openBH 0.4 Vu+ Solo2
I'm using OBH version 0.1 now, is this version 0.4 the best one for IPTV performance?
Which is the best image overall for IPTV?
Thanks
I also would like to change the buttons exactly as you did.
Can you point me to the version of multiquickbutton you installed??
Thanks
EDIT -
No need for the plugin, OBH 0.4 is highly customizeable, you can change button settings through:
SETUP --> USER INTERFACE --> BUTTON LAYOUT
I could achieve the requested changes without the need of any plugin.
which openmultiboot is newer...in latest BH or in latest OpenBH ?
r
AFAIK, they are the same version @Meo moded version for BlackHole team.
Note: I'm using in my Duo2 Blackhole 3.0.2F in Flash. And severall images in OpenMultiboot and i have no issues, i can boot:
OpenBH 04
Open BlackHole 01
BlackHole 3.0.2F
OpenVIX 4.1
OpenPli 4.0
OpenSpa 5.0
OpenSpa 6.0
Vti 9.0.3
Vuplus OE 3.0 original image
etc ...
Kodi have the same problem like as BH 3.0.x... Did you plan to fix screen resolution?
Resolution fix? What resolution, afaik, kodi is running in full screen in BlackHole 3.0.2F and OpenBH 04.
ATM, there´s nothing to fix.
You are referring to BlackHole 3.0.2C ... upgrade to BlackHole 3.0.2F ( online update ), all should be fixed ....
Note: This is valid to OpenBH 04 ... Upgrade your image using the same steps.
Thank you, but I already do this (flash BlackHole 3.0.2F/OpenBlackHole 0.4 & upgrade from online update), and still have the same problem whit Kodi.
Can you please upload the plugin.py file you have in Kodi 16.1RC2 ( BlackHole 3.0.2F )?
Ftp to your STB ... and navigate to:
/usr/lib/enigma2/python/Plugins/Extensions/Kodi
download the plugin.py file there, " zip it " an upload it here.
From BlackHole 3.0.2F
