openBH 0.4 Vu+ Solo2
Okay i find it. THX.
How do I adjust the remote to my display my via ftp charged bouquets? In OPH 0.1 it was Channel + or -
Your question it´s not quiet clear ... although:
Ok - displays info menu.
2XOk - displays 2nd infobar.
Arrow key(s) up and down ... display channels list.
Arrow key(s) up and down in channel list ... navigate through channel list
etc ...
Don´t be afraid to text the key(s) on your RCU ... press it to familiarize ... and to see some settings they have to acess context menus.
etc ...
Yes, but this was different in OBH 0.1. And I'll be fine, but the rest of the family has become accustomed to the use of 0.1.
The keyboard layout can be, unfortunately, so do not change as in 0.1
then I will probably unfortunately have to return, although I really like the wide range of settings in 0.4
moder
moder
If you like it... in one week all your family should work normally with this version.
hello! black hole bootlogo,don't work,i cant change another bootlogo.thank's
This is not an issue ... Although you can open another thread and i can, when have a spare time, add existent bootlogos by requesting.
OpenBH, AFAIK, only has one bootlogo.
thanks
I just installed Obh.4 and am very happy with it, thanks to bhTeam. I have solo2 with a hdd. I downloaded the picons from this site and Obh and still cant see them in my service list. I just don't know what is wrong. I tried to copy them using DCC didn't work. would please somebody help ! Thank you ...
Hi! Put the picons on hard disk into /picon folder
I think he means this --> http://www.vuplus-community.net/board/threads/howto-show-picons-in-channel-list-obh-04.28184/
