OpenBH 0.6 Vu+ Duo2
i have to remove this image because im having problems with audio for bbc freeviwe on 27,5W i lost audio. Also channel button ok on rc works very bad
Blackhole has the same problems?
I have a Duo2. My original Duo2 Remote control has problems as you have posted in your post --> http://www.vuplus-community.net/board/threads/openbh-0-6-vu-duo2.29116/page-5#post-214321, but for me not the <OK> but the <down>; <up> arrow buttons. I´ve bought another ... an universa original vuplus remote ... and all is working as expected.
The other situation about audio in the service channel you are referring i can´t help you, because i don´t have this sat position.
It seems your RCU ( remote control unit ) is defective and need to be repaired or you have to buy a new one.
Hi,
i need help. Since the last online update the box crashes during the online update. Here is the log.
There was an error in the software update, that has now been fixed.
To get the update you will need to use telnet and use this command:
opkg update && opkg upgrade
Afterwards reboot your box.
Hello guys, two minor problem for me
1.I have an vu+duo2 with OPB 0.6. The aspect ratio switch plugin go in error with green (black) screen after initialization. In setup: enabled, help key long...
2. Message after I push Plugins button in Main menu: some plugins are not available Pli/******* Setup(No module named Pli SoftcamSetup Plugin)
Best regards
Best regards
1. I can´t reply for now, although this image can´t give you an GSOD ( Green Screen of Death ), but indeed a BSOD ( Blue screen of Death ).
2. I would like kindly invite you for reading our board rules. It´s not allowed any kind of discussion about illegal stuff. --> http://www.vuplus-community.net/rules.html
OpenBH 0.6
Minor issue:
Using "Off / On (RC)" when in "MovieSelection list" or while "playing a recording", the box starts without audio.
Audio is reestablished again, via exiting "MovieSelection list" and then doing "Off / On (RC)" again.
Best regards
OpenBH 0.6
Minor issue:
Best regards
Press the <MUTE> button 2X ( twice ), instead. You don´t need to leave the movie that is playing.
1. OK, I understood, I am waiting for an working aspect ratio switch plugin
2. Sorry, it is my mistake. I read the board rules...
Another question, if you may. Where is the place the lcd4linux config and skin_user files in OBH 0.6? And do you have any lcd4 configuration made by you?
For skin_user.xml, it is in /usr/share/enigma2/display folder and the file is named skin_display.xml.
Note: ( they are not the same xml file ), so the skin_user.xml from BlackHole images don´t work in OpenBH images.
The Lcd4config file you can use the " same config file from BlackHole images " and must be uploaded to /etc/enigma2 folder.
Thank you again for your promptitude
[Quote = "EV0, posta: 215.030, membro: 4715"] C'è stato un errore nell'aggiornamento del software, che ora è stato risolto.
Per ottenere l'aggiornamento è necessario usare telnet e utilizzare questo comando:
[codice]
aggiornamento opkg && aggiornamento opkg
[/codice]
Successivamente riavviare il sistema. [/ Quote]
Ciao ,ho eseguito le tue isruzioni con telnet ma mi da il messaggio command not found. Dove sbaglio? Aspetto suggerimenti.Grazie
[codice]
[/codice]
always the update has to be done by telnet? i try by menu and appear again a new update
Immettere i seguenti comandi in telnet:
Enter the following commands in telnet:
reboot
grazie / thanks
[codice]
[/codice]
You can't translate linux commands to your language ( italian )
Non si possono tradurre i comandi di linux per la vostra lingua (Italiano)
grazie
