PCSC-Lite Packages Updated for OE 1.6 Images (all Vu+ boxes)
root@bm750:~# pcscd -f -d
00000000 debuglog.c:269:DebugLogSetLevel() debug level=debug
00000518 pcscdaemon.c:342:main() file /var/run/pcscd/pcscd.comm already exists.
00000104 pcscdaemon.c:344:main() Another pcscd (pid: 5022) seems to be running.
Remembrd to stop current PCSCD daemon using one of these commands:
/etc/init.d/pcscd stop
OR
killall pcscd
Then you can launch PCSCD daemon with this command:
pcscd -f -d
00001529 configfile.l:287:DBGetReaderList() Parsing conf file: /etc/reader.conf.
d
00000287 pcscdaemon.c:556:main() pcsc-lite 1.7.4 daemon ready.
00013258 hotplug_libusb.c:504:HPAddHotPluggable() Adding USB device: 3:2:0
00000413 readerfactory.c:934:RFInitializeReader() Attempting startup of ACS ACR3
8U-CCID 00 00 using /usr/lib/pcsc/drivers/ifd-acsccid.bundle/Contents/Linux/liba
csccid.so
00003967 readerfactory.c:824:RFBindFunctions() Loading IFD Handler 3.0
00000683 ifdhandler.c:1532:init_driver() Driver version: 1.0.2
00001808 ifdhandler.c:1545:init_driver() LogLevel: 0x0003
00001702 ifdhandler.c:1565:init_driver() DriverOptions: 0x0000
00000099 ifdhandler.c:82:IFDHCreateChannelByName() lun: 0, device: usb:072f/90cc
:libusb-1.0:3:2:0
00008185 ccid_usb.c:286:OpenUSBByName() Manufacturer: Advanced Card Systems Ltd.
00001716 ccid_usb.c:296:OpenUSBByName() ProductString: ACS CCID driver
00001583 ccid_usb.c:302:OpenUSBByName() Copyright: This driver is protected by t
erms of the GNU Lesser General Public License version 2.1, or (at your option) a
ny later version.
00005267 ccid_usb.c:505:OpenUSBByName() Found Vendor/Product: 072F/90CC (ACS ACR
38U-CCID)
00000228 ccid_usb.c:507:OpenUSBByName() Using USB bus/device: 003/002
00000818 ccid_usb.c:942:get_data_rates() IFD does not support GET_DATA_RATES req
uest: Success
01105969 ifdhandler.c:364:IFDHGetCapabilities() tag: 0xFB3, usb:072f/90cc:libusb
-1.0:3:2:0 (lun: 0)
00000289 readerfactory.c:290:RFAddReader() Using the pcscd polling thread
00004081 ifdhandler.c:364:IFDHGetCapabilities() tag: 0xFAE, usb:072f/90cc:libusb
-1.0:3:2:0 (lun: 0)
00000101 ifdhandler.c:418:IFDHGetCapabilities() Reader supports 1 slot(s)
00000275 hotplug_libusb.c:411:HPEstablishUSBNotifications() Driver ACR38UDriver.
bundle does not support IFD_GENERATE_HOTPLUG. Using active polling instead.
00000110 hotplug_libusb.c:420:HPEstablishUSBNotifications() Polling forced every
 1 second(s)
00000142 readerfactory.c:1301:RFWaitForReaderInit() Waiting init for reader: ACS
 ACR38U-CCID 00 00
00006940 ifdhandler.c:1043:IFDHPowerICC() action: PowerUp, usb:072f/90cc:libusb-
1.0:3:2:0 (lun: 0)
00004010 readerfactory.c:1301:RFWaitForReaderInit() Waiting init for reader: ACS
 ACR38U-CCID 00 00
00010987 readerfactory.c:1301:RFWaitForReaderInit() Waiting init for reader: ACS
 ACR38U-CCID 00 00
00011008 readerfactory.c:1301:RFWaitForReaderInit() Waiting init for reader: ACS
 ACR38U-CCID 00 00
00010989 readerfactory.c:1301:RFWaitForReaderInit() Waiting init for reader: ACS
 ACR38U-CCID 00 00
00011004 readerfactory.c:1301:RFWaitForReaderInit() Waiting init for reader: ACS
 ACR38U-CCID 00 00
00010999 readerfactory.c:1301:RFWaitForReaderInit() Waiting init for reader: ACS
 ACR38U-CCID 00 00
00011010 readerfactory.c:1301:RFWaitForReaderInit() Waiting init for reader: ACS
 ACR38U-CCID 00 00
00010997 readerfactory.c:1301:RFWaitForReaderInit() Waiting init for reader: ACS
 ACR38U-CCID 00 00
00010988 readerfactory.c:1301:RFWaitForReaderInit() Waiting init for reader: ACS
 ACR38U-CCID 00 00
00011015 readerfactory.c:1301:RFWaitForReaderInit() Waiting init for reader: ACS
 ACR38U-CCID 00 00
00010986 readerfactory.c:1301:RFWaitForReaderInit() Waiting init for reader: ACS
 ACR38U-CCID 00 00
00011013 readerfactory.c:1301:RFWaitForReaderInit() Waiting init for reader: ACS
 ACR38U-CCID 00 00
00012379 readerfactory.c:1301:RFWaitForReaderInit() Waiting init for reader: ACS
 ACR38U-CCID 00 00
00010619 readerfactory.c:1301:RFWaitForReaderInit() Waiting init for reader: ACS
 ACR38U-CCID 00 00
00001084 eventhandler.c:256:EHStatusHandlerThread() powerState: POWER_STATE_POWE
RED
00000135 Card ATR: 3F 77 18 00 00 C2 7A 42 02 68 90 00
00406730 ifdhandler.c:1043:IFDHPowerICC() action: PowerDown, usb:072f/90cc:libus
b-1.0:3:2:0 (lun: 0)
00099075 eventhandler.c:446:EHStatusHandlerThread() powerState: POWER_STATE_UNPO
WERED
d
csccid.so
:libusb-1.0:3:2:0
ny later version.
