PCSC-Lite packages for OE 1.6 Images (Duo and Solo)
072F - 9000 ... this means that we need a mipsel compiled driver...
Looking for some help , in the meanwhile may i ask your Gemplus deatils... ? to make sure to get one which is -for sure- works ? or suggest any brand for pcsc ?
wow, i no posted here thinking was poor used and useless, happy to see that someone other need it: maybe someone will try to compile they (i hope)
i don't know any other device, sorry (give a look to the 8_ccid driver, /./usr/lib/pcsc/drivers/ifd-ccid.bundle/Contents/ inside there is a list of the supported devices, i don't know if fully working or not)
072F - 9000 ...
This means that i need a mipsel compiled driver...
In the meanwhile can you suggest me a working pcsc reader on VU ? or your Gemplus model ?
072F - 9000 ...
I've downloaded the source code for your device and I try to build the packages for Duo and Solo.
I think they are avaiable this sunday.
You can find attached to this post the bh.tgz package to install in your boxes (Duo and Solo) for ACS PCSC readers.
Be careful! I haven't tested it because I don't have that device and the package is built against the logfile generated by "make install" command.
acr38_bh.tgz = no-CCID driver
acsccid_1.0.2_bh.tgz = CCID driver
wrong driver, was the not-ccid one
this one is for this ccid
<key>ifdProductID</key>
<array>
<string>0x90cc</string>
<string>0x2011</string>
<string>0x2200</string>
<string>0x2100</string>
<array>
On my previous post I've added the acr38_bh.tgz (non-CCID driver).
Please test and report.
tested with a pcscd -fd command: is spectacular :D
thanks!
ps: there is a name error in the plist file (missed libxxxxxxxxx.so) ;)
thanks!
If you have the piece of string to put into the file please write here and I upload a new updated package :)
I'm happy to read your reader works correctly :)
Hi to all! i'm hawe it i's reader
it is work of CI ?
Thaks.
Yes it's PCMCIA card reader. This vu is linux .. ok .. Why can not hardware di softwer? Enigma2? Thanks for the reply.
The problem is into CI slots: they are connected directly to CPU and act as DVB only device for Common Interfaces devices. We cannot use standard PCMCIA devices into this kind of slots.
I'm sorry.
usb 3-1: new full speed USB device using brcm-ohci-0 and address 3
usb 3-1: configuration #1 chosen from 1 choice
i'm hawe install all .*ipk my vu dont detected reader pcsc whay?
my reder it's OmniKey CardMan 1021 one pice
OmniKey CardMan 3121 one pice
OmniKey CardMan six pieces
four outputs 2.0 external hub that is plugged alimetat another external powered hub 2.0 10 outputs
logo above is done without as shown hub that is the problem?
T: Bus=01 Lev=03 Prnt=04 Port=00 Cnt=01 Dev#= 14 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=076b ProdID=1021 Rev= 1.00
S: Manufacturer=OMNIKEY
S: Product=Smart Card Reader USB
C:* #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=0b(scard) Sub=00 Prot=00 Driver=(none)
E: Ad=83(I) Atr=03(Int.) MxPS= 8 Ivl=24ms
E: Ad=84(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=05(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
The PCSC readers are driven via pcscd daemon.
