openBH 0.4 Vu+ Zero
Hello in attach the screen of the error for dgt usb. How can I do for to solve this problem? And yes, after trying to install the drivers I restarted the dec, but nothing.
Thank you very much
Thank you very much
Can you try please, make an Online update first?
Press in your RCU:
<GREEN>; <YELLOW>; and choose <ONLINE BLACK HOLE IMAGE UPDATE>.
After that, retry to install the device drivers.
Yes, in my first post I've try this:
opkg install kernel-module-af9033
opkg install kernel-module-mxl5007t
reboot
but nothing. After I've tryed green+yellow and.. same problem
I think the problem is the build of the driver ipk file.
try first by telnet:
opkg update
opkg upgrade
killall -9 enigma2
opkg install kernel-module-dvb-usb-a867
opkg install enigma2-plugin-drivers-dvb-usb-a867
reboot
or try this one: ( alternative solution )
opkg install kernel-module-dvb-usb-af9035
opkg install firmware-dvb-usb-af9035-02
reboot
opkg update
opkg upgrade
killall -9 enigma2
reboot
reboot
Hello I tryed following your instruction but nothing I see only sat tuner and not digital key. the blue LED is off. I also changed digital key, but the result does not change. In attach the screen of telnet
Thank you
Thank you
Have you solved your dtt connection? Is your dtt device working properly for now?
with this code:
reboot
Please reply, and let us know. ;)
with this code:
reboot
No :-( nothing, when I go in Tuner I see only sat tuner sigh!
with this code:
reboot
I followed the instructions but dtt A867 is not recognized, while with BH 3.x is automatically recognized
opkg update
opkg upgrade
killall -9 enigma2
reboot
reboot
openbh 0.4 vuzero
vuzero login: root
root@vuzero:~# opkg upgrade
Upgrading enigma2-plugin-extensions-mediascanner from 5.1+git22517+66ba228-r2 to
5.1+git22520+04fbf6d-r2 on root.
Downloading http://feeds.vuplus-community.net/openbh/0.4/vuzero/vuzero/enigma2-p
lugin-extensions-mediascanner_5.1+git22520+04fbf6d-r2_vuzero.ipk.
Configuring enigma2-plugin-extensions-mediascanner.
root@vuzero:~# killall -9 enigma2
root@vuzero:~# opkg install kernel-module-dvb-usb-a867
Unknown package 'kernel-module-dvb-usb-a867'.
Collected errors:
* opkg_install_cmd: Cannot install package kernel-module-dvb-usb-a867.
root@vuzero:~# opkg install enigma2-plugin-drivers-dvb-usb-a867
Installing enigma2-plugin-drivers-dvb-usb-a867 (1.0-r2) on root.
Downloading http://feeds.vuplus-community.net/openbh/0.4/vuzero/all/enigma2-plug
in-drivers-dvb-usb-a867_1.0-r2_all.ipk.
Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for enigm
a2-plugin-drivers-dvb-usb-a867:
*  kernel-module-dvb-usb-a867 *
* opkg_install_cmd: Cannot install package enigma2-plugin-drivers-dvb-usb-a867.
What files are you using to install it on BlackHole 3.0.1F?
I don't have Zero, but probably we could try to make it work.
Can you replicate the installation, by command line ... to see what is missing ( of course in BlackHole 3.0.1F ).
