openBH 0.4 Vu+ Solo2
When i change chanel i want to see channel ferequency
How can i set it without ok button
I could this feature in blackhole inage
But in open black hole i dont know how can i change it osd setting
Thanks
Thanks
You can't.
This is not the BlackHole image.
It is a very different image.
You can't.
Unfortunatelly this features was important for me
Please find any way to use this features
I want to see when i zap chanel show ferequency chanel and resulution in infobar same blackhole image
I have replaced the "InfoBar" section to "SecondInfoBar" section in /usr/share/enigma2/MX_HQ10/skin.xml and it works perfetctly (from line 144 and from line 379).
I have problem with 4:3 video content whore-ever I setup -just scale or pan scan than green and restart gui also hardreset picture is same do not accept changes .Can suggest me some solution
I have tried, what you wrote, and its work for me.
Can I ask is there a easy way to get a channel list ie sports movies etc
Thanks in advance I have looks
cannot install SAMBA or NFS, says installed but not showing as running and when you go into SAMBA / NFS it wants to reinstall?
Because of the problem mentioned in Post #38, I decided to go back to a backup of BH 3.0.1 F.
I noticed that when I restored the backup, at first the Image did not open at all.
Then I reflashed the BH 3.0.1 F Raw Image followed by my backup and now everything works fine.
