OpenBH 0.6 Vu+ Duo2
Obh 0.6 (openbh-0.6-vuduo2-20160627_usb_release_dfa51a6.zip Last update: 2016-07-16)
Online update is not working ?
What to do ?
Open Black Hole online Update :
There has been an error, please try again later. If this issue persists, please check vuplus-community.net
Open Black Hole Addons Plugins :
Ok
Black Hole Feeds Plugins :
Open Black Hole Image Skins :
Ok
Try using an FTP tool and via command line enter the following code:
opkg update && opkg upgrade
reboot
reboot
Thanks
Did that, but then i get this error when trying to "Open Black Hole online Update"
Error - A background update check is in progress, please wait a few minutes and try again
Then i did the "opkg/lists" cleanUp
/var/lib/opkg/lists
Delete all files in this folder
and the
reboot
again
Then the "Open Black Hole online Update" is not failing, but the response is "Nothing to update"
But still the Obh info is still:
Obh 0.6 (Last update: 2016-07-16) ???????????
Is it correct that there is no updates since 2016-07-16 ???
Best regards
Thanks
/var/lib/opkg/lists
and the
reboot
again
Best regards
Yes, the last update version is 2016-07-16.
If you got the message " Nothing to update", is that why there's no updates to do ATM.
You have a notify for updates that is a blink symbol, on the center of your Vfd display, if there is an update avaiable.
You can too, check the lastest updates done, if you take a look at your /home/root folder --> file ipkgupgrade.log, by ftp acess to your STB.
In this last period I found that almost everyday there is an online upgrade but the info does not reveal any change in kernel version, drivers and so on.
Just to be sure that something goes wrong where it announces that an update is available, where do I find a log of these updates? I look for it in root but I found nothing.
Some little updates are for example: autobouquet, imdb, etc... This are not updates for drivers, kernel, enigma2, etc ... are minor updates for some plugins embedded in image.
there is any way to configure the ok button of the remote control in other key because i have to push so hard to get reply
Hi,
thanks you for this image.
It's seem great ans stable. The remote controler works much better with this image !!!
Direct pause doesn't works on IPTV :-( On 0.4 it was possible to start the direct pause but it was unusable. It was working on 0.1.
I will try timer on IPTV later f to see if there have been improvements because on 0.4 it was not very stable.
I think 0.1 was the best for IPTV, for the rest 0.6 seems better.
regards
What to do ?
Ok
Ok
FYI:
The (OpenBH 0.6) Open Black Hole online Update has never been working for me ?
Keep getting ..
( Network nameserver test is confirmed OK )
Best regards
Press <MENU>; <BlackHole App´s>; <BlackHole Speed-Up>; Enable to install " Opera Browser and HBBTV app ".
It should install Youtube and HbbTV on your Duo2.
Thanks, but still can not find Youtube TV. Did as you recommended, but only change what i could notice is Youtube settings (under green button plugins).
With regards.
With regards.
You must go to extensions menu ( LONG Press ) BLUE BUTTON.
Thanks a lot! It did the trick!
Meantime would like to report a bug. If i do exit (push button "exit") without properly exiting Youtube in phone (in case it is pared), then vu+ box stuck forever and only way to exit is physical power off.
Anyway, thanks a lot for realy good image.
With regards
With regards
You must use to leave Youtube TV ( <RED> button on your RCU ).
im having problems to update with last update always crash and in the nex reboot still there is an update.
also i have lost audio on ac3 channels suddenly doesnt works.
There was an error in the software update, that has now been fixed.
To get the update you will need to use telnet and use this command:
Afterwards reboot your box.
i have to remove this image because im having problems with audio for bbc freeviwe on 27,5W i lost audio. Also channel button ok on rc works very bad
Blackhole has the same problems?
