PCSC-Lite packages for OE 1.6 Images (Duo and Solo)
pcscd daemon logo
root@bm750:/# pcscd -f -d
00000000 pcscdaemon.c:267:main() pcscd set to foreground with debug send to stderr
00000240 debuglog.c:239:DebugLogSetLevel() debug level=debug
00001776 pcscdaemon.c:505:main() pcsc-lite 1.5.2 daemon ready.
01567053 hotplug_libhal.c:490:HPRegisterForHotplugEvents() Could not initialise connection to hald.
00000109 hotplug_libhal.c:491:HPRegisterForHotplugEvents() Normally this means the HAL daemon (hald) is not running or not ready.
00000064 pcscdaemon.c:524:main() SVCServiceRunLoop returned
00000051 pcscdaemon.c:530:at_exit() cleaning /var/run/pcscd
When he sees pcsc ***** start site
My set *****.server
enable                        = 1
protocol                      = pcsc
Device                        = 0
log for *****
2011/04/23 20:09:18 2AAC63B0 s anticascader thread started
2011/04/23 20:09:18 2B8934B0 r ERROR opening device 0
2011/04/23 20:09:18 2B8934B0 r Cannot open device: 0
Deburg pcscd
root@bm750:/usr/bin# pcscd -f -d
00000147 debuglog.c:239:DebugLogSetLevel() debug level=debug
00000996 pcscdaemon.c:337:main() file /var/run/pcscd/pcscd.pub already exists.
00000123 pcscdaemon.c:339:main() Another pcscd (pid: 3010) seems to be running.
Driver run ok
cat /proc/bus/usb/devices
T:  Bus=01 Lev=03 Prnt=03 Port=00 Cnt=01 Dev#=  8 Spd=12  MxCh= 0
D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs=  1
P:  Vendor=076b ProdID=1021 Rev= 1.00
S:  Manufacturer=OMNIKEY
S:  Product=Smart Card Reader USB
C:* #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=100mA
I:  If#= 0 Alt= 0 #EPs= 3 Cls=0b(scard) Sub=00 Prot=00 Driver=usbfs
E:  Ad=83(I) Atr=03(Int.) MxPS=   8 Ivl=24ms
E:  Ad=84(I) Atr=02(Bulk) MxPS=  64 Ivl=0ms
E:  Ad=05(O) Atr=02(Bulk) MxPS=  64 Ivl=0ms
My set *****.server
enable                        = 1
protocol                      = pcsc
Device                        = 0
log for *****
Deburg pcscd
Driver run ok
Talk about EMU/SW Cam is not allowed on the Board.
To verify if pcscd is currently running please use
ps aux | grep pcscd
If you want to execute the daemon in foreground do the following commands:
killall pcscd
 pcscd -f -d
In just moments pcsc that is run after a while it dies and never sees the cards, escte possibly a script to see if they are ok?
Whay it not ismode al driver ?
T:  Bus=01 Lev=03 Prnt=04 Port=03 Cnt=03 Dev#= 17 Spd=12  MxCh= 0
P:  Vendor=076b ProdID=3021 Rev= 3.02
S:  Manufacturer=OMNIKEY AG
I:  If#= 0 Alt= 0 #EPs= 3 Cls=0b(scard) Sub=00 Prot=00 Driver=(none)
T:  Bus=01 Lev=02 Prnt=02 Port=01 Cnt=02 Dev#=  5 Spd=12  MxCh= 0
T:  Bus=01 Lev=02 Prnt=02 Port=02 Cnt=03 Dev#=  6 Spd=12  MxCh= 0
T:  Bus=01 Lev=02 Prnt=02 Port=03 Cnt=04 Dev#=  7 Spd=12  MxCh= 0
T:  Bus=01 Lev=02 Prnt=02 Port=04 Cnt=05 Dev#=  8 Spd=12  MxCh= 0
P:  Vendor=076b ProdID=a022 Rev= 2.03
T:  Bus=01 Lev=02 Prnt=02 Port=05 Cnt=06 Dev#=  9 Spd=12  MxCh= 0
T:  Bus=01 Lev=02 Prnt=02 Port=06 Cnt=07 Dev#= 10 Spd=12  MxCh= 0
Because the software pcscd drives your devices and there is not kernel drivers for these devices (I will verify with my PCSCs this evening).
The problem is not that, the driver if there is what might make this the ordered 7 times (as many readers have this just moments)
If I restart it manually e * mu reader does not see them falling needles su driver what happens?
bm750 login: root
root@bm750:~# ps aux | grep hald
  689 haldaemo  4792 S    /usr/sbin/hald
  690 root      3312 S    hald-runner
  694 root      3380 S    hald-addon-input: Listening on /dev/input/event0 /dev
  698 root      3392 S    /usr/libexec/hald-addon-cpufreq
10265 root      2640 S    grep hald
10268 root      2640 R    grep hald
10270 root      2640 R    grep hald
10273 root      2640 R    grep hald
10276 root      2640 S    grep hald
10281 root      2640 S    grep hald
10285 root      2640 R    grep hald
root@bm750:~#
