openBH 0.4 Vu+ Solo2
IMO not. Its another normal heavy image. OpenBH 0.1 it was different. It was fastest image ever and have good funcionality.
Never good,
when there are more options and when there is less :D
I can not notice such a huge difference in performance
truth usually I tested with duo2 and solo 4K
And there's a slight difference, which many do not even notice ..
Never good,
But we also have normal image BH 3.0.1 <- Mercedes, OpenBH 0.1 is a Ferrari.
This is only my opinion.
BH is Ferrari >> :D
But if you need IPTV channels from the list and other options
then it is OBH with so many options.
Even so with good performance.
Hi. Really good work. I have a problem with A867 LED BLU DTT tuner. I tried to install as before with code:
opkg install kernel-module-af9033
opkg install kernel-module-mxl5007t
reboot
but this time doesn't work. Can you help me? Thanks.
reboot
On your RCU, press:
<GREEN>; <YELLOW>; choose <Addons download Manager>; <BlackHole Feeds Plugins>; <Drivers>;
Install it and reboot your STB.
First of all, thanks a lot for the image, it's a good one!
1. Somebody here knows if the plugin "mhw2epgdownloader. E2. Plugin" works right with this image? (
http://team.tododream.com/mhw2epgdownloader/enigma2-plugin-mhw2epgdownloader_1.0.7_mipsel.ipk
I've tried to install it (pkg install) but it's not shown in Crossepg panel configuration (as MHW2 provider).
2. I get each time I (re)boot the vuplus solo2 an error about missed or corrupted satellittes.xml file... and I've favourites, channel lists, etc. running ok ¿?
Thnx in advance! Cheers
Thanks to the BH Team.
But i have a short question
Is it ok that i couldn`t find any Plugins in the download Manager?
There is nothing inside
Very interesting Image. Using Solo2.
But when using A867 usb stick and zap from Terrestrial to Sat Channel it is ok whilst zapping from Sat to Terrestrial the Image hangs miserably and have to reboot. Any suggestions please?
Is there a way to disable light skin on zap and disable video on chanel list?
There is a 10 sec laggy when I swith from sat to dtt.
