁka.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20150326 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20151012 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20151124 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20150218 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20131217 1630 - BBC Two HD - Are You Being Served_.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20150423 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20160112 1400 - ITV HD - Judge Rinder - .ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20151022 2110 - Extreme Sports HD - Best of Pride.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20150123 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20150415 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20150121 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20151211 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanF20:30:58.616 {  } Screens/Screen.py:150 show [SCREENNAME]  PluginBrowser20:30:58.563 {  } Screens/Screen.py:150 show [SCREENNAME]  PluginBrowserSummary20:30:58.560 { W } Components/ActionMap.py:53 action unknown action InputActions/1! typo in keymap?20:30:58.560 {  } Components/ActionMap.py:46 action action ->  InputActions 120:30:58.559 {  } Screens/InfoBarGenerics.py:204 actionA KEY: 2 0 KEY_1 120:30:58.557 [  ] driver/rcinput.cpp:23 handleCode 1 2 120:30:55.180 {  } Screens/InfoBarGenerics.py:204 actionA KEY: 352 1 KEY_OK OK20:30:55.178 [  ] driver/rcinput.cpp:23 handleCode 0 160 120:30:55.174 {  } Screens/Screen.py:150 show [SCREENNAME]  ['ChoiceBox']20:30:55.173 {  } Screens/Screen.py:150 show [SCREENNAME]  ['ChoiceBox_summary', 'SimpleSummary']20:30:55.169 {  } skin.py:1034 readSkin [SKIN] processing screen ChoiceBox_summary:20:30:55.154 {  } skin.py:1034 readSkin [SKIN] processing screen ChoiceBox:20:30:54.279 {  } Components/Scanner.py:107 scanDevice scanner: [<Scanner Ipkg>, <Scanner Movie>, <Scanner Video CD>, <Scanner Music>, <Scanner Audio-CD>, <Scanner Pictures>, <Scanner DVD>]20:30:54.277 {  } Plugins/Extensions/MediaScanner/plugin.py:20 mountpoint_choosen scanning ('WDC WD40EFRX-68W\t/media/hdd/', '/media/hdd/', <__main__.Session instance at 0x5f1be698>)20:30:54.109 {  } Screens/Screen.py:150 show [SCREENNAME]  PluginBrowser20:30:54.056 {  } Screens/Screen.py:150 show [SCREENNAME]  PluginBrowserSummary20:30:54.054 {  } Components/ActionMap.py:46 action action ->  WizardActions ok20:30:54.053 { W } Components/ActionMap.py:53 action unknown action WizardActions/ok! typo in keymap?20:30:54.053 {  } Components/ActionMap.py:46 action action ->  WizardActions ok20:30:54.051 {  } Screens/InfoBarGenerics.py:204 actionA KEY: 352 0 KEY_OK OK20:30:54.050 [  ] driver/rcinput.cpp:23 handleCode 1 160 120:30:51.815 {  } Screens/InfoBarGenerics.py:204 actionA KEY: 352 1 KEY_OK OK20:30:51.814 [  ] driver/rcinput.cpp:23 handleCode 0 160 120:30:51.570 {  } Screens/Screen.py:150 show [SCREENNAME]  ['ChoiceBox']20:30:51.568 {  } Screens/Screen.py:150 show [SCREENNAME]  ['ChoiceBox_summary', 'SimpleSummary']20:30:51.565 {  } skin.py:1034 readSkin [SKIN] processing screen ChoiceBox_summary:20:30:51.550 {  } skin.py:1034 readSkin [SKIN] processing screen ChoiceBox:20:30:51.534 {  } Components/ActionMap.py:46 action action ->  SetupActions ok20:30:51.533 {  } Screens/InfoBarGenerics.py:204 actionA KEY: 352 0 KEY_OK OK20:30:51.532 [  ] driver/rcinput.cpp:23 handleCode 1 160 120:30:48.017 {  } Screens/InfoBarGenerics.py:204 actionA KEY: 352 1 KEY_OK OKile /media/hdd/movie/20160329 1400 - ITV HD - Judge Rinder - .ts (vide20:30:48.015 [  ] driver/rcinput.cpp:23 handleCode 0 160 120:30:48.009 {  } Plugins/Extensions/MediaScanner/plugin.py:7 execute execute ('View Movies...', <Scanner Movie>, [<ScanFile /media/hdd/movie/20150313 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20160107 1400 - ITV HD - Judge Rinder - .ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20160518 1400 - ITV HD - Judge Rinder - .ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20150325 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20160513 2235 - BBC One HD - The Graham Norton Show - .ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20160527 1030 - Sky Premiere HD - Self_Less - .ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20151231 2135 - ITV HD - Birds of a Feather - .ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20150427 0938 - Animal Planet CE - MÆ pekelnÆ koŁka.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20150326 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20151012 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20151124 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20150218 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20131217 1630 - BBC Two HD - Are You Being Served_.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20150423 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20160112 1400 - ITV HD - Judge Rinder - .ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20151022 2110 - Extreme Sports HD - Best of Pride.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20150123 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20150415 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20150121 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanFile /media/hdd/movie/20151211 1400 - ITV HD - Judge Rinder.ts (video/MP2T, None MB)>, <ScanF20:30:47.818 {  } Screens/Screen.py:150 show [SCREENNAME]  PluginBrowser20:30:47.765 {  } Screens/Screen.py:150 show [SCREENNAME]  PluginBrowserSummary20:30:47.762 {  } Components/ActionMap.py:46 action action ->  WizardActions ok20:30:47.762 { W } Components/ActionMap.py:53 action unknown action WizardActions/ok! typo in keymap?20:30:47.762 {  } Components/ActionMap.py:46 action action ->  WizardActions ok20:30:47.761 {  } Screens/InfoBarGenerics.py:204 actionA KEY: 352 0 KEY_OK OK20:30:47.760 [  ] driver/rcinput.cpp:23 handleCode 1 160 120:30:45.874 [  ] base/ebase.cpp:290 processOneEvent poll: unhandled POLLERR/HUP/NVAL for fd 109(8)20:30:45.873 [!W!] dvb/demux.cpp:294 data ERROR reading PES (fd=109) - Value too large for defined data type20:30:45.872 {  } Screens/InfoBarGenerics.py:204 actionA KEY: 352 1 KEY_OK OK20:30:45.871 [  ] driver/rcinput.cpp:23 handleCode 0 160 120:30:45.848 {  } Screens/Screen.py:150 show [SCREENNAME]  ['ChoiceBox']20:30:45.847 {  } Screens/Screen.py:150 show [SCREENNAME]  ['ChoiceBox_summary', 'SimpleSummary']20:30:45.844 {  } skin.py:1034 readSkin [SKIN] processing screen ChoiceBox_summary:20:30:45.829 {  } skin.py:1034 readSkin [SKIN] processing screen ChoiceBox:20:30:39.683 [  ] gdi/grc.cpp:194 thread main thread is non-idle! display spinner!20:30:36.019 {  } Components/Scanner.py:107 scanDevice scanner: [<Scanner Ipkg>, <Scanner Movie>, <Scanner Video CD>, <Scanner Music>, <Scanner Audio-CD>, <Scanner Pictures>, <Scanner DVD>]20:30:36.017 {  } Plugins/Extensions/MediaScanner/plugin.py:20 mountpoint_choosen scanning ('WDC WD40EFRX-68W\t/media/hdd/', '/media/hdd/', <__main__.Session instance at 0x5f1be698>)20:30:35.841 {  } Screens/Screen.py:150 show [SCREENNAME]  PluginBrowser20:30:35.788 {  } Screens/Screen.py:150 show [SCREENNAME]  PluginBrowserSummary20:30:35.785 {  } Components/ActionMap.py:46 action action ->  WizardActions ok20:30:35.785 { W } Components/ActionMap.py:53 action unknown action WizardActions/ok! typo in keymap?20:30:35.784 {  } Components/ActionMap.py:46 action action ->  WizardActions ok20:30:35.783 {  } Screens/InfoBarGenerics.py:204 actionA KEY: 352 0 KEY_OK OK20:30:35.782 [  ] driver/rcinput.cpp:23 handleCode 1 160 120:30:31.875 {  } Screens/InfoBarGenerics.py:204 actionA