openBH 0.4 Vu+ Zero
What files are you using to install it on BlackHole 3.0.1F?
I don't have Zero, but probably we could try to make it work.
Can you replicate the installation, by command line ... to see what is missing ( of course in BlackHole 3.0.1F ).
BlackHole 3.0.1 vuzero
vuzero login: root
root@vuzero:~# opkg update
Downloading http://feeds.vuplus-community.net/3rd-party-settings/Packages.gz.
Inflating http://feeds.vuplus-community.net/3rd-party-settings/Packages.gz.
Updated list of available packages in /var/lib/opkg/official-3rd-party-settings.
Downloading http://feeds.vuplus-community.net/3.0.1/vuzero/all/Packages.gz.
Inflating http://feeds.vuplus-community.net/3.0.1/vuzero/all/Packages.gz.
Updated list of available packages in /var/lib/opkg/official-all.
Downloading http://feeds.vuplus-community.net/3.0.1/vuzero/mips32el/Packages.gz.
Inflating http://feeds.vuplus-community.net/3.0.1/vuzero/mips32el/Packages.gz.
Updated list of available packages in /var/lib/opkg/official-mips32el.
Downloading http://feeds.vuplus-community.net/3.0.1/vuzero/vuzero/Packages.gz.
Inflating http://feeds.vuplus-community.net/3.0.1/vuzero/vuzero/Packages.gz.
Updated list of available packages in /var/lib/opkg/official-vuzero.
root@vuzero:~# killall -9 enigma2
root@vuzero:~# opkg install kernel-module-dvb-usb-a867
Unknown package 'kernel-module-dvb-usb-a867'.
Collected errors:
* opkg_install_cmd: Cannot install package kernel-module-dvb-usb-a867.
root@vuzero:~# opkg install enigma2-plugin-drivers-dvb-usb-a867
Unknown package 'enigma2-plugin-drivers-dvb-usb-a867a867'.
Collected errors:
* opkg_install_cmd: Cannot install package enigma2-plugin-drivers-dvb-usb-a867a
867.
root@vuzero:~#
Then I turned off the box I put a867 into USB port, I turned on box and a867 automatically lit and it works perfectly
kernel problem like OpenPli ?
Still no solutions to manage the A867 (Sky DTT original)? I've tried everything but the best result is that OBH 0.6 (updated) recognises it but it's not able to tune anything.
I had a867 blu led and was recognized in OBH 0.6 .
In SERVICE SEARCHING -.---- Tuner configuration check your country for DTT receiver and change it
Obviously that was done, as always. As I wrote, the devise IS IS recognised, but it doesn't tune. And I haven't tried just the usual Europe DVB-T but also many other DVB-T settings.
Scusate ma solo a me una volta installata questa versione NON mi vede più la chiavetta USB Digitale Terrestre???
Sbaglio io qualcosa??
Grazie in anticipo!!
Intanto, non esiste LA chiavetta, ma ne esistono una pletora. Se ti riferisci, poi alla chiavetta Sky, si evidenzia qui proprio che non va con OBH, non solo 0.4 ma anche successive (anche se qualche fortunato è riuscito, con una procedura manuale, a farla funzionare). Ho visto che lo stesso accade con OpenPli, OpenATV e OpenVix, evidentemente con gli stessi driver e con lo stesso problema in fase d'installazione.
Per la cronaca, nonostante venga riconosciuta da BH e OBH come A867, si legge altrove che i driver da utilizzare siano gli A9035 ma questo, almeno a me, non ha risolto.
Per cui sarò stato "pletoriamente" fortunato perché a me la USB digitale terrestre Sky adesso mi funziona perfettamente sulla OBH 0.6!! Ma grazie ad ogni modo!!!
Ne sono contento. Ma hai fatto qualcosa di nuovo per farla riconoscere (e funzionare, perché anche a me la riconosce ma poi non sintonizza)? Oppure è successo dopo qualche aggiornamento? Fino a ieri ho provato inutilmente.
Ciao, io ho due Zero e sono stato uno dei fortunati, ma per i meno fortunati, qual'è la chiavetta usb funzionante? Non voglio credere bisogna affidarsi al caso.
Ciao e grazie
p.s. la procedura che ho seguito è la seguente, dopo aver installato l'immagine SENZA usb collegata, ed aver fatto tutto il wizard di configurazione, sono andato nei plugin ed ho installato i driver a867, a questo punto, CON IL DEC ancora acceso ho inserito la usb ed il led blu si è acceso. Solo a questo punto ho riavviato il dec ed una volta finito il boot e riavviato mi vedeva la DGT e funzionava regolarmente.
Ciao ho un vu+ zero con a867 blu ho installato obh 0.6 e me la riconoscuta subito senza installarlo nessun driver,unico problema di questo imagine e che va ogni tanto in crash,adesso lo provo con obh 0.4 e lo faro sapere.
Ma... ho la sensazione che, più ancora che l'immagine, conti il ricevitore, specie nel caso del Solo4k che ha un processore diverso (ArmV7). Quindi la domanda è: chi ha un Solo4K e una DVB-T Sky che funzioni sotto OBH 0.6?
Scusate ma volendo evitare di perdere tutto sto tempo con fare prove con a867, sky dgt etc etc qual'è una usb che viene riconosciuta al 100% da OBH e dove poterla acquistare?
Ripeto: chiedere solo quale USB tuner funzioni penso non sia sufficiente. Se alcuni riescono a far funzionare un dispositivo e altri no, è probabile sia dovuto anche al modello di VU+ posseduto e non solo all'immagine, specie (forse) nel caso del Solo4K che ha un processore diverso.
