OpenBH 0.6 Vu+ Duo2
Hello guys
I have a problem with , the image doesn't does not include YouTube TV.
I tried to install the plugin manually with no success!!
kindly Is there a way to add YouTube TV extension to OpenBH 0-6 ?
Hello guys
YouTube TV is included in the image.
Main Menu >> YouTube TV
Install and Update image >> Green>>Yellow>>Obh online update.
It is part of the Opera - HbbTv package, so you need to install that in the speedup panel for Youtube Tv to be installed.
It's not there , i even reinstall the image with no luck.
though the YouTube TV setting is on the plugin panel ??
Hi all,
I've noticed that the option to have 4 or 5 Channel numbering option (i.e. if you have 10000 + channels) is no longer available in 0.6 version? It was there in 0.4 in the Channel Selection Settings Menu ...
Can this be added in an on-line update or will i have to wait for new Image version (0.8???)
Thanks
Nitemare. :)
Hi all,
Thanks
Nitemare. :)
Hopefully this will be added in the next online update :)
Does anybody really use the Animations though ?
Of course - one of the favorite OBH features :yahoo: But if seriously, I'm pressing everything in succession, when translating Menus. Cannot translate, when do not see the real purpose of phrases
Hi all,
Thanks
Nitemare. :)
Has this been implemented? I did the on-line update yesterday but this option still isn't back??
Thanks.
Hi all,
Thanks
Nitemare. :)
Thanks.
Yes it has been implemented.
There is no option to select 4 or 5, you can just enter 5 digits now.
It works fine for me, on Duo2 and Solo4K
I assume you have not used the alt channel numbering ?
Channel Selection Menu / Alternative numbering mode / Set to "NO"
and i still can't input 5 digits directly on RC to access channels 10000+ ???
I did on-line update yesterday but I'm afraid this option sill eludes me? Weird?