KEY: 352 1 KEY_OK OK20:30:31.874 [  ] driver/rcinput.cpp:23 handleCode 0 160 120:30:31.638 {  } Screens/Screen.py:150 show [SCREENNAME]  ['ChoiceBox']20:30:31.637 {  } Screens/Screen.py:150 show [SCREENNAME]  ['ChoiceBox_summary', 'SimpleSummary']20:30:31.633 {  } skin.py:1034 readSkin [SKIN] processing screen ChoiceBox_summary:20:30:31.618 {  } skin.py:1034 readSkin [SKIN] processing screen ChoiceBox:20:30:31.603 {  } Components/ActionMap.py:46 action action ->  SetupActions ok20:30:31.601 {  } Screens/InfoBarGenerics.py:204 actionA KEY: 352 0 KEY_OK OK20:30:31.600 [  ] driver/rcinput.cpp:23 handleCode 1 160 120:30:30.120 {  } Screens/InfoBarGenerics.py:204 actionA KEY: 352 1 KEY_OK OK20:30:30.117 [  ] driver/rcinput.cpp:23 handleCode 0 160 120:30:29.939 {  } Screens/Screen.py:150 show [SCREENNAME]  PluginBrowser20:30:29.885 {  } Screens/Screen.py:150 show [SCREENNAME]  PluginBrowserSummary20:30:29.882 {  } Components/ActionMap.py:46 action action ->  MsgBoxActions ok20:30:29.881 {  } Screens/InfoBarGenerics.py:204 actionA KEY: 352 0 KEY_OK OK20:30:29.880 [  ] driver/rcinput.cpp:23 handleCode 1 160 120:30:28.564 {  } Screens/InfoBarGenerics.py:204 actionA KEY: 352 1 KEY_OK OK20:30:28.563 [  ] driver/rcinput.cpp:23 handleCode 0 160 120:30:28.561 {  } Screens/Screen.py:150 show [SCREENNAME]  ['MessageBoxSimple']20:30:28.559 {  } Screens/Screen.py:150 show [SCREENNAME]  ['MessageBoxSimple_summary', 'SimpleSummary']20:30:28.554 {  } skin.py:1034 readSkin [SKIN] processing screen MessageBoxSimple_summary:20:30:28.532 {  } skin.py:1034 readSkin [SKIN] processing screen MessageBoxSimple:20:30:28.520 {  } Components/Scanner.py:107 scanDevice scanner: [<Scanner Ipkg>, <Scanner Movie>, <Scanner Video CD>, <Scanner Music>, <Scanner Audio-CD>, <Scanner Pictures>, <Scanner DVD>]20:30:28.516 {  } Plugins/Extensions/MediaScanner/plugin.py:20 mountpoint_choosen scanning ('homeNASF62651', '/media/net/homeNASF62651', <__main__.Session instance at 0x5f1be698>)20:30:28.338 {  } Screens/Screen.py:150 show [SCREENNAME]  PluginBrowser20:30:28.282 {  } Screens/Screen.py:150 show [SCREENNAME]  PluginBrowserSummary20:30:28.279 {  } Components/ActionMap.py:46 action action ->  WizardActions ok20:30:28.279 { W } Components/ActionMap.py:53 action unknown action WizardActions/ok! typo in keymap?tions ok <![CDATA[ <enigma2crashlog> <crashlogs> </image> </imageissue>]]>openbh 0.4 %h <![CDATA[ <imageissue> </imageversion>]]>catalog=http://www.vuplus-community.neturl=http://www.vuplus-community.netcreator=BlackHoletarget=9comment=openBHdate=20160324015536build=0version=0.4build_type=0box_type=vuduo2 <![CDATA[ <imageversion> <nimsockets>NIM Socket 0:</nimsockets> <kernelcmdline>libata.force=1:1.5Gbps bmem=192M@64M bmem=384M@512M memc1=788M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync</kernelcmdline> </kernelversion>]]>Linux vuduo2 3.13.5 #1 SMP Tue Mar 22 21:24:33 CET 2016 mips GNU/Linux <![CDATA[ <kernelversion> <stbmodel>duo2</stbmodel> <image> </enigma2> <version>3.0.0</version> <sourcedate>2016-03-30</sourcedate> <skin>SkyQ/skin.xml</skin> <!-- Please email this crashlog to above address --> <contactemail>forum at " target="_blank" class="externalLink ProxyLink" data-proxy-href="http://www.vuplus-community.net
" rel="nofollow">www.vuplus-community.net</contactemail> <compiledate>Apr 28 2016</compiledate> <crashdate>Mon Jun 20 20:31:02 2016</crashdate> <enigma2><openBH><?xml version="1.0" encoding="utf-8"?>
Hi, sorry first time ive uploaded a crashlog is this better.
Thanks.
Your issue is not caused by Mediaplayer, but by a skin not supported ( SkyQ ) that results incompatible with image and severall plugins.
Change the skin to, and use MX skins for OpenBH 04 only. Of course you can use others, but we don´t support them ( use at your own risk ).
Anyway, thanks for the crash upload.