38U-CCID)
uest: Success
-1.0:3:2:0 (lun: 0)
-1.0:3:2:0 (lun: 0)
 1 second(s)
 ACR38U-CCID 00 00
1.0:3:2:0 (lun: 0)
 ACR38U-CCID 00 00
 ACR38U-CCID 00 00
 ACR38U-CCID 00 00
 ACR38U-CCID 00 00
 ACR38U-CCID 00 00
 ACR38U-CCID 00 00
 ACR38U-CCID 00 00
 ACR38U-CCID 00 00
 ACR38U-CCID 00 00
 ACR38U-CCID 00 00
 ACR38U-CCID 00 00
 ACR38U-CCID 00 00
 ACR38U-CCID 00 00
 ACR38U-CCID 00 00
RED
WERED
Seems all correct .......
what could be the problem ? i'am using device = 0 ?
i try device = 2 or device = 3 ?
how i can get it working again ? and avoid unknown issue , btw i did changed anything in config or *****
what i can do ?
Thx
what i can do ?
Thx
If you have one reader the
device = 0
is correct.
Update your emu to try to solve the problem.
Please make care: in this Board talk about cam/emu software is forbidden. This rule is also applied to configuration talks :)
that's why i hate this forum , i didnt talked about any emu or so , so please get away from me cause i'am old in the scene not stupid to talk about your shitty rules
this forum as only angelofsky which is helpful others are just time waster , rules reminder nothing to do
fuck you Matrix :mad:
i just hope i fix my issue will never come to this boring forum bunch of useless admin have no clue
btw Thx angelofsky for help but i cant get it working
anyway if i got banned , you can find me at angels of fire...
ciao e grazie
ciao e grazie
I do not know why you need this,
this is not the way we communicate on this forum.
just friendly I warned you,
Nothing more and nothing less
But In addition, you have already previously wrote post about the emu ecm info.
So this is the second time.
This is a friendly forum with a friendly way of communicating
even when you do not have the same opinion.
So you do not belong here.
@angelofsky
are these drivers applicable only to VU receivers and/or blackhole images?
thanks fesoj
thanks for your reply
tried on my VUs and as you said they work really well, but on my 800se no joy
will try installing again maybe something went wrong
thanks again m8
Package Details:
PCSC-Lite v1.7.4
CCID Drivers v1.4.4
LIBUSB v1.0.4
Installation Instructions:
If you have installed previous version of this kind of packages I suggest to start with a fresh image to avoid conflicts or remove the old packages.
Pay attention to do not mix libraries/drivers!!!!!!!
Copy all ipkg files into /tmp and install as usual.
Packages tested on my Vu+Uno :)
hi ,
i have the latest blackhole image installed in my vu+duo & i updated the drivers last night aswell .
initially i was getting this message PCSC failed establish context (8010001d)
Cannot open device: 0
i then installed the latest drivers .
as instructed here i placed all 4 ipk files in temp & installed as normal . i got the message installed ....... to root .
i then rebooted the box & went to telnet & tried this pcscd -f & got the message not found then i tried this pcscd -f -d still the same message not found .
i set the device to 0 , 1 , 2 & everytime restarted gui but no luck . as i only have 1 pcsc device connected it should have recognised it at 0 .
i do not have these files in my box . i would appreciate any help & support to resolve this matter .
hi ,
I need some infos about your HW.
1. detailed data about your PCSC device (Model, Manufacturer, USB IDs)
2. the output of this command: cat /proc/bus/usb/devices (with PCSC reader connected to box)
Remember:
to launch PCSC Daemon into debug mode do the following commands:
killall pcscd
pcscd -f -d
Remember:
killall pcscd
pcscd -f -d
hi mate i have just tried the commands as you instructed but i still get the same message not found .
i have a omnikey 3121 . it just does not recognise the reader . whilst having the reader connected the green light does come on the omnikey reader .
so i am guessing the reader is fine . any thoughts & suggestions would be great .
