OpenBH 0.6 Vu+ Duo2
Hi, are there any problems with the online Update? After the update the Box dont boot correct. The Bootting stops at the first BH picture.
Are there any Solution's?
Due to recent changes in the OE-A git, we recommend you do not online update OBH 0.6, as it is likely to stop your box from booting.
If you wish to update, please make a backup of your image first, and then use the new full flash update files in the 1st post of this thread. You will then be able to online update in future.
Please also remember to make periodic full backups of your image, just incase there are any future issue's, as it is outside of our control what other developers commit to the OE-A git and the build process is automated, therefore we can only fix issues when they arise but we are unable to predict them.
Can you explane more. beacuse i made a backup then i flashed , same thing . didnt work,
If you restore your full backup, you will be back where you started before you do the online update if it fails.
If you make a backup of your settings (you can use the option in software management if you wish to backup more than just channel and timer settings).
Then install the new image from the 1st post of this thread and restore your settings backup, then you will be on the latest build and have your original settings installed too.
ill stick with the original image then open black hole 0.6 will u be able to tewll all the members of the forum when we can do an up date then please what abaut the flashing light on the front display just leave it iv darkend the display so icant see it flashing on my duo2 telling me to do an up date regards
You can not update the original version, it is not possible due to changes in the OE-A git.
So reflash with the new file, that has been added to the first post of this thread.
OR
Don't reflash and never update.
The choice is yours.
OR
I've reflashed with new image and everthing now iworks fine.
many thanks for the effort.
BR
